Syncro - fuel tank pressure
StefDS
StefDS is offline
PostPosted: Sun Aug 13, 2023 2:13 am    Post subject: Syncro - fuel tank pressure Reply with quote
Hi all,
I've searched for the issue, but I only found 4 topics, all for non syncro vans.
When driving for some time, I noticed that the van always takes a "big breath" when opening the gas cap, which is probably caused by the built-up (negative?) pressure.
I'm trying to find a solution without having to remove the engine/fuel tank for now (will be done in future for other jobs, but still want to drive the van this summer season).
The diagram I found from GoWesty at https://gowesty.com/blogs/schematics/fuel-tank-breather-system-syncro
As there are no pressure tanks like in a non syncro, Is there an easy way to diagnose the problem?
Hose #7 on above diagram is only the overflow I would presume? (as this is easily accessible)
Thanks!
DuncanS
DuncanS is offline
PostPosted: Sun Aug 13, 2023 4:02 am    Post subject: Re: Syncro - fuel tank pressure Reply with quote
You have a plugged vent and can collapse the tank. This should help.
https://www.thesamba.com/vw/forum/viewtopic.php?t=606047
Duncan
MarkWard
MarkWard is offline
PostPosted: Sun Aug 13, 2023 7:12 am    Post subject: Re: Syncro - fuel tank pressure Reply with quote
I could be wrong, but the above diagram is for a diesel. The tell tale to me is the loop of fuel hose in the filler box to atmosphere. Gasoline engines would have had the charcoal canister tied to the vent and purged into the intake. Theory was to contain hydro carbons from venting to atmosphere.
The plastic valves in the top of the tank are normally open. They allow the tank to equalize, but if the van ended upside down, they close by gravity. They are sometimes referred to as roll over valves.
I’d start with the hose connected to the charcoal canister. Find the hose from tank and verify it’s not plugged or crimped. There are a lot of hoses on top of the tank and it’s possible if the tank was in and out, one may be caught between the tank top and the chassis.
DuncanS
DuncanS is offline
PostPosted: Sun Aug 13, 2023 10:03 am    Post subject: Re: Syncro - fuel tank pressure Reply with quote
Bentley 20.34 has a full diagram with descriptions of the parts. Should you have an open vent, one that a wasp can fill up, then you will not be able to pull air into the tank to replace the volume of the fuel used. I have had wasps plug lines and holes in my boat many times. It's very firm and has to be drilled out to open; not just some stuff loosely stuffed in. Bits of sand all glued together with serious wasp glue.
Duncan
DuncanS
DuncanS is offline
PostPosted: Sun Aug 13, 2023 10:30 am    Post subject: Re: Syncro - fuel tank pressure Reply with quote
Hose #7 on above diagram is only the overflow I would presume? !
#7 is the vent used while filling the tank. Air bypasses the fuel nozzle and allows the tank to fill. But once you put the cap back on then that line is sealed as it only goes to the main fuel line, not to the atmosphere all the time. The venting when the gas is being drawn comes by way of the charcoal canister. I would check that line which is #5.
By the way, don't know any of this other than what I could discern from looking at Bentley 20.20 through 20.34. This post could be all hogwash. Others will actually know and they can add or correct this as needed.
And by the way, access to the synchro tank is extremely difficult. You have to remove the tranny. I STRONGLY suggest that you do this:
I have some ½" waterproof ply which closes the hole and takes about 2 minutes to remove and replace. Then the tranny can stay just where it is.
Duncan
termuehlen Premium Member
termuehlen is offline
PostPosted: Sun Aug 13, 2023 6:10 pm    Post subject: Re: Syncro - fuel tank pressure Reply with quote
If you have a charcoal canister, that hose routing looks like this:
The hose coming out of the bottom of the canister is just tucked into the vehicle frame rail (even though it is labeled "to air cleaner") . A properly vented Syncro fuel system should not have any pressure in the fuel system, the bottom of the canister should be open to the atmosphere. You could work your way back through the system to try and find any "blockage".
1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx
StefDS
StefDS is offline
PostPosted: Mon Aug 14, 2023 12:07 am    Post subject: Re: Syncro - fuel tank pressure Reply with quote
Hi all, thanks already a lot for the replies.
Yesterday I did a 50 km (31 miles) trip, and again checked the pressure when releasing the fuel cap, but this time no pressure was built up Confused
Previous 4-5 times i've checked it after a trip there was, so the lines "automagically" cleared up I guess?
Anyway I'll have a look at the charcoal canister and the fuel lines around it to inspect the lines.
Thanks again.
DuncanS
DuncanS is offline
PostPosted: Mon Aug 14, 2023 5:38 am    Post subject: Re: Syncro - fuel tank pressure Reply with quote
StefDS wrote:
...... so the lines "automagically" cleared up I guess?
AH, yes..automagically. I remember hearing about a guy on the Click and Clack show who complained that his car quit and never gave any warning. C & C's response: "What did you expect, a post card?" You have received a post card.
A syncro tank may not collapse because of its shape, but a 2WD definitely can. The fuel pump has enough suction to collapse a tank which isn't venting. https://www.ebay.com/itm/192872399283?chn=ps&_...iYEALw_wcB $775, and it's in Latvia.
Do NOT drive until you sort this out! If it did automagically fix itself, at the very least, it may have sucked the blockage into the tank which may now block any fuel flow. So I'd swap out the fuel filter after you get it all properly under control .
Duncan AKA Mr. Bad Tidings
joetiger Premium Member
joetiger is offline
PostPosted: Mon Aug 14, 2023 7:30 am    Post subject: Re: Syncro - fuel tank pressure Reply with quote
I had the same ongoing problem with my Syncro. All my fuel lines and valves were new. In extreme heat, gasoline would even force itself out of the fill port.
I replaced the charcoal canister and that fixed it.
https://vancafe.com/evaporative-emission-canister/
Joe T.
'02 Baja-ish Beetle "Bubbles"
StefDS
StefDS is offline
PostPosted: Tue May 20, 2025 2:34 pm    Post subject: Re: Syncro - fuel tank pressure Reply with quote
Well, I finally got around on dropping the engine & transmission to get to the fuel tank. After reading all the horror stories it went fairly smooth (the actual dropping of the tank only took 15 minutes)..
But I guess it was taken out by a previous owner because the 2 plastic vents on top are missing and a lot of black silicone is used to plug the holes.. I can only presume the PO broke the vents off when dropping the tank, and they were not available new at the time..
Tomorrow I'll do some dissection of the silicone and hope the 2 holes are not damages, so I can put some proper vents in..
Picture of the top of the fuel tank, with the 2 vents missing (the 2 plastic knobs that hold the fuel lines lines are also broken off):
4Gears4Tires
4Gears4Tires is offline
PostPosted: Thu May 22, 2025 9:22 am    Post subject: Re: Syncro - fuel tank pressure Reply with quote
How did your van run right? Eventually there will be a negative pressure and it will reduce fuel flow to the motor?
Sodo
Sodo is offline
PostPosted: Fri May 23, 2025 7:09 am    Post subject: Re: Syncro - fuel tank pressure Reply with quote
Strange that your tank came out in 15 minutes. Was it “dry”?
Mine was such a fight that I’d never want to do it again.
Maybe some tanks are bigger, some vans are bigger.
Its feasible that a new tank is smaller, then it “grows a little“ the first time you put gas in it. Then after the tank is empty, and aired out for awhile, does it shrink a little?
Anyway, if you have trouble, plug a shopvac in and vacuum physically shrinks the tank size.
https://www.thesamba.com/vw/forum/viewtopic.php?p=10351785
'87 Tintop, EJ25, cooled filtered (original) gearbox
....KTMs, GasGas, SPOT mtb
All Vanagons should do this:
Add direct starter-to-chassis cable THEN delete ground strap at front transaxle mount.
The best time to do this mod was in 2010. The second best time is TODAY.
If your starter is slow, this is MORE important.
