Terry Cloyd Banned
Joined: March 23, 2004 Posts: 2218 Location: Valley Center "SO CAL"
Posted: Sat Jul 05, 2008 12:50 am Post subject: |
dog_jr911 wrote: |
this should be in minimans and scott novaks thread.... or added to it..... |
I don't think they will. We let no one know  |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Sat Jul 05, 2008 3:00 am Post subject: |
dog_jr911 wrote: |
It's no secret what a magneto is, or what it does. I'm not going to get into it because, quite frankly, they have no place in a street driven vehicle other then the 'wow' factor. I'll buy that aircraft and racecars have the need, because they operate independently of the car's electrical system, and are therefore a huge safety factor in those applications. However, their lack of accurate timing control, like a distributor, cancels any positive benefit in a street driven application for me. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Marty Staggs Samba Member
Posted: Sat Jul 05, 2008 8:53 am Post subject: |
A magneto is the most reliable and fool proof iginition you could ever put on a motor. _________________ Marty |
stoneloco808 Samba Member
Joined: June 15, 2007 Posts: 658 Location: Pakalolo Country, HI
Posted: Sat Jul 05, 2008 9:37 am Post subject: |
I have a Joe Hunt magneto sitting in a box. Is there a way to determine if the advance is locked out or not without installing it on an engine and running it? |
vw505 Samba Member
Joined: January 04, 2005 Posts: 435 Location: Lemoore,ca
Posted: Sat Jul 12, 2008 10:42 pm Post subject: |
I was thinking of getting a locked out one for my blower motor. |
birddog1148 Samba Member
Joined: June 03, 2005 Posts: 921 Location: Sandusky Ohio at my Brewery playing with cars.
Posted: Sun Jul 13, 2008 8:43 am Post subject: |
I run one on a 327 in a dirt late model, I have a battery and no charging system. _________________ '69 Baja, Crusty 62 bug
I Got Your Jeep Thing! Now It Hurts When I pee.
Cigarettes are like squirrels, they are both harmless until you put one in your mouth and light it on fire. |
klrskies Samba Member
Posted: Sun Jul 13, 2008 8:54 am Post subject: |
Do magnetos have a mechanical advance mechanisim? |
Messy Jesse Samba Member
Joined: January 03, 2006 Posts: 175 Location: North of Philly
Posted: Sun Jul 13, 2008 9:04 am Post subject: |
stoneloco808 wrote: |
I think it would work with one of those distributer testers like Glenn has:
http://www.youtube.com/watch?v=l34CmJgHjU8&eur...p;start=40 |
grimace007 Samba Member
Joined: August 30, 2006 Posts: 2673 Location: swampville, florida
Posted: Sun Jul 13, 2008 9:22 am Post subject: |
i like your steve zissou icon jessy.
sorry to threadjack guys. _________________ Brian
68 sedan
Dallas Air Coolers
perrib wrote: |
Hey It is The Samba where well thought out rational answers can take a while and getting side tracked is normal. I was just lucky this time.  |
cr@M wrote: |
No one has any personal responsibility these days. This country is sue happy. Intelligence is no longer a requirement, just an accessory. |
Posted: Sun Jul 13, 2008 12:03 pm Post subject: |
Thanks, I guess I am out of luck, I don't think anyone has that machine on this rock in the middle of the Pacific.
Another question, what is the advantage or disadvantage of both, w/advance and w/locked out advance? |
BobKTX Samba Member
Posted: Wed Apr 19, 2023 8:43 pm Post subject: Re: Vertex Magneto!? |
Guys, sorry to crash the thread, but finding folks who know what a Vertex magneto is let alone may be able to provide assistance has been a challenge.
I have a freshly rebuilt Vertex magneto (Joe Hunt did the rebuild). I also purchased from them the Magneto Tach Converter, since I'll be running a newer electronic tach. Has anyone used this box from Hunt for this purpose?
I have downloaded the wiring diagram that comes with the converter and I'm still a bit confused. Here is what I think needs to be done.....
Red - connect to a 12 volt switch power source
Black - connect to vehicle ground
Violet - connect to the input of the tach
Brown/Black - connect to one side of the kill switch along with a wire to the vehicle ground
Brown/Orange - connect to one side of the kill switch along with a wire from the terminal on the magneto
Brown/Yellow - No need to use in my situation
Does my interpretation of where the last three wires go correct?
Thank you in advance for any guidance. |
VeloMikey Samba Member
Posted: Sun Apr 23, 2023 9:42 am Post subject: Re: Vertex Magneto!? |
Here you go...
Don't worry about Brown / Orange and Brown / Yellow.
Just hook up Brown / Black to the ground lug on the magneto.
_________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748 |
BobKTX Samba Member
Posted: Sun Apr 23, 2023 11:32 am Post subject: Re: Vertex Magneto!? |
VeloMikey wrote: |
Here you go...
Here is how I currently have it connected. This should work right?
The reason I'm asking is that I have mounted the converter under the dash and have already run the ground/kill wire to the magneto.
Posted: Mon Apr 24, 2023 6:16 am Post subject: Re: Vertex Magneto!? |
BobKTX wrote: |
VeloMikey wrote: |
Here you go...
I think you are good. If it doesn't work correctly try moving the ground to the other side of the switch. _________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
BobKTX Samba Member
Posted: Tue Apr 25, 2023 7:39 am Post subject: Re: Vertex Magneto!? |
Since the converter is the same one that Autometer sells I reached out to them, while I'm waiting to hear back from Joe Hunt's tech guy. They tell me that this converter will not work with the Vertex OAC, but I swear I checked this out before I bought the converter and electronic tach. I also spoke with a guy from a company called Fuel Injected that sells a Hall Effect sensor for the Vertex magneto, but since it sends two pulses per revolution, you need to setup your tach for 1/2 the number of cylinders you have in order to get an accurate reading. The problem is that the electronic tach I have will not allow me to configure it for three cylinders....... |
Posted: Tue Apr 25, 2023 11:32 am Post subject: Re: Vertex Magneto!? |
BobKTX wrote: |
What is an OAC Magneto? Internal coil? My buddy gave me my mag and the Autometer adapter box. It all worked in his sand car so I know it works. The only thing that didn't come out of his car is my Autometer tach. I will buy a new tach if necessary. Why do you need to set the tach to a 3 cylinder? Do you have a six cylinder?
Here is a link to the instructions. You want to set it to 3 pulse not 3 cylinder.
https://www.autometer.com/pub/media/manual/2650-1165.pdf
Clatter Samba Member
Joined: September 24, 2003 Posts: 7782 Location: Santa Cruz
Posted: Tue Apr 25, 2023 6:09 pm Post subject: Re: Vertex Magneto!? |
How great was this forum BITD, eh? _________________ Bus Motor Build
It does not exist! |
BobKTX Samba Member
Posted: Tue Apr 25, 2023 7:24 pm Post subject: Re: Vertex Magneto!? |
Clatter wrote: |
How great was this forum BITD, eh? |
I'm thrilled that I could re-activate a 15 year old thread to get the answers I needed. Many thanks to all. |
BobKTX Samba Member
Posted: Mon Sep 23, 2024 5:51 pm Post subject: Re: Vertex Magneto!? |
Yesterday, my adult son and I started up my 1959 Chevy straight six ( 261 cubic inches) engine that had recently been rebuilt. Happily, it started on the first turn of the key after I spent a week re-installing the engine, trans, and other components. I spent some time tuning the idle and was happy with the outcome.
Today, I went to fire up the engine, but forgot to turn the fuel pump on. The engine ran for a few seconds until the fuel bowl was empty and then stopped suddenly. I then realized my error and turned the fuel pump on. The engine cranked but would not even cough to get started. I've spent all day chasing every angle of spark, air, fuel. Using a spark tester (wire between plug and wire that lights up with spark), I can see that there is spark but I've come to believe that the issue is with the magneto.
When I took the cap off to see what was going on, I saw that the engine builder neglected to put the red plastic isolator piece under the rotor, he probably lost it. I fashioned one from some gasket material and punched holes for the rotor, the conductor, and the two screw holes. Despite those efforts the engine still would not start.
I decided to ensure that the engine was getting adequate ground and using my multi-meter, I found that the engine was getting great ground, no issues. When I tested continuity from the frame to the Vertex (internal coil) magneto case, I saw that it was grounded, as I would have expected given that its mounted into the engine block, but I became concerned when I was getting continuity to the grounding terminal on the side of the magneto. In fact, I get continuity between the terminal and the magneto case too. I thought the grounding terminal was isolated from the case, so that when I used the switch on the dash it would ground out that terminal to stop the magneto.
Should the grounding terminal show continuity to the case?
Thanks in advance for any assistance. |
BobKTX Samba Member
Posted: Mon Sep 23, 2024 5:52 pm Post subject: Re: Vertex Magneto!? |
