The "Old Red" thread.
Page: Previous  1, 2
67rustavenger
67rustavenger is offline
PostPosted: Sat Dec 30, 2023 3:34 pm    Post subject: Re: The "Old Red" thread. Reply with quote
ryans65 wrote:
hesitation was yet another failed set of bosch points, I had a set prematurely fail on my 912 also, both had a couple thousand miles on them tops, stuff is junk!!
I buy points from Napa Auto Parts. The Standard brand points are far superior to the Bosch points available today.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
ryans65
ryans65 is offline
PostPosted: Sat Dec 30, 2023 6:14 pm    Post subject: Re: The "Old Red" thread. Reply with quote
Thank you for the recommendation, I have it running on a spare german 009 right now but I want to get the big cap back in as it runs so much better with that obviously.
ryans65
ryans65 is offline
PostPosted: Sat Dec 30, 2023 6:29 pm    Post subject: Re: The "Old Red" thread. Reply with quote
Here's a couple more of this thing from maybe 15-20 years ago until about 2017
One of the many previous owners:
When I got it shortly after the narrowed beam but still on the 5 spokes
Then on some fake sprint stars
ryans65
ryans65 is offline
PostPosted: Sun Dec 31, 2023 2:35 pm    Post subject: Re: The "Old Red" thread. Reply with quote
some shots of old reds gorgeous interior, I think it's mostly original except the front seat covers and floor mats obviously
ryans65
ryans65 is offline
PostPosted: Mon Jan 01, 2024 1:02 pm    Post subject: Re: The "Old Red" thread. Reply with quote
Set out to replace the front windshield seal and install the chrome trim, ended up getting it roped in on my second try, not bad!
ryans65
ryans65 is offline
PostPosted: Sun Jan 07, 2024 6:32 pm    Post subject: Re: The "Old Red" thread. Reply with quote
One step forward and one step backward, got my preheat hose hooked up to my little tube thing on the 3/4 cylinder side but had to put my spare 009 on from my road trip tool bag because the advance plate thing on my 205m distributor was sticking intermittently. Boy do these things drive a lot different (worse) with the 009's.
I thought I had a German square or dome top fuel pump I could rebuild but one was an old USA made unit and the other was a brazilian. Looks like Sparxwerxs has a scratch and dent sale on some
dome tops though.
Eric&Barb
Eric&Barb is offline
PostPosted: Sun Jan 07, 2024 7:44 pm    Post subject: Re: The "Old Red" thread. Reply with quote
You could try applying oil to the dual plates and see if that gets rid of the sticking, or take the advance distributor apart for a good cleaning. Just make sure to mark the shaft to show which way the drive gear goes back on if you do the latter.
VW of Brazil fuel pumps are good for a running engine that is not going to be restored to factory specs.
What size crankshaft pulley do you have? Looks like the smaller single port version that should not be paired with dog house cooling system.
In Stereo, Where Available!
ryans65
ryans65 is offline
PostPosted: Mon Jan 08, 2024 7:51 am    Post subject: Re: The "Old Red" thread. Reply with quote
I'll get it ripped apart and unstuck at some point. Good call on the crank pulley I'll measure it but I'm assuming since I didn't change it that it's an early pulley. This engine seems to be a hodge podge of different year stuff.
ryans65
ryans65 is offline
PostPosted: Sat Jan 13, 2024 7:12 pm    Post subject: Re: The "Old Red" thread. Reply with quote
Got my distributor back in, points plate was really stuck on the shaft to the point where the advance would stick at max and then it would run like garbage obviously. Still gotta dig out another heat tube clamp. Need to get an non insulated terminal crimper tool to replace a couple colorful ones I've used here and there.
Eric&Barb
PostPosted: Sat Jan 13, 2024 9:17 pm    Post subject: Re: The "Old Red" thread. Reply with quote
Take the green wire off the coil. Then wrap that wire around a wood pencil or straight sided pen, with each loop tight against the next. Once wound around let the wire loosen from that and slide the writing implement up and out of the now curled wire. Reattach the wire back on the coil. That will help the wire not rub on parts of the engine and make that much less rat nest of a look.
Also get the sealing tin parts to go around the heat riser pipes of the intake manifold at the rear tin.
ryans65
ryans65 is offline
PostPosted: Sun Jan 14, 2024 9:28 am    Post subject: Re: The "Old Red" thread. Reply with quote
that's funny I was trying to recoil it back and never thought about wrapping it around something, I'll do that, I need another set of those heat riser cover
things too but I'll do that when I get a normal muffler back on it, my buddy put this silly empi one on it that doesn't fit right at all
ryans65
ryans65 is offline
PostPosted: Sun Jul 14, 2024 2:44 pm    Post subject: Re: The "Old Red" thread. Reply with quote
Old red is patiently waiting for the new garage to go up.
ryans65
ryans65 is offline
PostPosted: Wed Jul 17, 2024 8:38 am    Post subject: Re: The "Old Red" thread. Reply with quote
ryans65
ryans65 is offline
PostPosted: Sun Dec 01, 2024 6:42 pm    Post subject: Re: The "Old Red" thread. Reply with quote
Old red is going to need some metal work soon, I fear I will get scope creep though and go too deep but we'll see. Need to reseal the axle flanges and boots soon. Still running like a champ though.
OldBeetles
OldBeetles is offline
PostPosted: Tue Dec 03, 2024 7:25 am    Post subject: Re: The "Old Red" thread. Reply with quote
Always interesting to see long term updates on cars like this. I should consider making a thread like this about mine.
ryans65
ryans65 is offline
PostPosted: Mon Mar 24, 2025 12:51 pm    Post subject: Re: The "Old Red" thread. Reply with quote
I returned from a recent find with mixed feelings. This guy tried his hardest to save what he could but in the end it's all basically scrap. For years people tried to buy these cars and parts and the answer was always no. Now they sit waiting their turn for the scrapper.
I thought it was fitting to at least pull what I could off this turkis 61 and put it on old red. It's always been missing its wolfsburg hood badge so I picked the nicest one of the pair to give to old red.
This 61 was driven to this very spot in the 70s where the humidity and pine needles slowly devoured it. It had that malachite(?) interior, title and even the window sticker from Brundage (Brumos) but the car is quite literally falling apart.
Aside from some axle boots that leaked about a quart of gear oil on my catch pan old red continues to be my go to for cruising around town.
Old red finally got its vintage Florida tag approved so on it went!
ryans65
ryans65 is offline
PostPosted: Mon Mar 24, 2025 1:18 pm    Post subject: Re: The "Old Red" thread. Reply with quote
I think I've decided instead of taking on a new car project I will devote some time to getting red's floors, channels and rear body mounts solid again. The outside will remain as-is but I'd love to get the floors nice and tight as I can get carpet back in it and reupholster the front and rear seats. I've done some rubber here and there but the doors will need redone, the quarter glass and rear window need new rubber as well. Just thinking out loud here.
ryans65
ryans65 is offline
PostPosted: Mon Mar 24, 2025 1:24 pm    Post subject: Re: The "Old Red" thread. Reply with quote
Another photo of this peice of aircooled history has emerged!
ryans65
ryans65 is offline
PostPosted: Thu Apr 17, 2025 6:33 pm    Post subject: Re: The "Old Red" thread. Reply with quote
My drivers glass seemed to be binding on the non-existent felts. When I removed the door panel I realized the glass channel clip thing was pretty much seized to the channel. I removed and greased everything, did the inner felts and window sweep but skipped the outer one with the chrome for now. Too much money for a beater car. I cleaned up the door panel but that didn't really make much difference.
In the photos above there is an MG I've lined up for paint and while it's there I'm thinking of doing pans, channels, rear body mounts and some work on the fenders. It's less about aesthetics and more about keeping the weather out on this car. This thing was actually pretty solid when I first bought it but the rust flakes piling on the floors are telling me it's time!
Page: Previous  1, 2
Page 2 of 2
