Alaninin Samba Member
Joined: December 04, 2023 Posts: 19 Location: Indiana
Posted: Sun Dec 24, 2023 5:47 pm Post subject: Turn Signal switch question |
I am having issues with the turn signals and hazard flashers burning up fuses. The high beam lights also do not work. I figured I would remove the turn signal switch and check it out. I think the high beams is not making contact and not sure on flasher issue. When looking into finding a new switch nothing shows up for a 1972 411. I looked at the 72 bug switch but looks a little different and looks to have 9 wires. Mine has only 6. Will the 72 bug switch work? Are the unused wires?
Also when I removed my switches this metal piece in photo fell out. Not sure where it goes. See photo
Posted: Wed Jan 03, 2024 6:05 pm Post subject: Re: Turn Signal switch question |
Update on electrical issues.
Turn signals all work including hazards. Problem was turn signal switch was bad replaced with 72 super beetle switch 9 wire unit worked fine.
Turn signal relay burnt out and front turn signal light prongs were touching causing a short.
High beams now work also turn signal high beam switch fixed.
Horn works now. Only on horn and it was bad along with a bad horn relay. Bought 2 new horns and a relay and all good.
Fuel gauge not working cause by a bad sender. Could not find the correct one but got one that works for now just shorter. Read full when full but when it says empty it is not empty. Has a big reserve for now. If anyone knows a better solution for the fuel sender let me know.
Buffing out the paint now. Will add photos later. I will need to find some trim with out so many dings.
That’s all for now,
Alan |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23128 Location: Oklahoma City
Posted: Thu Jan 04, 2024 9:58 am Post subject: Re: Turn Signal switch question |
Alaninin wrote: |
That’s all for now,
Alan |
Hello Alan! Sorry I could not get to this back when you had the issue. Yes, super beetle switch assemblies work as well as late model type 3. Both the turn signal switch and wiper/washer lever assemblies are 111 part prefix meaning type 1 based.
The fuel sending unit....according to the part # is unique to type 4. Its part # is 411 919 049. I assume you are working with a type 3 sending unit. These are identical but shorter. There are more than a few people who have detailed "how-to's" for repair in the type 3 forum if you search there.
This thread might help...maybe not. Its the same issue.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9424283
Ray |
Posted: Thu Jan 04, 2024 6:27 pm Post subject: Re: Turn Signal switch question |
Ray,
Thank you for the information you have provided. You have been helpful and I’m sure I will have more questions as I get this 411 ready for spring.
Added pictures of after buffing.
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7498 Location: Houston, Texas
Posted: Fri Jan 05, 2024 3:41 pm Post subject: Re: Turn Signal switch question |
There's a diagram on here somewhere that tells you what each wire does. I found it one day and used to check the turn signal switch I have. Basically you put your meter on continuity check. Then you attach the leads to the different wires. From there you flip the switch into the different modes. This will tell you if something is wrong internally in your switch. _________________ www.vwnos.com [email protected]
Posted: Sun Jan 07, 2024 9:30 pm Post subject: Re: Turn Signal switch question |
Nice looking car! Alaska blue metallic? My first car a 1972 411 four door was that color. Ray |
