Early vs late clutch action
Ted2
Ted2 is offline
PostPosted: Wed Apr 05, 2023 5:01 am    Post subject: Early vs late clutch action Reply with quote
Question of the day:
There is a marked difference between my 4/55 and 11/55 beetles clutch operates.
Is there a difference in the clutch feel between early and late Ovals?
Thanks
Erik G
Erik G is offline
PostPosted: Wed Apr 05, 2023 8:38 am    Post subject: Re: Early vs late clutch action Reply with quote
Thanks
In my opinion you need to look at what your issue is. They do not operate differently. You may have a carbon bearing on one, a roller type on the other, mix matched parts, new vs old, a cable fraying etc.
this is akin to "I have a check engine light on, what could it be" or "How long is a string".
earlywesty
earlywesty is offline
PostPosted: Thu Apr 06, 2023 5:38 pm    Post subject: Re: Early vs late clutch action Reply with quote
Do you what pressure plate is on each? I have found a massive difference in feel between spring vs diaphragm style. I prefer the original spring style.
Ted2
Ted2 is offline
PostPosted: Fri Apr 07, 2023 4:34 am    Post subject: Re: Early vs late clutch action Reply with quote
Thanks for the input.
The clutch has been adjusted but I haven't pulled the engine to see what clutch is in the '55.
The operation just feels different than on the '56.
