Flasher relay mega mystery!
mickey mouse
mickey mouse is offline
PostPosted: Tue May 16, 2023 3:23 pm    Post subject: Flasher relay mega mystery! Reply with quote
Hi everyone,
I've replaced my broken 1970 fuse box with a rewired 1972 after being handed back a mess of wires by the mechanics that said they would fix things. Everything works but my hazard lights and turn signals.
I replaced the emergency flasher switch, which was definitely bad, and I even got the exact same one as the original.
Now when I turn on the hazard lights I have power leaving the switch, going to and entering the flasher relay, but I have no power leaving the relay.
I bought a cheap one at autozone to see if it would work, but I get the same result: no power leaving the relay, no turn signals, no hazard lights.
I am mystified!
Please help!
bsairhead
bsairhead is offline
PostPosted: Tue May 16, 2023 3:58 pm    Post subject: Re: Flasher relay mega mystery! Reply with quote
Verify ground path to gauge cluster
mickey mouse
PostPosted: Tue May 16, 2023 4:11 pm    Post subject: Re: Flasher relay mega mystery! Reply with quote
yes i have the ground wire going to ground up to the left of where the fuse box mounts, then another brown wire leading from that to the gauges.
bsairhead
PostPosted: Tue May 16, 2023 6:26 pm    Post subject: Re: Flasher relay mega mystery! Reply with quote
How many connections on the relay?
mickey mouse
PostPosted: Wed May 17, 2023 2:00 pm    Post subject: Re: Flasher relay mega mystery! Reply with quote
All fixed! I had the positive and negative terminals backwards!
