Dual Mass Flywheel Autopsy
syncroserge
syncroserge is offline
PostPosted: Thu Nov 30, 2023 2:43 pm    Post subject: Dual Mass Flywheel Autopsy Reply with quote
Autopsy might be too strong a word..I did not look for a smoking gun, just thought I would share..
Anyways that's what happens when you leave dead parts around a man with a grinder and some spare time Cool
Before..
Friction surface removed..
Ring gear assembly removed..Wo..that's a lot of springs..spacers between springs are plastic
All that you see or seem is but a spring within a spring..within a spring..
Feels like something interesting inside the core..
Indeed..two little gears are nylon..
Cool
DanHoug
DanHoug is offline
PostPosted: Thu Nov 30, 2023 2:45 pm    Post subject: Re: Dual Mass Flywheel Autopsy Reply with quote
very cool!!!
-dan
www.thefixitworkshop.com
Sodo
Sodo is offline
PostPosted: Thu Nov 30, 2023 6:08 pm    Post subject: Re: Dual Mass Flywheel Autopsy Reply with quote
Awesome.
Thats a lot of monkeybusiness.
How is all that stuff lubed?
How was it 'dead' ?
....KTMs, GasGas, SPOT mtb
skills@eurocarsplus
Samba Peckerhead
PostPosted: Thu Nov 30, 2023 6:19 pm    Post subject: Re: Dual Mass Flywheel Autopsy Reply with quote
Sodo wrote:
How was it 'dead' ?
they chatter and (i'm gonna fuck this up) they get play in the "face" where the disc contacts. basically the "face" wobbles.
When I have seen these fail, it's usually for noise more than anything.
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
syncroserge
PostPosted: Thu Nov 30, 2023 6:22 pm    Post subject: Re: Dual Mass Flywheel Autopsy Reply with quote
Sodo wrote:
Awesome.
How was it 'dead' ?
It was making the usual "handful of nuts in a coffee can" noise of when they fail.
A lot more rotational play than a good one.
The spring assembly and the core with the small gears are generously filled with grease.
Appears to me to be thick molly type.
Sodo
Sodo is offline
PostPosted: Thu Nov 30, 2023 6:27 pm    Post subject: Re: Dual Mass Flywheel Autopsy Reply with quote
syncroserge wrote:
Sodo wrote:
Awesome.
How was it 'dead' ?
So they can't be opened/cleaned/maintained?
I wonder if you could drill some holes and shove all the old grease out, then weld up the holes?
syncroserge
skills@eurocarsplus wrote:
Sodo wrote:
How was it 'dead' ?
Exactly..they are suppose to fail in a way that gets you home i.e. the little plastic spacers
contact one another and allow it to be usable but it makes quite a ruckus !
syncroserge
PostPosted: Thu Nov 30, 2023 6:34 pm    Post subject: Re: Dual Mass Flywheel Autopsy Reply with quote
No, it's all riveted and crimped together.
VW had some issues in the beginning with a lot of failures but supposedly re-engineered it.
Issues were with Sachs and not LUK from memory, but not certain.
jimf909
jimf909 is offline
PostPosted: Thu Nov 30, 2023 6:45 pm    Post subject: Re: Dual Mass Flywheel Autopsy Reply with quote
I had no idea. I just assumed they were heavier.
Is this a three-phase bent spring DMF? It looks like it matches the wikipedia description:
https://en.wikipedia.org/wiki/Dual-mass_flywheel
Three-phase bent spring
This curved spring consists of an outer and two inner arc springs with different elastic characteristics connected in series. This category of bent spring uses the two concepts together: parallel and series connection in order to ensure optimal torsional compensation for each value of torque.
- Jim
Butcher wrote:
Guilty as charged.
Sodo
Sodo is offline
PostPosted: Thu Nov 30, 2023 7:04 pm    Post subject: Re: Dual Mass Flywheel Autopsy Reply with quote
Plastic fails?
Where in your pics - are the 'failed' components visible?
AndyBees
AndyBees is offline
PostPosted: Thu Nov 30, 2023 7:58 pm    Post subject: Re: Dual Mass Flywheel Autopsy Reply with quote
Syncroserge, thanks for your free time and sharing your work.
The DMF is a wear item just about like all the other components of a vehicle. As the miles roll up, the backward-forward "play" between the two halves increases. At what point a DMF begins to make noise, I have no clue.
I preemptively replaced the DMF in my 2000 Jetta at 291k miles while I was doing other major maintenance. It was not making any noise. The one in it now has about 100k miles on it and is quiet (my son owns it).
The DMF in my 03 Jetta TDI has over 275k miles on it. No noise.
I've changed a good number of them in TDIs and a couple in BMWs.. all were high mileage.
I installed a DMF in my 84 Vanagon with the ALH engine ....... no more rattling noise at idle in neutral and no more beating the hell out of the transmission. Shifting gears is very smooth.
'84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Thu Nov 30, 2023 8:17 pm    Post subject: Re: Dual Mass Flywheel Autopsy Reply with quote
The DMF is a wear item just about like all the other components of a vehicle. .
yes, thanks for cutting it open! I have seen them "windowed" in training sessions.
would also like to add... they are impossible to machine like a traditional flywheel. you can't stabilize the face to cut them
so basically, it's suicide to do a clutch and not replace the flywheel at the same time
and to derail things, because why not? check out this carnage.
kid took his parents S60R for a rip and wanted to know what happened when you went from 6th to 1st on the highway at 129 mph:
Sorry for the shitty pix....
the answer is you fucking destroy everything Laughing
that was a 13k bill.
Jake Raby wrote:
Brian wrote:
