What are these weird bags?
MrKawfey
MrKawfey is offline
PostPosted: Thu Aug 24, 2023 7:21 am    Post subject: What are these weird bags? Reply with quote
I found these strange pouches in my convertible when doing some work. I don't have a clue what they are or what they are for. They look like they might be made from headliner material turned inside out and they are filled with fluff that looks similar to the insulation used around the heat duct mufflers.
There was one on each side, under the area where the convertible top hinge mechanisms fold.
Any ideas what these might be? Are they factory? Maybe to absorb leaking water?
1971 Ghia Convertible Auto-stick
Braukuche
Braukuche is offline
PostPosted: Thu Aug 24, 2023 8:41 am    Post subject: Re: What are these weird bags? Reply with quote
Sound insulation.
Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia
MrKawfey
MrKawfey is offline
PostPosted: Thu Aug 24, 2023 10:28 am    Post subject: Re: What are these weird bags? Reply with quote
Really? They are only about 6-8" tall and 3" thick.
I found them laying on the "floor" behind and to the sides of the rear seat area. Is this where they were originally placed? Or did they fall there from somewhere else?
tri356
tri356 is offline
PostPosted: Thu Aug 24, 2023 11:51 am    Post subject: Re: What are these weird bags? Reply with quote
Take a look at this thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=629547&highlight=socks
and here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=720003&highlight=pillow
and you'll get a better idea of where they came from. It seems that there could be two sets of these small-ish types of bags/pillows, one underneath the rear seat bottom and the other set "Stuffed back over the wheel wells from the inside all the way back. "
Mike
Starbucket
Starbucket is offline
PostPosted: Thu Aug 24, 2023 3:44 pm    Post subject: Re: What are these weird bags? Reply with quote
Look like the padding that goes next to the rear window sides.
