What is the CFM of popular carbs?
Page: 1, 2, 3  Next
sbnova
sbnova is offline
PostPosted: Thu Sep 08, 2005 6:16 pm    Post subject: What is the CFM of popular carbs? Reply with quote
I read all about Weber 40's,44's,48's and Dellorto 40's and Kadrons, and Solex's, but what CFM's are some of these capable of? I know swapping venturis changes the flow, so an approximate is fine.
On a side note- I thought I posted this question a few days ago, but I cant find it so I appologize if this is a duplicate post.
Link to my build thread- Updated 6-6-07 http://www.thesamba.com/vw/forum/viewtopic.php?t=210613
check my sites to see my work;
http://www.cardomain.com/ride/1564293 (bug)
http://www.cardomain.com/ride/448794 (Vette,Nova,Typhoon)
DRD RACING HEADS
DRD RACING HEADS is offline
PostPosted: Sat Sep 10, 2005 4:45 pm    Post subject: Re: What is the CFM of popular carbs? Reply with quote
I flowed and IDA with a 42mm choke, it was 325 cfm. This will give you and idea. Smaller carbs will be around 225 cfm on up.
"DRD RACING HEADS"
"CNCHEADS and engine parts"
We sell What Works!
HTTP://WWW.DRDRACINGHEADS.COM
Email [email protected]
Phone-714-545-4100
DRD Online Store
HTTP://WWW.DRDRACINGHEADS.COM/Xcart/
sbnova
sbnova is offline
PostPosted: Sun Sep 11, 2005 4:55 am    Post subject: Reply with quote
Cool, Thanks for the info!
stealth67vw
stealth67vw is offline
PostPosted: Sun Sep 11, 2005 10:49 am    Post subject: Reply with quote
Here are few I found over the years:
Source: JayCee Ent./Perf.Tech- flowed on Superflow 600 @25" water
Weber 48mm IDA w/44 venturi-348cfm (per venturi) 1392cfm total
Weber 51.5mm IDA w/47.5 venturi-395cfm (per venturi) 1580cfm total
JayCee 62mm /55 venturi -633cfm (per venturi) 2531cfm total
with 20" water
Holley 1150 Dominator (4 barrel) 1180cfm (est.) total
Weber 48mm IDA w/44 venturi-311cfm (per venturi) 1244cfm total
Weber 51.5mm IDA w/47.5 venturi-353cfm (per venturi) 1413cfm total
JayCee 62mm /55 venturi -565cfm (per venturi) 2260cfm total
Source: Gene Berg Ent. no flow specs given
Weber 48mm IDA 40mm venturi-561 per carb
Weber 48mm IDA 42mm venturi-583 per carb
Source: CB Performance 1991 catalog- no flow specs or venturi sizes
I assume these numbers are @28" H2O per venturi
Dell'Orto 48mm DRLA 388.5cfm
Weber 48mm IDA 372.1cfm
Dell'Orto 45mm DRLA 329.3cfm
Weber 44mm IDF 292.3cfm
Dell'Orto 40mm DRLA 266.4cfm
Weber 40mm IDF 212.8cfm
Dell'Orto 36mm 205.8cfm
John Bates
JB Machining Services
1967 street Bug 2276 w/ 48 IDAs, 2050lbs with driver
7.76 @ 89.55mph 1/8 mile
12.27 @ 109.56 mph 1/4 mile
https://youtube.com/shorts/GmifEu5QvnA?si=OIw8eM7QU3LMhtiz
https://www.tiktok.com/t/ZT68foYFS/
sbnova
sbnova is offline
PostPosted: Sun Sep 11, 2005 11:33 am    Post subject: Reply with quote
Wow, those are some serious flow #'s . I cant believe an A/C VW 4cyl uses so much carb.
Bugman Jeff
Bugman Jeff is offline
PostPosted: Mon Sep 12, 2005 12:23 am    Post subject: Reply with quote
I've often wondered why such a small motor uses so much carb? can anyone explain that to me? I mean, 600 CFM is just right for a mild 350(5.7L) Chevy, yet a 3.0L VW will use 1,200 CFM?
Restorer of Porsche Speedster 80486 Smile
jamestwo
jamestwo is offline
PostPosted: Mon Sep 12, 2005 5:18 am    Post subject: Reply with quote
on a V8 with a single plane, each cylinder has full benifit of of all four barrels, on a VW with one ventura per cylinder, each cylinder only draws from one barrel.
So on a V8 with a 65 cfm, each cylinder can draw up to 650 CFM, because only one cylinder draws at a time.
running four 325 cfm venturas on a VW would be the same as running a single 325 cfm carb on a single plane intake.
dawi4x4
dawi4x4 is offline
PostPosted: Mon Sep 12, 2005 6:15 pm    Post subject: Reply with quote
my pulling tractor is a chevy 2.3L, demon 1050 cfm
use to run it on my pulling truck 468 ci bbc
sbnova
sbnova is offline
PostPosted: Tue Sep 13, 2005 12:31 pm    Post subject: Reply with quote
Jamestwo- that makes sense. Thanks for describing it that way.
A.J.Sims
Banned
Location: LowBugget.com 982 N Batavia A4 Orange Ca 92867
A.J.Sims is offline
PostPosted: Tue Sep 13, 2005 5:14 pm    Post subject: Reply with quote
Stock 40 mm Kadron with 28mm vent and stock aircleaner brackit.
165cfm @25"
Our 46mm Kadrons with 38mm vents and our Air Top kit.
243cfm @25"
Our 48mm Kadron with 42mm vents,Air Top Kit, Spray Bar
307cfm @25" With JC.Ent stack 330cfm @25"
Twisted Evil
Terry Cloyd
Banned
Terry Cloyd is offline
PostPosted: Wed Sep 14, 2005 1:11 pm    Post subject: Reply with quote
A stock VW dual port head with 35.5mm intake and 32mm exhaust valves will flow 92.93 cfm with 44s. At .450 lift the head flows 126.35 at .600-in lift the flow is 139.01. Terry
vdubyah73
vdubyah73 is offline
PostPosted: Wed Sep 14, 2005 2:09 pm    Post subject: Reply with quote
Is this 1 barrel or both?
Thanks Bill
stealth67vw
PostPosted: Wed Sep 14, 2005 4:43 pm    Post subject: Reply with quote
One venturi (barrel)
John Bates
vdubyah73
PostPosted: Wed Sep 14, 2005 5:11 pm    Post subject: Reply with quote
Does that mean I can tell some mook thats raggin' on my 2275 cc dune buggy that I got 1170 cfm worth of carb on my puny little VW engine? Shocked Laughing
Thanks, Bill
stealth67vw
PostPosted: Wed Sep 14, 2005 6:07 pm    Post subject: Reply with quote
You sure can Very Happy
John Bates
RanX0R0X
RanX0R0X is offline
PostPosted: Thu Dec 02, 2010 7:10 pm    Post subject: Reply with quote
Yeah, I know, this post was from a long time ago but I'm curious to know how to think about the flow rate.
1 cubic foot/minute = 0.471 947 45 liter/second
Dell'Orto 40mm DRLA
266.4cfm*0.471 947 45
=~125L/second
1914cc/4=478.5cc which thanks to metric
=0.4785L
(2000RPM/2)*0.4785/60 seconds
=~8L/s
Does that look right?
VW-Gasser
VW-Gasser is offline
PostPosted: Thu Dec 02, 2010 9:23 pm    Post subject: Reply with quote
I am not sure if I read this data right, but it looks like that 48 DRLA are less restrictive than 48IDAs? And does that mean that you can get a little more power out of the DRLA (perhaps the TriJet ones) than out of the IDAs?
Thanks
-- www.vw-gasser.de --
modok
modok is offline
PostPosted: Fri Dec 03, 2010 12:53 am    Post subject: Reply with quote
Dell'Orto 40mm DRLA
=~125L/second
=0.4785L
=~8L/s
Do keep in mind
Holley's carb CFM ratings were usually @ 3mm HG for regulear apps and 1.5mm HG for Hp apps. You can roughly convert 25 inches of water depression CFM to the lower carb CFM rating with a conversion you can probably find somewhere maybe.
I don't know what you are trying to figure out, for IR carbs most everybody just goes by venturi size. To get scientific maybe you could figure the flow coefficient of the vent size?? and use that to compare?
RockCrusher
RockCrusher is offline
PostPosted: Fri Dec 03, 2010 1:02 am    Post subject: Reply with quote
Thanks, Bill
You can....kind of.
Those ratings are based on steady stabilized flow where as we use them in a stop and start mode......kind of. Independent runner applications are far different than plenum apps.
[email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly.
catbox
catbox is offline
PostPosted: Fri Dec 03, 2010 9:25 am    Post subject: Reply with quote
This is good information to have.
I just stepped up to a set of Dell 45's for my new motor and was just wondering what these flow for a comparison to the numbers the head guys put out.
Of course they are probablly not a direct comparison but a comparison anyway. Better than nothing.
Very Happy
Page: 1, 2, 3  Next
