Real Street Setup
fl59bug
fl59bug is offline
PostPosted: Sat Apr 01, 2023 12:27 pm    Post subject: Real Street Setup Reply with quote
For those competing in the Real Street class, which I've been watching a lot of on YT, what is a "typical" setup? What mods to the car, and most importantly to me, its driveline?
What displacement, hp, heads, cam, carbs, oiling mods etc.? Is a built bus IRS tranny allowed?
Does anyone on thesamba compete in this class and if so what are your setup specifics?
thanks in advance
Ted
madmike
madmike is offline
PostPosted: Sat Apr 01, 2023 5:16 pm    Post subject: Re: Real Street Setup Reply with quote
Should be a 'Rule Book' somewhere?
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
vince1
vince1 is offline
PostPosted: Sun Apr 02, 2023 1:03 am    Post subject: Re: Real Street Setup Reply with quote
https://www.facebook.com/groups/157560131623071/files/files
Race director will be: Dino Mendoza (626) 278-7825
Cruise Rules
At any time during the race the officials reserve to right to collect fuel samples that will be sent for testing. Violators will be banned for the year/season
20 mile cruise the day of the race is MANDATORY!
• To participate in the cruise/race you must pay ahead of time to secure your spot
• You can purchase your spot at volkstroke.com or cash to Dino
• No stops, fixing or refuels during cruise
• Breakdown during the cruise will eliminate you
• Must show up with empty gas tank to refill at gas station where cruise starts
• Gas tanks will be sealed prior to cruise by race director (in the event that gas is needed, only the race director can remove seal)
• Entry fee must be submitted no later than the time of the street cruise
• No driver swaps! (same driver for cruise & race)
Engine and Vehicle Restrictions
• Weight for engine combinations as follows:
• Light (1738=82mm crank shaft X 94mm cylinder bore)
• Medium (1775 lbs= 84mm CS X 94 mm CB)
• Heavy (1825 lbs= 86 mm CS X 94 mm CB)
• 91 octane max (No E85)
• All factory style: steel fiberglass, body parts are OK as long they are bolted like stock body parts. NO dzus on outside body panels anywhere. Package tray areas and the shell of the VW must not be cut out is so must have a firewall and either bumpers or factory style ragtop as penalty. Must run with decklid on. No more than a 10in gap between decklid and body (complete cars)
• Minimum trimming in engine compartment and rear apron allowed
• Min 2 seats required- must have front door panels (matching seats or a stock passenger seat)
• All Motor (carburated only)
• No power adders
• No Fuel Injection
• No mixed fuels (No octane boosters or fuel additives)
• No fuel chillers (in vehicle)
• No vacuum pump
• No roller camshaft
• No dry sumps (must be wet, stock or deep sump)
• No wheelie bars
• No clutch management of any kind
• No spool/No electronic lockers
• STOCK VW dual-port intake stud location only! Manifold cannot be oversized (intake stud itself)
• Functioning 4 wheel brakes required
• DOT tires allowed all around 235 60 15 max on the rear (cheaters, or street radials, front rollers okay)
• Engine cooling system must remain in the engine at all times, fan belt could be removed (Stock shroud or 911 style allowed)
• 48 MM bore carburetor as max
• No stingers (must run minimum 8” bullet style or 6” chambered muffler)
• Carburetor may have 48.0mm throttle plates with 44 mm venturi or smaller, Berg venturi is okay
• IDA, IDF, DRLA, replicas & copies are allowed. Mods are OK as long as they remain mechanical and has throttle plates
• Stock transmission location is okay
• IRS trailing arms, 1inch narrow allowed
• No raise or narrowing of torsion housing allowed
• Type 2 transmission allowed must be within 1 inch of stock location
• No E.T. trigger in front of the car. (front bumper, T-bar or no bumpers is OK)
• No chop tops, roof sectioning, channeling, or shortening of floor pan or body
• Standard wheel base, no scattered front wheels
Race Day Rules
• Registration and insurance required (will be verified at the buy in)
• Fuel will be checked for octane levels for finalist and #1 qualifier
• 1/8 mile Heads Up
• Pro light “pro .004”
• Repairs during the race are allowed, as along as its policed by our class official and another Real Street Racer participant (no exceptions or will be disqualified)
o Must replace with similar part- not of higher performance
o Timing, jets, etc.
o No oil changes permitted on premises or surrounding area the day of the race, no exceptions!
• $40 buy in on an 8 car field the winner will get $200 and the runner-up $120 on top of the sponsorship money
• Winner and runner up’s engines will be pumped at each race to ensure the integrity of the class
• All vehicles must roll across the scales at time of tech with every pass you want validated and for points purposes
• One warning during qualifying if the car doesn't have a roll cage if the car runs an illegal number during eliminations automatic DQ
• Swapping wheels between cruise and race is ok as long as the tires on the track are DOT
• Finalist will have to drain their entire fuel system. Officials will provide 2.5 gallons for each contender of the final round
• 13 car minimum for 16 car ladder (in the event that the car minimum (13) is not met, we will run an 8 car ladder from the fastest 8 qualifiers only)
All vehicles must meet NHRA safety requirements per E.T. and MPH ran
PLEASE PARK CLOSE TOGETHER TO FACILITATE THE PROGRAM!!!!
Be respectful to the race director the Periscope Racing Association and the track officials “talking trash” on Facebook or elsewhere is not going to make you quicker or faster on Race day -we are encouraging a peaceful, positive racing family atmosphere.
Thank you
my French blog https://vwpanelvan.wordpress.com/
Click here for my full pix detailed 2165 engine build with beehive valvetrain.
Sorry for my poor English, I'm a French guy ... Wink
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
mark tucker
mark tucker is offline
PostPosted: Sun Apr 02, 2023 8:22 am    Post subject: Re: Real Street Setup Reply with quote
that sounds like fun.
fl59bug
fl59bug is offline
PostPosted: Sun Apr 02, 2023 10:44 am    Post subject: Re: Real Street Setup Reply with quote
Thank you very much guys!
I see that carb size is max 48mm. It sounds like 51.5s are excluded in that case, interesting!
Ted
