Current info on low profile battery 6v for Split?
bloomsburyVW
bloomsburyVW is offline
PostPosted: Mon Jun 26, 2023 1:34 pm    Post subject: Current info on low profile battery 6v for Split? Reply with quote
Hello,
I have been looking for a low profile 6v battery for my split (1952).
I am in Canada and the stores, Nappa & Canadian tire, only have an 8.75 inch height battery.
Any recommendations?
I'll have to buy in the USA if necessary.
Thanks.
dmooresc
dmooresc is offline
PostPosted: Mon Jun 26, 2023 4:58 pm    Post subject: Re: Current info on low profile battery 6v for Split? Reply with quote
I believe it would be the same as I run in my stock 1960 beetle: 19L. these are 7.5" tall and available at many locations in the USA. prices have almost doubled in the last few years so expect in the $200 range.
I have typically gotten a decade of life out of mine.
NAPA: Part #: BAT 7217L
best wishes
johnshenry
johnshenry is offline
PostPosted: Tue Jun 27, 2023 6:16 am    Post subject: Re: Current info on low profile battery 6v for Split? Reply with quote
I buy the 19L batteries. Have to call around, getting harder to find, and expensive. Paid $193 for the last one at my local Auto Parts Chain. They had to order it from their main distribution center.
John Henry
'57 Deluxe
'56 Single Cab
c_wilburn
c_wilburn is offline
PostPosted: Tue Jun 27, 2023 7:38 am    Post subject: Re: Current info on low profile battery 6v for Split? Reply with quote
Optima makes a 6v battery that is half as wide as a regular battery and can be mounted sideways. It's also 800cca
#8010-044
1972 Westfalia (Marshmelo)
1952 Beetle (Krampus)
1968 Beetle convertible (Buttercup) (the wife's car)
DrDarby
DrDarby is offline
PostPosted: Tue Jun 27, 2023 8:57 am    Post subject: Re: Current info on low profile battery 6v for Split? Reply with quote
Somebody needs to get creative and make a battery box for the Optima that looks like an old battery!
Midwest Autosavers, Inc. Crystal Lake, IL
finster
finster is offline
PostPosted: Tue Jun 27, 2023 9:16 am    Post subject: Re: Current info on low profile battery 6v for Split? Reply with quote
like this...
finster
finster is offline
PostPosted: Tue Jun 27, 2023 10:33 am    Post subject: Re: Current info on low profile battery 6v for Split? Reply with quote
or this - https://www.tartopper.com/product/optima-six-volt-coming-in-september-2018/
and - https://www.ebay.com/itm/235051591206?nma=true&...7675.l2557
bob hailend
bob hailend is offline
PostPosted: Tue Jul 04, 2023 9:35 am    Post subject: Re: Current info on low profile battery 6v for Split? Reply with quote
I have this one it is NOS and it is ready to go all you have to do is fill it with battery acid give me a call or e mail me. Thanks
615-516-3791
rglsr
rglsr is offline
PostPosted: Wed Aug 09, 2023 1:51 pm    Post subject: Re: Current info on low profile battery 6v for Split? Reply with quote
Man the 19L batteries have become hard to find, and with cost approaching that of an Optima I got motivated. I've always run 19Ls since they are so OG, but need to consider alternates.
I came up with this adapter. The two plastic blocks simulate the size of a 19L battery, so the original battery cover/strap can be used. This one is for an oval window. You also need a longer ground strap, and some sort of terminal covers for the clamps, to prevent shorts. Now on a later beetle with kick panels you're good to go.
Putiting this out there for comments and/or interest...
grailoc
grailoc is offline
PostPosted: Thu Aug 10, 2023 2:46 am    Post subject: Re: Current info on low profile battery 6v for Split? Reply with quote
did you 3d print it ?
My 59 low light ghia: https://www.thesamba.com/vw/forum/viewtopic.php?t=452128
My 56 beetle convertible: http://www.thesamba.com/vw/forum/viewtopic.php?p=7796259
My 60 SO23 westy: http://www.thesamba.com/vw/forum/viewtopic.php?t=341539
My oldspeed 36hp autotechnik express build: https://www.thesamba.com/vw/forum/viewtopic.php?t=670827
My garage build: http://www.garagejournal.com/forum/showthread.php?t=199438
rglsr
rglsr is offline
PostPosted: Thu Aug 10, 2023 3:05 pm    Post subject: Re: Current info on low profile battery 6v for Split? Reply with quote
Yes, these are 3D printed. I also modeled up a simplified version if you wanted to machine/fabricate a set out of solid plastic. They are the same parts upper/lower.
The battery is held in place with features, so it won't slip/shift while driving, sort of like a "saddle" clamp design.
finster
finster is offline
PostPosted: Fri Aug 11, 2023 3:24 am    Post subject: Re: Current info on low profile battery 6v for Split? Reply with quote
a neat and simple idea
sgmalt46
sgmalt46 is offline
PostPosted: Tue Aug 15, 2023 3:29 pm    Post subject: Re: Current info on low profile battery 6v for Split? Reply with quote
cool idea . you can sign me up for one or 2 . Very Happy
Steve
55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG
geneL3c
geneL3c is offline
PostPosted: Wed Nov 13, 2024 9:02 pm    Post subject: Re: Current info on low profile battery 6v for Split? Reply with quote
Recently had to order a 6V battery for a project and tried to get an Interstate 19L which had been spec't at 172mm wide, 227mm long, which converts to 6.77" x 8.94"not sure of height. The 19L is no longer listed and has apparently been superceded by P/N 1-VHD. The newly listed battery measures 9" L, 6 15/16" W, 8 3/4" H. Battery should arrive next week, so I can check fit of cover, which I hope fits, not too many options at this point. Hope this helps those looking for new batteries.
geneL3c
geneL3c is offline
PostPosted: Thu Nov 14, 2024 11:35 pm    Post subject: Re: Current info on low profile battery 6v for Split? Reply with quote
Update on low profile 6v battery for Splits. Advance Auto has a Die Hard 6v 19L battery listed for $192-. Ht - 7.5", W - 6.8", L -8.2". I'm staying with the Interstate battery I ordered since height is not a concern ( no back seat ) and have always had very good luck with Interstate batteries for my other 6v cars.
