rsbadura Samba Member
Joined: November 30, 2009 Posts: 771 Location: Berlin, Germany
Posted: Sat Apr 08, 2023 11:06 am Post subject: Re: Hazet Assistent |
Hello everyone,
my Hazet Assistent 160 from 1954 is now ready for use again...
My Hazet Assistant fleet is now complete for my needs:
1955 Hazet (HELKA Favorit) for VW workshops, 1967-1976 HAZET Assistent 166 TS, 1954 Hazet Assistent 160
(last 2 Assistent with Hazet 161-0 stool and Hazet 161-5 lamp from Rademacher)
happy easter and regards from Berlin _________________ Rolf-Stephan Badura
1970 VW Karmann-Ghia Coupe
1979 VW Bus L camper conversion
1982 Eriba Pan travel trailer
2017 VW CrossPolo
HAZET classic tools collection
notchboy Samba Member
Joined: April 27, 2002 Posts: 22688 Location: Escondido CA
SplitBusVanatic Samba Member
Joined: August 16, 2005 Posts: 355 Location: Co. Mayo. Ireland
Posted: Thu May 25, 2023 2:26 am Post subject: Re: Hazet Assistent |
So. I now have two Rademacher lamps.
Question: which should I give to my buddy. ? I only want one to keep one lamp for myself. I think the black one is better suited to my needs !!! What do you guys think ? |
Posted: Thu May 25, 2023 3:28 am Post subject: Re: Hazet Assistent |
| SplitBusVanatic wrote: |
| So. I now have two Rademacher lamps. Question: which should I give to my buddy? |
the silver one never sold by HAZET - so give it away.
Rademacher was an old company (founded 1914 - included to another company 2018) with many industrial lamps such as scissor lamps or with rollable stands for doctors and laboratories. Only one model of them with different versions over time 1954-1979 was sold by HAZET.
The black one fit to early little "a" Hazet Assistent 160/161/162 of the time frame of 1954 to around 1963 (followed by the same partly in grey, exchanged by a modern design in 1967 - but different to your silver model). The switch is missing the rubber cap to protect against dust and water - but it is mostly missing - the rubber got brittle over the decades. But also the joint at the base is missing and the junction box for the incoming cable (3 cores with grounding incoming - to 2 cores for lamp in front - I hope it is currently securely connected with grounding - spend a new cable also inside to be safe or cut the cable entirely). So quite incomplete and not in such a good condition.
regards, _________________ Rolf-Stephan Badura
2017 VW CrossPolo
HAZET classic tools collection |
Posted: Thu May 25, 2023 4:34 am Post subject: Re: Hazet Assistent |
Thank you for your reply Rolf.
Yes. There is indeed a new cable on the black one. And a switch. But not rademacher unfortunately, but fine for my needs.
I am leaning towards the black one certainly.
I may borrow the lower fixture and hinge part for the lower joint off the grey lamp and transfer to the black one, to attach to the upright of the Assistent.
MFG. |
Posted: Sun May 28, 2023 2:05 pm Post subject: Re: Hazet Assistent |
Yes. There was no switch on my black lamp. I added a generic lamp cable switch one when i put a new cable on it.
Any luck with a key for your TS ? |
70bus  Samba Member
Posted: Tue Jun 27, 2023 9:30 am Post subject: Re: Hazet Assistent |
Accessory 1607 - anyone have one?
I didn't flip through all 61 pages of this thread yet, but a random look indicates these were not common. 480 mm long-ways dividers. Also, setup D look useful! Any 1605 and 1606 out there?
Rather find some real ones than go tin snips and rattle-can blue paint route... _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Raoul the 65 singlecab
Karl the 70 nine-seater |
70bus  Samba Member
Posted: Tue Jun 27, 2023 4:46 pm Post subject: Re: Hazet Assistent |
That's a neat photo - practically a charming Mom-and-Pop-factory set-up.
I may look for a modern 1607 equivalent and try to modify; I have a few tools that would go better lengthways rather than tossed in the tub at bottom! I have to say, at first I was a bit embarassed to have spent the (very fair-price) money on mine, but I use the damn thing every day, and rolling it around is so much nicer than closing and hauling my big metal toolbox(es) from one task to another. If you have been thinking about tool storage and can spare the cash, I recommend them. Plus, spouse thinks it's cute. _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Posted: Fri Aug 25, 2023 12:59 pm Post subject: Re: Hazet Assistent |
Hello everyone,
| notchboy wrote: |
| My question was going to be - what tools do you already have for this? |
some - not all as 781-5 hub puller and some sheet metal tools (I have other) - and some existing tools that i didn't immediately find for the photo today
What I didn't know until today: above the 450 wrench pyramid behind the wheel cross there is still a place to hook in a 450 Remscheid holder with other open-end wrenches to take with you quickly.
But still in progress: CHROM VANADIUM inscription at the top is still missing, the lock is still being worked on (will be good and look like original), ...
and I need a shorter saw blade - the long one (new HAZET blade) did not fit
and to be true to the main topic here:
2017 VW CrossPolo
Posted: Wed Nov 22, 2023 8:07 am Post subject: Re: Hazet Assistent |
| It it strange that there is a half a bottom divider in that picture above. |
