Finally passed smog
Clark Addison
Clark Addison is offline
PostPosted: Mon Oct 02, 2023 8:34 am    Post subject: Finally passed smog Reply with quote
Our 1989 Vanagon 2.1 L finally passed California smog inspection after flunking last month. All it took was a new catalytic converter. Just under $1000.
MarkWard
MarkWard is offline
PostPosted: Mon Oct 02, 2023 8:57 am    Post subject: Re: Finally passed smog Reply with quote
Congrats. I was wondering about California. Are they imposing emissions that the Vanagon would not have had to meet when new. In those days, we measured HC and CO before the cat. I recall the manual only lists CO for adjusting. Just curious.
fxr
fxr is offline
PostPosted: Mon Oct 02, 2023 9:25 am    Post subject: Re: Finally passed smog Reply with quote
Just the original emissions.
Jim Crowther
Vespa GTS 300
zerotofifty
zerotofifty is offline
PostPosted: Mon Oct 02, 2023 10:58 am    Post subject: Re: Finally passed smog Reply with quote
The test now days in much of california is considerably more stringent than it was years ago for the vanagon. It is now much more difficult to pass.
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
zerotofifty
PostPosted: Mon Oct 02, 2023 11:01 am    Post subject: Re: Finally passed smog Reply with quote
You should have a new oxygen sensor to go with the new catalyst. as a defective, or what is known as a "lazy" sensor can lead to damage of that pricey catalyst. Passing the test does not assure the sensor is at optimal performance, and less than optimal can quickly ruin a new catalyst. Protect that $1000 catalyst, get a new sensor often.
Words to live by.
fxr
fxr is offline
PostPosted: Mon Oct 02, 2023 12:56 pm    Post subject: Re: Finally passed smog Reply with quote
It's still the original specification emissions they test for. They also test the gas system for zero venting (they block off the evap crap) by fitting an adapter instead of the gas cap and then pressurise the system to a few psi and wait for some minutes - there must be no loss of pressure. The whole test for the van takes quite a long time, and costs way more than a modern sedan. Sad
Jim Crowther
Vespa GTS 300
Mateo83
Mateo83 is offline
PostPosted: Mon Oct 02, 2023 1:10 pm    Post subject: Re: Finally passed smog Reply with quote
Most kids working at the smog shops don't even know how to drive a stick or what and e brake is. Shocked
83 Air-cooled 2.0 Tin Top
