Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Mon Jan 16, 2017 6:53 pm Post subject: Re: Best Year Early Squareback opinions wanted |
That pink (red) Square is a 72 or 73. _________________ 71 Elm Green FI A/T Squareback |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Mon Jan 16, 2017 7:27 pm Post subject: Re: Best Year Early Squareback opinions wanted |
The blue one is most likely a 67 in VW Blue. This is based on back up lights, the rear reflector housings, and the hatch script and hatch type. 1967 is the last year of this style hatch. The 'bolt on' light housing started in 68.
The 67 has a lot of 'one year only' parts but almost every model year of Type 3 has some 'one year only' parts - some lasting months in production, not even the whole production year. The 1967 has the most 'one year' parts, in my opinion, but it seems to have been a very popular year as well. I've had several 67's and never really had a problem finding parts for them.
Depends upon how close to stock you're going to stay...but don't get too wrapped up in one model year or a few odd parts unless they're part of specific appeal to you.
Posted: Mon Jan 16, 2017 7:47 pm Post subject: Re: Best Year Early Squareback opinions wanted |
ataraxia wrote: |
The 67 has a lot of 'one year only' parts but almost every model year of Type 3 has some 'one year only' parts - some lasting months in production, not even the whole production year. |
Josh makes a good point. You will find this to be true with Type 3's more so than with the Beetle. _________________ 71 Elm Green FI A/T Squareback |
jgerock Samba Member
Joined: July 15, 2011 Posts: 50 Location: Alexandria, VA
Posted: Thu Jan 19, 2017 6:11 pm Post subject: Re: Best Year Early Squareback opinions wanted |
Donnie strickland wrote: |
ataraxia wrote: |
Josh makes a good point. You will find this to be true with Type 3's more so than with the Beetle. |
This is my greatest fear. I've seen the crazy variations of the 66/67 Beetle turn signal/emergency switch relay along with the dash switches, door handles, wiring, etc. to know better than to try and tackle a one year only vehicle that must be updated to keep it on the road (quoting from Seinfeld: "not that there's anything wrong with that").
My first 66 Bug was really bastardized: 66 body, 1500 "H-code" engine, 68 heater channels (along with the same bulkheads) with new floorpans and 67/68 electricals. I converted the engine to 1600, then to 1641 using "big bore" cylinders, added Cofap remanufactured dual port cylinder heads (several times), single Dellorto 40mm Bugpack intake setup (horrible) later changed to dual Weber 34ICT carbs. I removed the thermostat and fan housing flaps like an idiot and added a Thunderbird brand glass pack muffler. This engine ended up in the 75 Beetle with more mods like single QP muffler. |
Posted: Thu Jan 19, 2017 6:15 pm Post subject: Re: Best Year Early Squareback opinions wanted |
jgerock wrote: |
ataraxia wrote: |
If you're going to keep it bone stock and don't want a bunch of one year only parts - steer clear of the 67 Type 3. I think almost every year has some one year only parts though...
Which areas are you more concerned with having to find one year only parts? |
Posted: Thu Feb 02, 2017 6:18 pm Post subject: Re: Best Year Early Squareback opinions wanted |
Think I'll stick with a 69 with 4 speed. I really have liked the IRS in my last two Beetles.
I've been browsing thru the classifieds. Glad I kept all my VW specific tools |
Posted: Fri Mar 22, 2024 5:55 am Post subject: Re: Best Year Early Squareback opinions wanted |
Found one earlier this month. Royal Red 69 4 speed. Should get it delivered next week. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13286 Location: Tejas!
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4194 Location: Pasadena CA/DTLA soon China
Posted: Fri Mar 22, 2024 9:26 am Post subject: Re: Best Year Early Squareback opinions wanted |
Use the type 3 selecta something. _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
Scotty D Samba Member
Joined: February 08, 2020 Posts: 133 Location: Claremont CA
Posted: Fri Mar 22, 2024 10:14 am Post subject: Re: Best Year Early Squareback opinions wanted |
Finally pulled the trigger! Wow, that's a nice one.
Congrats on your purchase. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22440 Location: Kimball, Mi
Posted: Fri Mar 22, 2024 2:09 pm Post subject: Re: Best Year Early Squareback opinions wanted |
jgerock wrote: |
That looks great.
I was going to say, that IRS can be swapped into an early car, but nobody mentioned it yet. My 65 Notch has an IRS swapped in (I did it myself). It's currently got a super beetle trans axle in it for the gearing (3.88:1) which helps with fuel economy and ride. I also converted the car to 12 volt, as it's not hard to do. Getting all the bulbs is the the thing. In my case I used a 1 year only wiper motor (from a 70) do do that part of the conversion. I'm running a generator and an old style VR in it, and haven't had any issues. I built my car the way I wanted it, as I like to drive it. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Mar 22, 2024 2:37 pm Post subject: Re: Best Year Early Squareback opinions wanted |
Bobnotch wrote: |
jgerock wrote: |
That looks great.
I was going to say, that IRS can be swapped into an early car, but nobody mentioned it yet. My 65 Notch has an IRS swapped in (I did it myself). It's currently got a super beetle trans axle in it for the gearing (3.88:1) which helps with fuel economy and ride. I also converted the car to 12 volt, as it's not hard to do. Getting all the bulbs is the the thing. In my case I used a 1 year only wiper motor (from a 70) do do that part of the conversion. I'm running a generator and an old style VR in it, and haven't had any issues. I built my car the way I wanted it, as I like to drive it. |
Car was made August 13, 1968 per the VW Certificate. It has IRS, dual baby Webers, Pertronix distributor and coil, Vintage Speed exhaust. |
Posted: Fri Mar 22, 2024 2:40 pm Post subject: Re: Best Year Early Squareback opinions wanted |
Erik G wrote: |
some 4 lug sprint stars would do wonders for that car, those wheels and tires are terrible
congrats - it's got a cool fade |
I’m trying to decide which wheels to get. Sprint Stars, 914 alloys or Riviera alloys are some ideas. I also like ATS 5 spokes with black background.
Car will get repainted L30 Royal red. I might do a two tone with white (Lotus?) roof. |
Posted: Fri Mar 22, 2024 2:43 pm Post subject: Re: Best Year Early Squareback opinions wanted |
ALLWAGONS wrote: |
Use the type 3 selecta something. |
Not familiar with that term. Please elaborate. |
Posted: Fri Mar 22, 2024 2:45 pm Post subject: Re: Best Year Early Squareback opinions wanted |
jgerock wrote: |
Bobnotch wrote: |
jgerock wrote: |
That looks great.
More pics of it, or start a new thread about your newest purchase. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Erik G Samba Member
Posted: Sat Mar 23, 2024 11:06 am Post subject: Re: Best Year Early Squareback opinions wanted |
jgerock wrote: |
Erik G wrote: |
Do a search of this thread for https://www.thesamba.com/vw/forum/viewtopic.php?t=245654 (direct link)
As this IS the tire and rim thread for type 3s. Most of these combos have been worked out, and some of the users discussed what mods needed to be done before they fit. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22729 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sat Mar 23, 2024 5:27 pm Post subject: Re: Best Year Early Squareback opinions wanted |
jgerock wrote: |
Erik G wrote: |
Nice choice! I have two Royal Red '69s here (along with 3 Peru Greens! Somebody help me... )
Hit me up if you decide to go back to fuel injection on this. Have fun with it. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 24167 Location: Southeast USA
Posted: Sun Mar 24, 2024 12:31 pm Post subject: Re: Best Year Early Squareback opinions wanted |
Wow! It looks like it took seven years for you to finally pull the trigger on a car that pretty much matches your parents' original, which would have been my suggestion all along! I would do it as an exact match to the one you remember.
I almost bought a nice beige '68 Squareback that exactly matched the one my dad had, which would have been a memory trigger for sure, ultimately deciding to stick with the simplicity of bugs, but it was a hard call! _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
