72 Beetle Rear Wheels Locked
CimminoBrothers
CimminoBrothers is offline
PostPosted: Fri Sep 29, 2023 6:13 am    Post subject: 72 Beetle Rear Wheels Locked Reply with quote
I’ve had this 72VW Beetle “Baja” for 20+ years and it’s been sitting around as a project that I’m finally getting time for. Here’s the issue… while trying to see if my reverse switch worked, I was shifting through the gears trying to get it into reverse. Once It shifted into reverse, at least I believe it’s in reverse, the wheels locked up. I can’t even move it an inch. The shifter still moves through the gears and they seem fine. I have also replaced all the brake lines and currently there is no fluid in them. The parking brake is disengaged. What are your suggestions?
jeffrey8164
jeffrey8164 is offline
PostPosted: Fri Sep 29, 2023 6:27 am    Post subject: Re: 72 Beetle Rear Wheels Locked Reply with quote
Pull the wheels and drums to see if it’s just rust. Once off put it in neutral and see if the axles will turn.
Volkswagen!
(Compression 8.7:1)
CimminoBrothers
PostPosted: Fri Sep 29, 2023 11:37 am    Post subject: Re: 72 Beetle Rear Wheels Locked Reply with quote
Just prior to me trying to shift it into Reverse I was pushing it in and out of my garage. I know it’s not rusty brakes. Is almost feels like there’s a pin stopping it from moving or like it’s stuck in gear
67rustavenger
67rustavenger is online now
PostPosted: Fri Sep 29, 2023 1:13 pm    Post subject: Re: 72 Beetle Rear Wheels Locked Reply with quote
When the clutch pedal is depressed. Will the car roll?
One of my 67's from time to time, gets stuck in second gear.
https://www.thesamba.com/vw/forum/viewtopic.php?t=705081&highlight=stuck
https://www.thesamba.com/vw/forum/viewtopic.php?t=781293&highlight=stuck
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
CimminoBrothers
PostPosted: Fri Sep 29, 2023 1:48 pm    Post subject: Re: 72 Beetle Rear Wheels Locked Reply with quote
Jeffrey,
I AM SORRY MAN!!!
I put it up on jack stands and pulled the wheels. With a little brute strength the passenger side broke free and was spinning easily. I tried the same on the drivers side with no luck so I decided to pull the drum off and while doing so it broke free. I cleaned the dirt/grim/rust out and now it’s spinning freely.
Thanks Brother!
