shizzon Samba Member
Joined: July 25, 2006 Posts: 600 Location: Boulder, CO
Posted: Sun Jul 09, 2017 3:18 pm Post subject: Re: Bostig AC mod |
So is 7 oz total or 9 oz total correct? It sounds like 5 or 7 oz goes to compressor, and then the other 2 goes elsewhere in the system _________________ 1989 Bostig Syncro Westy |
LemonCove Samba Member
Joined: July 29, 2010 Posts: 324 Location: Henderson, NV
Posted: Mon Jul 10, 2017 1:36 pm Post subject: Re: Bostig AC mod |
I used 7. From my notes in 2013: I added 4 oz of oil to the compressor through the ports (new Ford compressor shipped dry). I also added 2 oz to the evaporator, and appx 1/2 oz to the receiver/drier, and the same to the hoses where they connect to the condenser at the front of the car. _________________ '88 Bostig Westy |
Posted: Tue Jul 11, 2017 10:35 am Post subject: Re: Bostig AC mod |
Thanks!
Quick history - I replaced almost everything last year (all new hoses, new parallel flow condensor, drier, expansion valve, cleaned out evaporator with air line cleaner), but stupidly used a compressor that was used and had been sitting for a while.
Not long after getting the system fully functional, the compressor started to go (clutch was staying engaged even when system was off).
So now I'm just replacing the compressor and drier. I'm trying to figure out if I should just add 4 oz to compressor and 1/2 oz to drier, or try and put in a complete 7 oz into the system. I assume a fair bit of oil remains in the evaporator, condensor, and lines.
Any advice on how much to put in, or does it not matter that much? _________________ 1989 Bostig Syncro Westy |
Farf Samba Member
Posted: Tue Jul 11, 2017 11:16 am Post subject: Re: Bostig AC mod |
Follow steps for compressor replacement on Page 22 (I think). You may not have a Sanden compressor but the process is the same. Add an additional .7 oz for the new R/D, you can add this right into the compressor too.
www.sanden.com/productlibrary/manuals/SD_Service_Guide_Rev_2.pdf |
Posted: Tue Jul 11, 2017 11:44 am Post subject: Re: Bostig AC mod |
Thanks. I don't have a sanden compressor (it's a ford one).
Unfortunately I pulled the compressor in a friends driveway on a road trip and didn't measure how much oil came out.
I think I'm going to assume that there is still a few oz in there and just put 4.5 in the compressor and 0.5 in the drier. _________________ 1989 Bostig Syncro Westy |
vanagoonsquad Samba Member
Posted: Sun May 29, 2022 1:27 pm Post subject: Re: Bostig AC mod |
Resurrecting this thread for a relevant wiring question. I'm sure the photos posted here would have helped answer this, but the links are all dead. I've checked out all of the relevant threads here and on the Zendesk site, but I'm still not sure.
I'm trying to wire up my compressor. Here is a photo of the wires that have been tucked away after the WBX removal.
The wire at the top with a ring terminal is brown. Beside it is a red/blue wire that forks (via some sort of quick disconnect) into a single male pin connector and a female spade connector. The largest wire is red and I've gathered this needs to be connected either to the post in the distribution box or the post on the alternator (does it matter?)
Is the fork on the Red/Blue wire redundant? It seems the fork once led to the idle stabilizer unit? My intuition is to snip the fork and connect the Red/Blue wire and the brown wire to the compressor, but I learned early in this process not to trust my intuition...
Thanks. |
Tommy Turtle Samba Member
Joined: July 26, 2014 Posts: 8 Location: Camp Hill, PA
Posted: Sat May 13, 2023 7:26 pm Post subject: Re: Bostig AC mod |
Vanagon squad,
Any luck with your Bostig A/C wiring?
I’m about to wire mine, and as you know, concise information is hard to come by.
Tom |
John Sullivan Samba Member
Joined: July 04, 2006 Posts: 178 Location: Lansdale, PA
Posted: Sun May 14, 2023 11:15 am Post subject: Re: Bostig AC mod |
The only wire change is the compressor clutch. The ford compressor similar to the Vanagon compressor has a 2 wire coil for engagement. My 87 Vanagon had a Red/blue wire at the connector (actually 2 wires) and the brown ground wire. The ford compressor on Bostig is on the opposite side to the VW compressor and required an add of about 3 ft of shielded tw/pair with crimped fastons to mate to existing Vanagon connector. I picked up a ford compressor plug with wire off of a 2000-04 ford focus, yellow/green and black wires with connector. I connected the yellow/green to the red/blue (hot) and the black to the brown VW ground via the added 3 ft of cable extension.
Maintain wire size, gauge.
That's the only wire change for the whole job. Should work no problem. |
jimf909 Samba Member
Posted: Sun May 14, 2023 11:29 am Post subject: Re: Bostig AC mod |
This is the plug for the compressor that I bought and used. Ignore the 'kit' part of the title. As I recall it was a plug with two wires that I mated to the VW harness.
https://www.amazon.com/dp/B000IYHEP2/?coliid=IGY4V..._lig_dp_it _________________ - Jim
| Butcher wrote: |
| This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
Posted: Sun May 14, 2023 9:09 pm Post subject: Re: Bostig AC mod |
Thank you gentlemen for replying.
With all the dead links of pictures at the Bostig site, I wanted to clarify the wiring solutions.
I’ve suffered a bit of mission creep, and have purchased everything new, except for the quite pristine evaporator. Motorcraft compressor, EZ Clip hose & fittings etc. You get the idea.
The cleaned and flushed evap, and new exp valve went in today. Condenser & R/D yesterday. Cabinet & serviced fans, and the hose/fittings tomorrow and Tuesday.
I don’t have to be back to work until Saturday, and would love at very least to have a sealed system & be able to draw a vacuum, to see where I stand…possibly even charge it.
From gleaning everything I could online previously, and now with a focus on electrical…
First, does the long red main power wire coming down from the closet go to the alternator post? I’m planning on using a length of 6 gauge I have for this. There’s surprisingly no evidence of prior overheating or melting in the D pillar.
Secondly, the wires from the high & low pressure switches that were in the D pillar originally, will be moved to the Nostalgic Air binary switch located in the new receiver drier. This is following djkeev’s great post on his ‘86 weekender.
I’m unsure how this is ultimately accomplished.
It sounds like I can combine the existing wiring directly to the new two wire binary switch…but I’m unsure which ones and where. Originally it’s Red/blue & red/white on one switch and brown/black & brown/white on the other. Any guidance here would be greatly appreciated.
Lastly the compressor clutch. I bought the Dorman two wire pigtail plug for the FS10 recommend by Jim, it’s getting delivered tomorrow.
Does this merely splice in to the Vanagon’s wiring for clutch engagement?
If I remember correctly, polarity isn’t important.
I’m praying that the switches & wiring up front is ok, but I have the Bentley & a multimeter ready for that last step.
Thanks guys!
Tom
Pchill2 Samba Member
Joined: November 19, 2021 Posts: 410 Location: Georgia
Posted: Mon May 15, 2023 10:39 am Post subject: Re: Bostig AC mod |
The large red wire goes to the alternator.
Why are you going with a binary switch rather than a trinary? Both will work, I'm just curious.
If you are putting the switch on the receiver/drier, you will need to run wires back up into the d-pillar and connect to the factory pressure cutout switch wiring. It does not matter what wire connect to what. They just need to be connected to the two wires that plug into the factory pressure switch connector
I'm not super familiar with the Zetec engine computers but I assume there would be an A/C switch signal required by the ECU to bump the idle so the engine does not bog down when the A/C compressor cycles on. Maybe a Zetec expert can chime in on this. _________________ 87 Syncro Westy
Honda K24 swap |
Posted: Mon May 15, 2023 11:20 am Post subject: Re: Bostig AC mod |
Pchill2,
I went with the binary for two reasons.
One was to mimic the factory (dealer installed I suppose) setup to keep it simple. The binary switch implementation is well documented various places…minus the wiring peculiarities due to dead photo links.
Secondly, it was again to keep it simple, for now. I don’t have the time in this block of days off-11 days, or the rest of summer most likely, to do the wiring for the radiator fan and associated under the dash work etc. to my ridiculous OCD standards.
A trinary is in the future, since I have the manifold gauges, vacuum pump & a six pack of RedTek standing by.
Kind of bass akwards, I know…just a finite amount of time.
FYI the increased idle is handled by using the kit’s included SCT engine scanner/programmer to bump up the idle to 1200, I think, for summertime.
John, thanks for the info! Mine is an ‘87 as well. While we’re on the subject of binaries & trinaries, any words of wisdom, since you’ve been there/done that.
Thanks guys!
Tom |
Posted: Mon May 15, 2023 11:38 am Post subject: Re: Bostig AC mod |
These are pictures of my trinary switch flying leads. Since you are using a binary switch just ignore the blue wires.
You will need to connect the black wires (or whatever color are on your binary switch leads) to Red/Blue and Red/White in your d-pillar and then run your wire to your alternator and you should be good to go. _________________ 87 Syncro Westy
Honda K24 swap |
Posted: Mon Jun 05, 2023 10:22 am Post subject: Re: Bostig AC mod |
Just wanted to thank all who helped this happen for me.
My first foray into A/C, and I couldn’t have done it without the many Samba members. Because of all the knowledgeable help…
My system held a vacuum of -30” for SEVEN DAYS.
It blew 57 degree air on a humid 92 degree day…a 35 degree differential, which I’m quite pleased with.
The cleaned grounds, feed wires, and relays in the D pillar never got hot enough to cause worry. Even on fan speed 3 & 4.
Thanks again!
Tom |
