MarkWard Samba Member
Joined: February 09, 2005 Posts: 19010 Location: Retired South Florida
Posted: Wed Nov 01, 2023 8:46 am Post subject: Re: How to know it’s time time for a tranny rebuild? |
| The 091 4 speed is about an inch and a half shorter than the 091/1 4 speed. Don’t have the measurement you seek, but wanted to point that out since the packed one above is from description an 091 4 speed. |
steve244 Samba Member
WillRB Samba Member
Posted: Fri Nov 03, 2023 1:49 pm Post subject: Re: How to know it’s time time for a tranny rebuild? |
Have everything removed including the starter bolt but struggling to get transmission to release from engine studs. Have an adapter plate (2.2 Subuaru). Any tips? I have removed motor but never transaxle. Would some gentle prying between adapter plate and transmission case be out of line? _________________ 1984 Vanagon Westfalia w/ Subaru Conversion (99 Legacy 2.2 Phase II) 2WD 4speed 4.57 R/P (.828 straight cut 4th) GT TBD |
Posted: Fri Nov 03, 2023 2:18 pm Post subject: Re: How to know it’s time time for a tranny rebuild? |
| Gentle pressure would be ok I believe. There is likely a register on the adapter plate for the bell housing, dowels, or something to index it square that could be sticking. |
WillRB Samba Member
Posted: Fri Nov 03, 2023 2:26 pm Post subject: Re: How to know it’s time time for a tranny rebuild? |
I don’t need to loosen the engine carrier (RMW) at all do I? _________________ 1984 Vanagon Westfalia w/ Subaru Conversion (99 Legacy 2.2 Phase II) 2WD 4speed 4.57 R/P (.828 straight cut 4th) GT TBD |
Posted: Fri Nov 03, 2023 2:32 pm Post subject: Re: How to know it’s time time for a tranny rebuild? |
I do not know the answer to that question. Do you recall if the adapter plate was attached to the engine case and then the flywheel installed? For the adapter plate to unbolt from the engine, it would need to be able to pass over the flywheel. That would not leave much meat for the adapter. Might want to start another thread to get better response.
edit, mis read your last post. I don't see a problem loosening the engine carrier if it gives you more droop on the transmission end. You need to be able to clear the chassis with the nose of the transmission. I usually remove the complete transmission bracket to gain more room. |
WillRB Samba Member
Posted: Fri Nov 03, 2023 2:53 pm Post subject: Re: How to know it’s time time for a tranny rebuild? |
| MarkWard wrote: |
Thanks i went ahead and started a new thread, but did go ahead and remove the mounting bracket so i dont have to mess with clearance. _________________ 1984 Vanagon Westfalia w/ Subaru Conversion (99 Legacy 2.2 Phase II) 2WD 4speed 4.57 R/P (.828 straight cut 4th) GT TBD |
WillRB Samba Member
Posted: Sat Nov 18, 2023 6:38 pm Post subject: Re: How to know it’s time time for a tranny rebuild? |
Well a bit of an update. Not ideal news on my transaxle teardown at builder. Ring and pinion damaged. Potentially a couple other issues. Turns out someone had “hodgepodged” together the transaxle at some point. 4.83 r&p, 2 spider gear diff, with aluminum case. All on my 84 westy. I guess its good that it was discovered as part of a rebuild not after a breakdown across the country..
Might be needing to locate another core. Leads welcome..
Sodo Samba Member
Joined: July 06, 2007 Posts: 10762 Location: Western WA
Posted: Sat Nov 18, 2023 6:47 pm Post subject: Re: How to know it’s time time for a tranny rebuild? |
Bummer about the R&P.
Thass why I say keep clean oil in it.
Theres no economy in running contaminated gear oil longer when clean oil is only $30.
Especially in an old trans that may have an old gear or 2 ready to start shedding steel into the oil at any time.
Well at least you have an Aluminum case!!
Those are hard to find.
Big engine fellers be envious.
Good thing you didn’t “exchange” it away.
I just saw a video where an aussie guy used a compressed air nozzle to force oil out of a soda bottle, up a tube into a gearbox.
It looked like a great DIY trick. _________________
....KTMs, GasGas, SPOT mtb |
WillRB Samba Member
Posted: Sat Nov 18, 2023 7:02 pm Post subject: Re: How to know it’s time time for a tranny rebuild? |
| Sodo wrote: |
It looked like a great DIY trick. |
Yep. I have actually changed the oil twice at 6-7k mile intervals in the time I have owned the van. Obviously have no history on the transaxle before me. When i drained to ship I felt like the gear oil looked a tad more sparkly than the other times I had dropped it. Magnet didn’t look super awful, but had a bad feeling. _________________ 1984 Vanagon Westfalia w/ Subaru Conversion (99 Legacy 2.2 Phase II) 2WD 4speed 4.57 R/P (.828 straight cut 4th) GT TBD |
E1 Samba Member
Joined: January 21, 2013 Posts: 8560 Location: Westfalia, Earth
Posted: Sat Nov 18, 2023 7:08 pm Post subject: Re: How to know it’s time time for a tranny rebuild? |
I’d personally trust any core that Arizona Transaxle or Mr. Gas had approved for rebuild. They worked long and hard to build reputations that wouldn’t be worth risking for a few hundred bucks.
I can’t comment on other builders, but myself would in general trust their judgment over buying a completely-unknown core, especially from a private party without personal knowledge of them.
Builders not only know what they’re looking at that a private party isn’t likely to, but the last thing a builder would need is rebuilding on a bad core just to have it come back for warranty. _________________ If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans |
zerotofifty Samba Member
Posted: Mon Nov 20, 2023 10:18 am Post subject: Re: How to know it’s time time for a tranny rebuild? |
Here is a nice little video on tranny synchronizers you all may enjoy.. Even has strobe light action video!
https://m.youtube.com/watch?v=e-Lk3FXHubw _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
E1 Samba Member
Posted: Tue Nov 21, 2023 3:26 pm Post subject: Re: How to know it’s time time for a tranny rebuild? |
Great video, Thanks! _________________ If ever twice as rich, we’re gettin’ a double-wide
