SCP_Austin Samba Member
Joined: November 04, 2009 Posts: 372 Location: Tacoma, WA
Posted: Fri Dec 22, 2023 7:37 pm Post subject: Wilwood Front Disc Brake Kit: Vanagon |
As the team at SCP continues to drive new product development, we are excited to announce our Wilwood Front Disc Brake Kit. These are 4 piston calipers with improved stopping power from our brake it and any of the other kits on the market.
https://smallcar.com/wilwood-front-disc-brake-kit-vanagon/
As Vanagon users, we are always looking for ways to improve, upgrade, explore what is possible. We have a rear kit coming in the next month to round out our performance brakes.
Fitment note:
-works with many 15" wheels (please post your fitment confirmations in the comments here!!)
-we offer a SCP upgrade version for existing G60 style customers
Thank you for the support!
Austin
_________________ #leftlanelife |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10934 Location: Western WA
Posted: Fri Dec 22, 2023 10:41 pm Post subject: Re: Wilwood Front Disc Brake Kit: Vanagon |
That's nice!
I have Smallcar front and rear brakes from 2009 and am curious about the caliper upgrade kit: https://smallcar.com/wilwood-caliper-upgrade-kit-vanagon/
| Quote: |
| We have a rear kit coming in the next month to round out our performance brakes. |
I need a rear disc brake with a parking brake that will hold a 5,000 lb van.
Not just when the pads are new & hairy, but even after 10,000 miles.
That's kinda difficult with a cable-operated disc brake and I am hopeful !
Also need a motion sensing alarm that screams at me if I drive off with the parking brake pulled.
See I don't have high confidence in the stopping power of a rear disc parking brake.
....but it's possible to hold the van parked, right?
This alarm that i want doesn't have to be tied to the vehicle speed - it can sense any van motion while the parking brake light is on.
Curious what that crooked finger feller thinks about that.  _________________
'87 Tintop, EJ25, cooled filtered (original) gearbox
....KTMs, GasGas, SPOT mtb
All Vanagons should do this:
Add direct starter-to-chassis cable THEN delete ground strap at front transaxle mount.
The best time to do this mod was in 2010. The second best time is TODAY.
If your starter is slow, this is MORE important. |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1789 Location: Victoria,B.C.Canada
Posted: Sat Dec 23, 2023 12:53 am Post subject: Re: Wilwood Front Disc Brake Kit: Vanagon |
| I know what you mean by driving off with the handbrake on. Maybe something simple like signs "Is your handbrake off" Also "Is your anti-theft switch off ". After a while it should become innate. I wonder if that's how I get a nice gouge in the rotor? |
0cean Samba Member
Joined: February 29, 2012 Posts: 1153 Location: California
Posted: Sat Dec 23, 2023 5:00 am Post subject: Re: Wilwood Front Disc Brake Kit: Vanagon |
This looks like the same kit boxeer was selling a couple years ago. I did all the research and had all the part numbers for this wilwood conversion somewhere, need to find it. Its a good vanagon option and really easy to change the pads. _________________ I'm not a mechanic, I just play one on the internet
Cluster Rebuild:
http://www.thesamba.com/vw/forum/viewtopic.php?t=569920&highlight=
Left for Dead the Resurrection Story Build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=613669
(Number of Different Donor VW Vans Body Parts Used: 12)
(Number of completely different vehicles parts used: 3) |
E1 Samba Member
Joined: January 21, 2013 Posts: 8896 Location: Westfalia, Earth
Posted: Sat Dec 23, 2023 5:14 am Post subject: Re: Wilwood Front Disc Brake Kit: Vanagon |
| wesitarz wrote: |
This is similar to what drivers do in racing. There’s enough to focus on that sometimes one thought goes “Poof” as soon as the starter cranks.
One common one is “New pads” to remind you need a few laps to scuff the brakes in. _________________ If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
The caveman’s first question to the headhunter: “Hey, you got any coffee?” |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32987 Location: Reading Pennsylvania
RGS Paul Samba Member
Joined: April 20, 2007 Posts: 692 Location: Los Alamos, NM
Posted: Sat Dec 23, 2023 7:40 am Post subject: Re: Wilwood Front Disc Brake Kit: Vanagon |
It's not like getting quality parts for the stock system is particularly easy these days. They way I approached it was that the aftermarket kits that are out there have good support now and I can't predict availability of any particular replacement part more than a decade out. If the kits I installed get me through the next 10-15 years before becoming obsolete there will probably be new kits on the market then. Replacing the entire brake system every decade and a half doesn't sound like too high a cost to me.
Paul _________________ '87 Syncro 7-Pass. Adventure Touring Vehicle
"Simplicate, then add lightness." Colin Chapman |
vanagondan Samba Member
Posted: Sat Dec 23, 2023 10:34 am Post subject: Re: Wilwood Front Disc Brake Kit: Vanagon |
| Sodo wrote: |
That's nice!
| Quote: |
Curious what that crooked finger feller thinks about that.  |
I’m the engineer working on the rear brake kit. I’ll keep the alarm request in mind. I’ve got a couple ideas that would be simply to implement. The upgrade kit will be a great option for you. I have not tested the wilwood fronts with the furling style rears yet though. I will soon. You’ll need an adjustable proportioning valve to get optimal performance. In the next weeks I’ll complete testing and have info on the site for setting the proportioning valve appropriately. |
Posted: Sat Dec 23, 2023 10:38 am Post subject: Re: Wilwood Front Disc Brake Kit: Vanagon |
| djkeev wrote: |
My concern about the brake kits is more into the future.....
The point will come that you need new rotors or brake pads.
Whose? What do you order? From where?
We've already seen older brake mods go the way of the dodo bird..... it is only a matter of time before this one does too.
Instead of buys pads ..... you need to buy the latest brake mod kit?
Maybe the owner who installed the kit will know the parts source, but what about the next or two or three owners into the future? |
The beauty of this kit is that all the wear parts are readily available from us, Wilwood, and other sellers. Calipers and pads are Wilwood, rotors can be sourced through SCP but could easily be found elsewhere, hoses are manufactured by SCP but could be replaced by VW hoses or through SCP, the hubs and bracket are made by SCP but will outlast the van. |
Posted: Sat Dec 23, 2023 10:56 am Post subject: Re: Wilwood Front Disc Brake Kit: Vanagon |
I hear the rear e-brake issue come up quite a lot, but I think you guys are getting us confused with our competitors. Our e-brakes work on all kits.
"What about replacement parts?"
This comment comes up a lot. We have done our best to future proof this by manufacturing hubs, brakes lines, and we have rotors made to our specification. Pads and calipers are from Wilwood who is a major player in aftermarket brakes as well. VW Stock left side calipers went out of stock nationally this fall, and we are now in a world where aftermarket parts will start to take over the "stock" replacement parts as they go the way of the Dodo.
We will continue to work hard to bring value to the community and innovate in ways that make a difference. _________________ #leftlanelife |
RoryGirl Samba Member
Joined: October 14, 2016 Posts: 1018 Location: WestWorld Nanaimo BC
Posted: Sat Dec 23, 2023 1:09 pm Post subject: Re: Wilwood Front Disc Brake Kit: Vanagon |
| djkeev wrote: |
| Forgive my ignorance, but Ive never heard of Willwood until I read this thread....... |
SCM Samba Member
Joined: January 26, 2011 Posts: 3483 Location: Bozeman MT
Posted: Sat Dec 23, 2023 4:51 pm Post subject: Re: Wilwood Front Disc Brake Kit: Vanagon |
| djkeev wrote: |
| RoryGirl wrote: |
| djkeev wrote: |
Yeah…… probably.
Just out of touch with the aftermarket market. Mainly because the market just makes me yawn……. |
Jay Leno has said he uses Willwoods on all of his resto modded cars ( but maybe you don’t know about him or his extensive car collection). They’re something of a gold standard. If OE calipers are disappearing this option is pretty good news. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
skemems Samba Member
Joined: February 23, 2017 Posts: 254 Location: Oregon
Posted: Sat Dec 23, 2023 9:36 pm Post subject: Re: Wilwood Front Disc Brake Kit: Vanagon |
This looks like a solid option especially using wilwood calipers. Nice work!
My only questions is it seems in the photos that the wilwood calipers used are not quite deep enough to maximize the surface area of the rotor. If these are 288mm rotors I would I think you would want to maximize that surface area.
Whats the measurement between the caliper and usable rotor surface?
_________________ 87 VW Westfalia - EJ25
86 VW Westfalia - EJ22
85 VW Westfalia - WBX 2.1 project |
vik Samba Member
Joined: January 13, 2005 Posts: 240 Location: back in Czech
Posted: Sun Dec 24, 2023 4:47 am Post subject: Re: Wilwood Front Disc Brake Kit: Vanagon |
Wilwood - great idea.
Caliper depth - could this be that SCP used smaller calipers to allow use of 15¨ rims? They seem to be one of the smaller calipers Wilwood offers.
On the other hand - 8 piston carbon-ceramic might be overkill _________________ T3 Syncro camper in progress |
Silverghost500 Samba Member
Joined: August 01, 2018 Posts: 1198 Location: Atlanta, GA
Posted: Sun Dec 24, 2023 7:51 am Post subject: Re: Wilwood Front Disc Brake Kit: Vanagon |
Wilwood is a very good aftermarket brake component vendor. I'm glad to see this kit's availability!
Perhaps Wilwood has a brake booster that might work for the Vanagon platform too. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
Honda K24A conversion
3-Speed Automatic
Von Westy YouTube Channel
https://www.youtube.com/channel/UCbhyZYxJEQrUuLnMbLleeIA |
tdivan82 Samba Member
Posted: Sun Dec 24, 2023 9:12 am Post subject: Re: Wilwood Front Disc Brake Kit: Vanagon |
Wilwood is top shelf stuff. Certainly more performant than a floating caliper. Easier to service too. Pads are likely available through any local motorsport shop. _________________ 82 Westy TDI (ahu) = 70 mph uphill + 28 mpg
See my Classified ads for some super deals on Diesel Vanagon parts! |
ledogboy Samba Member
Joined: September 19, 2005 Posts: 608 Location: Scappoose, OR / Oakland, CA
Posted: Sun Dec 24, 2023 11:19 am Post subject: Re: Wilwood Front Disc Brake Kit: Vanagon |
| Silverghost500 wrote: |
Perhaps Wilwood has a brake booster that might work for the Vanagon platform too. |
Fantastic idea! _________________ 1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice... |
0cean Samba Member
Posted: Sun Dec 24, 2023 11:28 am Post subject: Re: Wilwood Front Disc Brake Kit: Vanagon |
If i remember from my reseach, the brake pads can be removed without removing the full caliper. That is a huge pluse in my book. Dont know if its the same with the claipers shown. _________________ I'm not a mechanic, I just play one on the internet
Cluster Rebuild:
