‘95 993 Mystery hole in Fan Shroud Cover
Pepperbilly
Pepperbilly is offline
PostPosted: Sat Apr 29, 2023 4:52 pm    Post subject: ‘95 993 Mystery hole in Fan Shroud Cover Reply with quote
Have seen this before and always wondered why this open hole? It is on the right side bank side (cyl 4, 5, 6). Easy to see after removing the air cleaner housing. When the engine is running it allows a stream of cooling air to escape. It is located behind the intake plenum in the center of the photo. This is a fully stock ‘95 USA Carrera. I don’t like the fact that cooling air leaks out here. Also could be it does not matter?
Bill
Flashlight lights up the hole in question
squaret3
squaret3 is offline
PostPosted: Thu Mar 14, 2024 7:37 pm    Post subject: Re: ‘95 993 Mystery hole in Fan Shroud Cover Reply with quote
I'm fairly certain that hole is to inspect the knock sensors, 1 per bank, attached to an aluminum bridge between all three cylinders on each bank.
Cheap, Fast, Reliable- Pick two.
Pepperbilly
PostPosted: Fri Mar 15, 2024 7:23 pm    Post subject: Re: ‘95 993 Mystery hole in Fan Shroud Cover Reply with quote
Thanks for that. Shortly after I posted this I found out from other sources that the hole is for inspecting the knock sensor and access, just like you say.. What I am now trying to figure out if there is a plug for that hole? I would think that cooling air would be escaping with the engine running.
Bill
TornadoRed06
TornadoRed06 is offline
PostPosted: Tue Mar 19, 2024 2:25 pm    Post subject: Re: ‘95 993 Mystery hole in Fan Shroud Cover Reply with quote
Bill,
I went out to check the cooling diagram, it may be the location for these:
rubber grommets
9 - 911.612.328.00
10 - 911.612.327.00
What is the specification of your car, Varioram, Non-Varioram ?
Pepperbilly
PostPosted: Tue Mar 19, 2024 4:03 pm    Post subject: Re: ‘95 993 Mystery hole in Fan Shroud Cover Reply with quote
TornadoRed06 wrote:
Bill,
rubber grommets
9 - 911.612.328.00
10 - 911.612.327.00
Thanks for checking! This is a non varioram induction.
Pepperbilly
PostPosted: Fri Mar 29, 2024 8:04 pm    Post subject: Re: ‘95 993 Mystery hole in Fan Shroud Cover Reply with quote
TornadoRed06 wrote:
Bill,
rubber grommets
9 - 911.612.328.00
10 - 911.612.327.00
Well, I doubled checked those grommets you researched and they are not for that hole. That which you listed is a double grommet with holes in the center for a wire. The mystery hole should have a solid plug to keep the cooling air from escaping. This hole is still being debated as we speak. No one has yet found the answer and Porsche keeps us in the dark as to what part [if any], should go there.
Bill
TornadoRed06
PostPosted: Sat Mar 30, 2024 10:29 am    Post subject: Re: ‘95 993 Mystery hole in Fan Shroud Cover Reply with quote
Germans being germans would never engineer and design features without a purpose. I don't find any possible part on the diagram that could be missing so, for now, I would say it is a by-product of the production process like, pilot hole or control dimensioning.
I attach the part & picture list here, you could possibly already had seen it too.
I could have questioned this, if I hadn't forgot about it , when I went to the local OPC this week... Rolling Eyes
Pepperbilly
PostPosted: Sat Mar 30, 2024 12:25 pm    Post subject: Re: ‘95 993 Mystery hole in Fan Shroud Cover Reply with quote
Haha…so true. I am of German descent because my parents were from there. Came to the Seattle area after WW2. That is the reason this bothers me so. I know it’s there for the kno ck sensors but why no plug listed. Everyone you talk to and it’s the same story. Where is the part #?
Bill
