biffidum Samba Member
Posted: Tue Apr 16, 2024 3:45 pm Post subject: captured nut? |
I am attempting to replace the shocks in the rear of my '69 SQB. It appears the bolt for the top of the shock threads into a spinning captured nut inside the upper portion of the subframe. Is there a trick to this, or am I cutting the frame open to access and welding it shut again post R&R? |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22442 Location: Kimball, Mi
Posted: Wed Apr 17, 2024 2:44 pm Post subject: Re: captured nut? |
I'll report back. I had hoped there was some secret with respect to the bump-stop pad being removable, but it appears not to be. |
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3698 Location: San Jose, CA
Posted: Wed Apr 17, 2024 3:25 pm Post subject: Re: captured nut? |
Shortest Bobnotch reply ever? _________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
Posted: Thu Apr 18, 2024 9:54 am Post subject: Re: captured nut? |
Turns out VW spot welded a simple "wrench" over the internal nut in the upper rear shock tower. I guess they didn't have wire or rod welding capability on their assembly line, only spot welding which would explain this poor approach to a captured nut. Once rusted the bolt spins the nut and the "wrench". Another scenario (likely mine) the bolt rusts onto the bush inside the upper shock. When you spin the bolt it can't move outwards, so the internal nut moves inwards forcing itself out from the "wrench"
For the love of Mike people, please replace your shocks if they look at all rusty. These look to be original and well composted. |
Posted: Thu Apr 18, 2024 11:09 am Post subject: Re: captured nut? |
biffidum wrote: |
Looks like you fixed it. I do agree with you on the shocks needing to replaced every so often thing, especially if you live in the "salt belt" or near the ocean. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
