zoti Samba Member
Joined: December 26, 2007 Posts: 2175 Location: Plano, TX USA
Posted: Mon Jan 29, 2024 6:27 pm Post subject: Anyone here using EcoFlow Wave or Wave 2? |
I'm looking into getting a wave 2 for the coming summer.
My thought is to use it while driving by sectioning off the front of the cab and cooling just that area and then use it at night for sleeping.
Venting of the air from the condenser side will be through the side window.
I also have solar and 200Ah batteries to supplement the included battery. Thinking of charging from that or the alternator while driving.
I'm in TX so it has to work in 100 degree weather.
Anyone have one of these? It's a 5200btu unit. I think it can work but not sure.
https://www.ecoflow.com/us/wave-2-portable-air-conditioner |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19166 Location: Retired South Florida
Posted: Mon Jan 29, 2024 7:20 pm Post subject: Re: Anyone here using EcoFlow wave or wave 2? |
We have a 5000 btu window unit for camping. It does a nice job of cooling the van at night. Not so much in direct sunlight. We also have a vintage air dash unit. I don’t know the rating, but it’s small compared to the factory air AC. It direct sunlight it really only cools the front passengers. Cloudy day, rain, or night it will freeze you out.
Every year this comes up and every year we get closer. I watched a van life video where the owner installed a 12 volt mini split in a sprinter type van. No idea of the battery pack required.
If the unit you linked has to exhaust heat out of the van, ambient air will need to replace it. Not ideal for cooling in hot climates. |
VeeDubn Samba Member
Joined: May 31, 2019 Posts: 169 Location: Olympia, Washington
Posted: Mon Jan 29, 2024 11:47 pm Post subject: Re: Anyone here using EcoFlow Wave or Wave 2? |
We purchased the EcoFlow Wave 2 last summer; used it on our 'round the country trip last October. Really nice little unit; definitely glad I purchased the bundle (unit & battery). I also purchased an extra set of venting tubes - the extra set are 8' long (vs. the 5' long tubes that come with the unit), which allowed us to use the unit while driving down the road. We used 3 tubes while driving - two venting in/out the window, one blowing cold air into the cab. Hanging curtains behind the front seats helped keep the cool air up front for sure.
We used it a couple of times for heat as well, but the primary reason we purchased it was to keep our doggie cool in the warmer temperatures. While driving, it was fine up to about 85 degrees, but when we hit 95 degrees in the afternoon in Arizona, the unit could not keep up sufficiently to keep our doggie cool. Hubby and I could have handled it just fine, but doggie not so much. Parked over night we turned the unit off once the camper cooled down - otherwise it just got too cold!
Overall we are very happy with the unit; no regrets. I can post pictures if you are interested.
~ Judy |
MayorMcCheese Samba Member
Joined: October 07, 2009 Posts: 777 Location: Lancaster PA
Posted: Tue Jan 30, 2024 4:10 pm Post subject: Re: Anyone here using EcoFlow Wave or Wave 2? |
| They are tempting. But considering there are 5! of them for sale locally I'm guessing they don't live up to expectations. I might look into buying one of those used one though. |
zoti Samba Member
Posted: Tue Jan 30, 2024 7:57 pm Post subject: Re: Anyone here using EcoFlow Wave or Wave 2? |
| VeeDubn wrote: |
~ Judy |
Does it fit between the front seats? |
Xevin  Samba Member
Posted: Tue Jan 30, 2024 9:26 pm Post subject: Re: Anyone here using EcoFlow Wave or Wave 2? |
20 x 16 x 12 inches _________________ Keep on Busin'
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
| Clatter wrote: |
Damn that Xevin...  |
| skills@eurocarsplus wrote: |
| SGKent wrote: |
Posted: Tue Jan 30, 2024 9:36 pm Post subject: Re: Anyone here using EcoFlow Wave or Wave 2? |
Does it fit between the front seats?[/quote]
Fits perfectly. We built a bench seat for our doggie; EcoFlow sets on the bench seat just fine. Fits on the floor as well. Hubby built an insert for the front passenger window for the venting tubes when we are parked. We installed the insert that came with the unit on the side window to use while driving. Having a third tube allows us to direct the flow of air. While driving we extend the venting tube and hang it from the pop-top latch to have it point into the cab. We now have a smaller tray for the draining tube, but because of the internal draining system we haven't had any draining into the tray.
zoti Samba Member
Posted: Wed Jan 31, 2024 12:54 pm Post subject: Re: Anyone here using EcoFlow Wave or Wave 2? |
| VeeDubn wrote: |
[/quote]
Perfect. That's what I was thinking of doing.
How well does the battery hold if you are also charging it while driving? |
Posted: Thu Feb 01, 2024 7:28 pm Post subject: Re: Anyone here using EcoFlow Wave or Wave 2? |
[/quote] Perfect. That's what I was thinking of doing. How well does the battery hold if you are also charging it while driving?[/quote]
The battery charges being plugged in to shore power, a vehicle "cigarette lighter," or 400W solar. We only have 100W solar, and no "cigarette lighter," but we can plug into our inverter while driving, and shore power when parked.
As I recall from last year, we comfortably got a good 6 hours from the battery; probably a bit more. We were plugged in to our inverter, but our alternator (unbeknownst to us until the last day of vacation!) was not operating at full power. Nonetheless, we were able to charge the battery to some extent while using it at the same time, which did extend the usage time. We did recharge the battery with shore power each night. |
zoti Samba Member
Posted: Thu Feb 01, 2024 7:41 pm Post subject: Re: Anyone here using EcoFlow Wave or Wave 2? |
I've managed to grab a unit locally with the battery.
A quick test to see how it will fit in the van. I will definitely have to separate the front from the back while driving and insulate everything the best way possible.
zoti Samba Member
Posted: Fri Feb 02, 2024 10:33 pm Post subject: Re: Anyone here using EcoFlow Wave or Wave 2? |
Working on designing vents for the EcoFlow. These will be attached to the panels that will go on the window.
Posted: Sat Feb 03, 2024 7:14 pm Post subject: Re: Anyone here using EcoFlow Wave or Wave 2? |
| zoti wrote: |
| Working on designing vents for the EcoFlow. These will be attached to the panels that will go on the window. |
Which window? Front passenger? or driver side slider? |
zoti Samba Member
Posted: Sun Feb 04, 2024 6:01 pm Post subject: Re: Anyone here using EcoFlow Wave or Wave 2? |
| zoti wrote: |
| Finished my vent design. One big vent. One small vent. |
Looking forward to a picture of them installed! |
zoti Samba Member
Posted: Sun Feb 04, 2024 6:31 pm Post subject: Re: Anyone here using EcoFlow Wave or Wave 2? |
| VeeDubn wrote: |
| zoti wrote: |
I'm printing them now. Need to design the part that goes on the window itself. |
zoti Samba Member
Posted: Tue Feb 06, 2024 10:07 am Post subject: Re: Anyone here using EcoFlow Wave or Wave 2? |
jlrftype7 Samba Member
Posted: Tue Feb 06, 2024 11:46 am Post subject: Re: Anyone here using EcoFlow Wave or Wave 2? |
Very Cool- I envy your skills.. or, congrats to your Printer....  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
zoti Samba Member
Posted: Tue Feb 06, 2024 12:23 pm Post subject: Re: Anyone here using EcoFlow Wave or Wave 2? |
Posted: Tue Feb 06, 2024 3:08 pm Post subject: Re: Anyone here using EcoFlow Wave or Wave 2? |
Nicely done! Thank you for posting the pics . . . |
zoti Samba Member
