Do Bug Seats fit in a Ghia?
HandsomeGhia67
HandsomeGhia67 is offline
PostPosted: Thu Aug 24, 2023 8:17 am    Post subject: Do Bug Seats fit in a Ghia? Reply with quote
Until I find the illusive 1967 Karmann Ghia seats I need something to put into my Ghia. I was wondering if Bug seats and rails fit in my car? The car currently has not seats or rails.
Thank Guy!!!! Much Appreciated!
Braukuche
Braukuche is offline
PostPosted: Thu Aug 24, 2023 8:41 am    Post subject: Re: Do Bug Seats fit in a Ghia? Reply with quote
No, but seats are way to narrow. You’d have to weld tracks in twice which makes no sense.
‘67 seats are only one year in the sense that they had this ridiculous mechanism for releasing the seat back. You can use any Ghia low back or even 68 high back Ghia seats on your current tracks.
Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia
HandsomeGhia67
PostPosted: Thu Aug 24, 2023 8:43 am    Post subject: Re: Do Bug Seats fit in a Ghia? Reply with quote
Replacing the rails twice is not a big deal. My brother is a welder so I have no labor costs🤣
Braukuche
PostPosted: Thu Aug 24, 2023 8:45 am    Post subject: Re: Do Bug Seats fit in a Ghia? Reply with quote
They likely would fit then, but they are much narrower, you have to position the rails right or you will be sitting cockeyed.
Retirement is here!
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
1989 Westfalia
Era Vulgaris
Era Vulgaris is offline
PostPosted: Thu Aug 24, 2023 9:07 am    Post subject: Re: Do Bug Seats fit in a Ghia? Reply with quote
Welding in rails for beetle seats, that will later be removed, seems like alot of extra unnecessary work when 56-68 Ghia seats will fit the seat tracks for your 67. Not to mention that the Beetle seats won't feel right in a Ghia. Not only are they narrower, but I'm pretty sure they're quite a bit taller, so your head might be bouncing off the headliner.
Here's some 64 seats that will fit your 67 perfectly
https://www.thesamba.com/vw/classifieds/detail.php?id=2495135
Unless you're planning on re-creating the rube-goldberg cable mechanism that 67 had attached to its seats, I would buy these and re-cover them for your car. The frames are otherwise the same.
Also, the search function is helpful Wink
https://www.thesamba.com/vw/forum/search.php?searc..._chars=200
Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Thu Aug 24, 2023 9:14 am    Post subject: Re: Do Bug Seats fit in a Ghia? Reply with quote
You might get bug seats to fit in the Ghia, but YOU sure as hell wouldn’t fit in the Ghia once they were. Laughing
John Moxon Premium Member
John Moxon is offline
PostPosted: Thu Aug 24, 2023 9:53 am    Post subject: Re: Do Bug Seats fit in a Ghia? Reply with quote
Yep if IRCC they sit a lot higher than Ghia seats.
John.
HandsomeGhia67
PostPosted: Thu Aug 24, 2023 11:34 am    Post subject: Re: Do Bug Seats fit in a Ghia? Reply with quote
Thanks for all the info guys! I didn't think about the height difference and being 6'4" it matters!
What are your thoughts on the Pro 90 seats from Scat VW? They make them for the 67 Ghia so i'm assuming the brackets are shorter than the ones for a bug.
https://scatvw.com/product/beige-vinyl-left-2/
PostPosted: Thu Aug 24, 2023 12:17 pm    Post subject: Re: Do Bug Seats fit in a Ghia? Reply with quote
There is a whole host of good alternatives, you'll find the topics on the subject in the "How To" stickies at the head of the Ghia section...
Here's a few:
Alternative Seat Options-1
Alternative Seat Options-2
Alternative Seat Options-3
John.
myghiarocks
myghiarocks is offline
PostPosted: Thu Aug 24, 2023 3:36 pm    Post subject: Re: Do Bug Seats fit in a Ghia? Reply with quote
I put the Scat seats in my Ghia. I really like them. very comfortable
HandsomeGhia67
PostPosted: Thu Aug 24, 2023 5:15 pm    Post subject: Re: Do Bug Seats fit in a Ghia? Reply with quote
That's great to hear! I just ordered a set with the Ghia adapters.
