Kubel 2021
fastmc25
fastmc25 is offline
PostPosted: Wed Jan 25, 2023 5:39 am    Post subject: Re: Kubel 2021 Reply with quote
Thanks. It’s Battlefield Green. The Paint is a Matte finish paint from Eastwood.com. I also sealed the body with thier urethane epoxy primer.
https://www.eastwood.com/eastwood-battlefield-olive-drab-3-1-single-stage-paint.html
Peace,
Paul
1973 Type181 Kubelwagen (Thing 2 ) 2110cc
1971 Transporter (Pickle) 1914cc
1961 Deluxe Beetle (Christine) 1776cc
1973 Adventurewagen Baja Bus (Clyde) 3.4L
1970 Formula Vee Beetle 2276cc
I identify as: “A Grumpy Old Vet”
vwtragic62
vwtragic62 is offline
PostPosted: Thu Jan 26, 2023 1:11 am    Post subject: Re: Kubel 2021 Reply with quote
Thanks Paul.
cheers
Noel.
fastmc25
fastmc25 is offline
PostPosted: Fri Oct 27, 2023 4:50 pm    Post subject: Re: Kubel 2021 Reply with quote
Trying out one of these Diesel heaters Still need to finish wiring and the fuel tank install.
Peace,
Paul
fastmc25
fastmc25 is offline
PostPosted: Tue Oct 31, 2023 7:13 am    Post subject: Re: Kubel 2021 Reply with quote
Peace,
Paul
Johnnyw
Johnnyw is offline
PostPosted: Tue Oct 31, 2023 11:12 am    Post subject: Re: Kubel 2021 Reply with quote
Excellent build. Thank you for posting.
I’m curious about your seats. What make and model are they??
Did they attach to your existing rails?
Also, are your fuel lines custom made??
Thanks, John
1997 Eurovan camper
1974 Thing with a 1776
San Clemente, CA
fastmc25
fastmc25 is offline
PostPosted: Tue Oct 31, 2023 12:48 pm    Post subject: Re: Kubel 2021 Reply with quote
Thanks. The seats are from Rugged Ridge. Purchased on Amazon. Seat mounts and sliders are from Speedway.com.
Fuel lines i made. 😎
Peace,
Paul
Johnnyw
Johnnyw is offline
PostPosted: Tue Oct 31, 2023 6:36 pm    Post subject: Re: Kubel 2021 Reply with quote
Paul,
Thanks for the information.
John.
1997 Eurovan camper
San Clemente, CA
fastmc25
fastmc25 is offline
PostPosted: Thu Nov 02, 2023 1:48 pm    Post subject: Re: Kubel 2021 Reply with quote
Working great! Took a bit to get the pump primed but puts out very nice heat.
I will need to install a downpipe on the muffler though. 😎. The kit comes with a 10L tank which i hated. Too odd shaped to work for me so i changed to a 7L tank that fits much better.
I will be painting the heater cover black. 😳
Peace,
Paul
ncpi
ncpi is offline
PostPosted: Fri Nov 17, 2023 8:41 am    Post subject: Re: Kubel 2021 Reply with quote
Really nice work! I am reinstalling an original heater in my Thing. A lot of the holes in the Frunk were fiberglassed and hidden. I have found all the heater related ones, but how is that forward facing evap line from the canister running through the Frunk? I can't figure out how (where) it passed through to get under the chassis?
Thanks,
Bill
fastmc25
fastmc25 is offline
PostPosted: Fri Nov 17, 2023 2:04 pm    Post subject: Re: Kubel 2021 Reply with quote
There’s a hole beside the fuel tank underneath the heat shield for the heater exhaust.
Peace,
Paul
ncpi
ncpi is offline
PostPosted: Fri Nov 17, 2023 2:21 pm    Post subject: Re: Kubel 2021 Reply with quote
I was looking for where the evap line ran. Don't think I would want to route it through the hole for the heater exhaust, that might get a bit warm Smile
I did find that i could route it through the hole for the heater fuel line and fuel pump wires. That seems to work out pretty well.
fastmc25
fastmc25 is offline
PostPosted: Fri Nov 17, 2023 2:24 pm    Post subject: Re: Kubel 2021 Reply with quote
That’s where I meant
Peace,
Paul
fastmc25
fastmc25 is offline
PostPosted: Fri Nov 17, 2023 2:27 pm    Post subject: Re: Kubel 2021 Reply with quote
I wrapped my exhaust with the header wrap. Helps reduce some of the heat in the Frunk
Peace,
Paul
ncpi
ncpi is offline
PostPosted: Fri Nov 17, 2023 3:26 pm    Post subject: Re: Kubel 2021 Reply with quote
Thanks Paul. The wrap is a good idea!
doublecanister
doublecanister is offline
PostPosted: Sat Nov 18, 2023 7:29 am    Post subject: Re: Kubel 2021 Reply with quote
very nice install there Paul.
Maybe a good suggestion for the Things with missing heaters.
Shame they don't make a gasoline one to use the Thing fuel source but you made it work! Applause
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8
KAmes
KAmes is offline
PostPosted: Sat Nov 18, 2023 2:26 pm    Post subject: Re: Kubel 2021 Reply with quote
This one's gasoline but trust me you don't want to pay what it cost, I probably should have bought a diesel one also.
fastmc25
fastmc25 is offline
PostPosted: Wed Nov 29, 2023 6:02 am    Post subject: Re: Kubel 2021 Reply with quote
Yeah. The webasto is nice but very pricey. I’m still going to go through my eberspacher heater and seeif it’s serviceable.
Peace,
Paul
fastmc25
fastmc25 is offline
PostPosted: Thu Apr 04, 2024 12:29 pm    Post subject: Re: Kubel 2021 Reply with quote
Trying out a Tri-Mil sidewinder on Thing 2. Hangs lower than i like but is still not lower than the bottom of my engine sump. Sounds good and does run quieter and smoother than with the Tri-Mil bologna tube exhaust. Will know more when i get some drive time and tuning done. 😎
I may shorten the chrome tip.
Peace,
Paul
Heiferman
Heiferman is offline
PostPosted: Thu Apr 04, 2024 4:55 pm    Post subject: Re: Kubel 2021 Reply with quote
I have been quietly following along. I am very impressed.
fastmc25
fastmc25 is offline
PostPosted: Thu Apr 04, 2024 5:05 pm    Post subject: Re: Kubel 2021 Reply with quote
Thanks. It’s a evolutionary project 😂😂
Peace,
Paul
Page 3 of 4
