RichBenn Samba Member
Joined: November 16, 2005 Posts: 703 Location: Lake Tahoe, NV
Posted: Wed Jan 12, 2022 1:14 pm Post subject: Clutch Slave cylinder which brand? |
After a couple years, my clutch slave cylinder is leaking. Think it was FEBI. Thinking about Exidy or LUK. Opinions? _________________ Rich |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7178 Location: Honolulu,Hawaii and France
Posted: Wed Jan 12, 2022 1:23 pm Post subject: Re: Clutch Slave cylinder which brand? |
RichBenn wrote: |
After a couple years, my clutch slave cylinder is leaking. Think it was FEBI. Thinking about Exidy or LUK. Opinions? |
Exedy or LUK are the exact same ones. I've been testing a few chinese hydraulics from them, so far so good. I have 5 years on a clutch and brake masters, 4 on the clutch slave. I opened them, the quality seems decent. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Robw_z Samba Member
Posted: Wed Jan 12, 2022 6:03 pm Post subject: Re: Clutch Slave cylinder which brand? |
As of today, GoWesty, Van Cafe and BusLab are all Out of Stock on clutch slaves. I bet you'll find one if you look but just saying it's a hard time to be choosing good brands.
-Rob
Posted: Wed Jan 12, 2022 6:07 pm Post subject: Re: Clutch Slave cylinder which brand? |
ALIKA T3 wrote: |
RichBenn wrote: |
Exedy or LUK are the exact same ones. I've been testing a few chinese hydraulics from them, so far so good. I have 5 years on a clutch and brake masters, 4 on the clutch slave. I opened them, the quality seems decent. |
Thank you! _________________ Rich |
Posted: Wed Jan 12, 2022 6:14 pm Post subject: Re: Clutch Slave cylinder which brand? |
Robw_z wrote: |
As of last today, GoWesty, Van Cafe and BusLab are all Out of Stock on clutch slaves. I bet you'll find one if you look but just saying it's a hard time to be choosing good brands.
-Rob |
I noticed that. But every other, non-Vanagon specific parts vendors seem to have them in stock. _________________ Rich |
BrownLoaf Samba Member
Joined: January 21, 2021 Posts: 107 Location: Bellingham, WA
Posted: Wed Jan 12, 2022 8:27 pm Post subject: Re: Clutch Slave cylinder which brand? |
FTE if you can find one. They are out of stock at the usual online places but shops my have them on hand if there are any near you that work on Vanagons. Reference Automotive near my in Bellingham, WA had one in stock and were gracious enough to sell it to me. Also try Ken Willford at Vanagain as he may be able to order them.
I recently found that I had suffered shifting issues (grinding gears) since 2013 due to a slave cylinder that was too short. Then I replaced it in December with a new one and that one was even shorter, causing the transmission to not go into gear at all. Finally, the FTE solved the problem I didn't know existed.
Here's the thread on that:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=40 _________________ 83.5 Vanagon Riviera WBX 2.2 "Brown Loaf"
87 Vanagon Syncro Tin Top WBX 2.1 "Bubbles" |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2938 Location: San Luis Obispo, CA
Posted: Wed Jan 12, 2022 8:54 pm Post subject: Re: Clutch Slave cylinder which brand? |
Are there rebuild kits out there? When I was a kid, my dad never bought a new master cylinder. He would do a quick hone in the bore and then replace all the rubber seals. Put it back together and throw it back in...
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
Posted: Wed Jan 12, 2022 9:03 pm Post subject: Re: Clutch Slave cylinder which brand? |
FTE on fleabay
https://www.ebay.com/itm/132935374243 _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1733 Location: Budapest Hungary, Europe
Posted: Thu Jan 13, 2022 12:49 am Post subject: Re: Clutch Slave cylinder which brand? |
I would say there are max 3 factories making these cylinders.
The cheapest black ones with laser engraved partnrs. Like the Meyle, Febi, JPGroup, etc.
The "middle class" zinc coated with some cast markings. Probably made in italy but more likely also in china. Like Lpr, Sachs, Bosch, etc. I would say Ate ones are the same.
The "premium". Like FTE, TRW, Girling, Hella. Also probably in italy, but more likely somewhere in the east.
But of course the boxing brands buy bulk from different suppliers, so you find the good one in one box and you will find the bad in the other
Here you can see the catalog pics to compare. No guarantee if they look the same in the box :
https://www.niparts.com/s_637E62/03252527113.html _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
kaeferman Samba Member
Joined: April 04, 2012 Posts: 115 Location: Sylva, NC
Posted: Mon Feb 26, 2024 5:38 am Post subject: Re: Clutch Slave cylinder which brand? |
i had to chime in as my build from a few years ago just ended up with brake fluid on the cab floor, eating the paint and soaking the carpet, pad and all. Love that brake fluid
Anyway, i had bought an FTE in mid 2019 and its barely made it 5 years with light ussage as the van is not a daily driver
The res grommets seem to have leaked on me in the past on another van after super cold weather which is like this time too but no evidence of grommet leak this time. Rubber shrinkage happens
I wonder if anybody else had short life with FTE or am i just lucky? I saw a Sachs available but doesn t sound like its any better than FTE which VC is calling “german” - box says Germany but another sticker on the part says elsewhere..which i ve seen on Meyle parts sometimes
Guess i try another fte?
B _________________ 83 Westfalia wbx “Idaho”
84 Tintop “Vanamos”
formerly
71 Squareback sold
70 Westfalia lost to fire by new owner
71 Super Beetle rolled/scrapped |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1555 Location: san diego
Posted: Mon Feb 26, 2024 7:25 am Post subject: Re: Clutch Slave cylinder which brand? |
l buy FTE, and have had nothing but long lasting use out of them.
l've never had to replace one l have fitted for a customer _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6926 Location: Fort Lauderdale, Fl.
Posted: Tue Feb 27, 2024 4:37 am Post subject: Re: Clutch Slave cylinder which brand? |
Sorry i should clarify my recent issue with fluid on the cab floor was a leak that developed from the clutch master and not the slave. The boot which seals the pushrod business end was wet and i assume the unit has failed somehow. when i get it disassembled i will confirm this.
On a side note regarding the slave cyl
Twice i have had vans that either would not shift correctly or couldn t be put into gear. Simply bleeding the slave of dark dirty fluid rectified the issue without replacing the part. Kind of weird
84 Tintop “Vanamos”
formerly
71 Squareback sold
Van den Broke Samba Member
Joined: May 20, 2012 Posts: 207 Location: Victoria, Canada
Posted: Wed Feb 28, 2024 7:02 pm Post subject: Re: Clutch Slave cylinder which brand? |
I just received an order from California Import Parts that included a clutch enslaved cylinder as well as a rebuild kit.
I've yet to install either since the van is outside and weather is awful, but the parts are "Classic Line" brand, distributed by JP Group.
The packages say "Denmark", but it doesn't say "Made in Denmark".
The cylinder is painted black with silver (laser?) printing.
My plan is to swap the bad part out and then rebuild it if it is still good. I have found that cast iron brake cylinders tend to get pitted, whereas aluminum ones do not. So my old part may well be unusable.
Of course, with rare and expensive parts the pitted cores are often sleeved. |
Posted: Thu Feb 29, 2024 8:51 am Post subject: Re: Clutch Slave cylinder which brand? |
Van den Broke wrote: |
Wasn't made in Denmark!
It will take you all of ten minutes to pull the seals off and replace them after you get it out. If you do swap it out with the JP brand definitely carry the spare seal kit with you. _________________ This free advice is worth exactly what you paid for it.
Posted: Fri Mar 01, 2024 11:16 pm Post subject: Re: Clutch Slave cylinder which brand? |
If that's true, it would seem that consumer protection legislation is really deteriorating.
I had the notion years ago that products had to have the country of origin marked on them.
I used to repair brake hydraulic cylinders by only changing the rubber cups, which I could get at one of the older auto parts or brake shops in town. Those cups wearing out are the usual cause of hydraulic cylinder failure. I hope that the new ones are made as well as the originals, or the US made replacements I used to get. |
Nitramrebrab72 Samba Member
Joined: November 10, 2018 Posts: 832 Location: France
Posted: Sat Mar 02, 2024 12:31 am Post subject: Re: Clutch Slave cylinder which brand? |
If there is no damage or corrosion inside to the piston of cylinder and if you can find a high quality rebuild kit I would rebuild it as it is simple. If not the original fitted was TRW and they are quality . |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5679 Location: Bemidji, MN
Posted: Sat Mar 02, 2024 6:55 am Post subject: Re: Clutch Slave cylinder which brand? |
hdenter wrote: |
Are there rebuild kits out there? |
here's some i have for the master and slave.
_________________ -dan
www.thefixitworkshop.com |
