CimminoBrothers Samba Member
Joined: September 28, 2023 Posts: 15 Location: SW Florida
Posted: Fri Sep 29, 2023 6:13 am Post subject: 72 Beetle Rear Wheels Locked |
I’ve had this 72VW Beetle “Baja” for 20+ years and it’s been sitting around as a project that I’m finally getting time for. Here’s the issue… while trying to see if my reverse switch worked, I was shifting through the gears trying to get it into reverse. Once It shifted into reverse, at least I believe it’s in reverse, the wheels locked up. I can’t even move it an inch. The shifter still moves through the gears and they seem fine. I have also replaced all the brake lines and currently there is no fluid in them. The parking brake is disengaged. What are your suggestions? |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4176 Location: Georgia
Posted: Fri Sep 29, 2023 6:27 am Post subject: Re: 72 Beetle Rear Wheels Locked |
Pull the wheels and drums to see if it’s just rust. Once off put it in neutral and see if the axles will turn. _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Fri Sep 29, 2023 11:37 am Post subject: Re: 72 Beetle Rear Wheels Locked |
Just prior to me trying to shift it into Reverse I was pushing it in and out of my garage. I know it’s not rusty brakes. Is almost feels like there’s a pin stopping it from moving or like it’s stuck in gear |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11269 Location: Oregon
Posted: Fri Sep 29, 2023 1:48 pm Post subject: Re: 72 Beetle Rear Wheels Locked |
Jeffrey,
I AM SORRY MAN!!!
I put it up on jack stands and pulled the wheels. With a little brute strength the passenger side broke free and was spinning easily. I tried the same on the drivers side with no luck so I decided to pull the drum off and while doing so it broke free. I cleaned the dirt/grim/rust out and now it’s spinning freely.
Thanks Brother! |
