Jimone Samba Member
Posted: Sun Mar 17, 2024 7:04 am Post subject: Re: Jims 1952 |
Windows are in! i did not have any luck with the piano wire method. kept ripping rubber. 4 unsuccessful attempts later and on my second set of rubber i decided to change it up. i wedged them in with a little pry bar. worked great.
i broke one of the back windows. i was hitting it with a rubber mallet. im still not sure what i thought was going to happen. anyway i got a replacement from sgmalt46 super fast. thanks Steve for saving the day!
_________________ november 1952 ragtop
november 1954 single cab |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 10004 Location: Huntington Beach, CA
Posted: Sun Mar 17, 2024 9:13 am Post subject: Re: Jims 1952 |
Very nice updates! The car looks ready for a road trip! Where are you going on the first voyage? _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Jimone Samba Member
Posted: Sun Mar 17, 2024 12:31 pm Post subject: Re: Jims 1952 |
VW_Jimbo wrote: |
Very nice updates! The car looks ready for a road trip! Where are you going on the first voyage? |
Ha! i havent thought about that yet. i guess the first one will be some sort of super cautious trip up and down the driveway. followed by a terrifying lap around the block. after that....i dont know yet. i plan to drive it till the wheels fall off and then put the wheels pack on and drive it some more. _________________ november 1952 ragtop
esde Samba Member
Joined: October 20, 2007 Posts: 5979 Location: central rust belt
Posted: Mon Mar 18, 2024 6:05 am Post subject: Re: Jims 1952 |
Excellent work Jim. Sucks about the back glass, but you got it done. I tried a number of things for the glass over the years and did eventually settle on thin weedwhacker cord.
The first few trips are always nerve wracking, I always have a tote with a full assortment of tools on the passenger floor, to fix the little things that pop up. The first big smile and wave you get from a stranger as you drive by is the most rewarding.
SD _________________ modok wrote:
western auto Samba Member
Posted: Mon Mar 18, 2024 6:14 pm Post subject: Re: Jims 1952 |
best method i have found for vw window installation is silicone spray on the body and outside of the rubber- a helper to push in in the hole and hold light pressure on it/ best rope is weed eater pull start rope not the crappy plastic string for grass the actual starter rope - the high quality black stuff that looks like paracord |
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 24260 Location: Southeast USA
Posted: Mon Mar 18, 2024 6:18 pm Post subject: Re: Jims 1952 |
I like everything you're doing. Stick with it!
As for the old case, throw it away. It's junk. You also have plenty of replacements!
With all the parts you have, you could probably barter for some of the work! _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
Jimone Samba Member
Posted: Tue Mar 19, 2024 6:24 am Post subject: Re: Jims 1952 |
esde wrote: |
I always have a tote with a full assortment of tools on the passenger floor, to fix the little things that pop up. |
i have a start to that kit. i imagine that will be something that grows and changes as i get to know the car better.
western auto wrote: |
thats the method that i called piano wire. i watched a bunch of videos and tried it. i dont understand what everyone is on about. took me a long time to get the wire in. i didnt have much luck getting it to lip over either. the cord tended to pinch the rubber against the car. the cord broke. the cord tore the rubber. i tried several types of cord.
since others are having success with that method you can assume my issues are operator error. since i wasnt having success that way i decided to attempt it differently.
what i did was pop the lip over using a small pry bar and then chase the lip around prying gently. all the stuff about silicone and an extra set of hands are the same. just using a pry bar to get it over the lip instead of weed whacker cord. i found it easy to control. i didnt have to feed anything into the tracks. the thing i was using to lever didnt break and it didnt damage my rubber. it worked well for me. maybe it can for someone else too.
a word of caution - the prybar can slip and damage things like the headliner. also prying against paint can and will damage it.
Blue Baron wrote: |
With all the parts you have, you could probably barter for some of the work! |
tyty - that case was the only 25hp out of the bunch. i think i may end up turning it into a coffee table or something. who knows.
its funny that you mention bartering for work. i sent all that 36hp engine stuff off to Joe Ruiz in california. we worked out a deal. im going to end up with a longblock. the case he is planning on using is a ~week older than the one i sent out there.
Toolpouch001 wrote: |
thanks for sharing with us |
for sure. thanks for joining me on this adventure! _________________ november 1952 ragtop
ddutch Samba Member
Posted: Thu Mar 21, 2024 6:07 am Post subject: Re: Jims 1952 |
Jimone wrote: |
I like the idea and I can understand why you want to re-use it and give it a special function/place like that. It has been blasted clean and it looks great, even with the holes and damage, and it will make a nice reminder of all the parts your dad had gathered. |
Jimone Samba Member
Posted: Tue Mar 26, 2024 7:42 pm Post subject: Re: Jims 1952 |
put the door panels and handles in
dont forget the little dampeners. easy to forget.
looking like a car. that cant stand
better take it apart
the beam was sitting 2" high on the drivers side
get to rework the leaky steering box while im in here
got it clean enough to see teh number finally. looks like this was an original part.
looks like the link pins are pretty toast
fun stuff
Jimone Samba Member
Posted: Wed Apr 03, 2024 4:38 pm Post subject: Re: Jims 1952 |
got the beam clean and lubricated. everything moves fine. i think the trailing arms on the driver side has frozen up from some hardened grease.
started getting ready for king and link pins. pulled them off the brake backing plates
got the link bushes out. i dont have a press so it was time for some precision work with the sledge. king pins are still being stubborn.
new seals for the steering box. this one is dated 1960. no biggie from my perspective.
Jimone Samba Member
Posted: Sun Apr 14, 2024 6:00 am Post subject: Re: Jims 1952 |
i took the front beam off of the car because the drivers side sat several inches high. i couldnt install the shocks or the torsion snubber. after pulling everything apart and lubricating the beam it snapped back to place. it was stuck from dried up grease. i ran it through with solvents. the seals are fine. the bushings are fine. im not going to re-bush it at this time. it - shockingly - doesnt need to be done.
as i have gone through the front it seems someone had done some but not all of this work previously. this car was flat towed from wyoming to kansas city in the 1980s. i think it got some front axle work right before that. for instance it has new wheel bearings.
anyway...i blasted everything up with my handy dandy soda blaster.
masked up the beam
i spritzed it with some paint as a rust preventative.
all the shocks and snubbers fit. hooray!
and here are the brakes starting to get assembled. im still working through the differences between november 52 brakes and the 1954+ stuff thats available on the repop market. at this time im building something with 54+ pads because they are readily available. im going to wear this set out anyway. all the technically correct stuff will be saved and sorted out at a later date.
esde Samba Member
Posted: Sun Apr 14, 2024 6:31 am Post subject: Re: Jims 1952 |
Great work Jim.
I've found very few cars that need inner bushings, but the bearings will get wrecked if not greased.
ddutch Samba Member
Posted: Mon Apr 15, 2024 1:55 pm Post subject: Re: Jims 1952 |
The work on the front beam and the brakes is looking good. The finish on the beam looks very matte, what kind of protection did you use for it? |
Jimone Samba Member
Posted: Tue Apr 16, 2024 8:22 am Post subject: Re: Jims 1952 |
thanks guys-
i used a rustoleum high heat paint. i just wanted to put something on it to keep the exposed metal from rusting. should be fine. looks kinda cool. shows grease with great contrast. obviously not stock at all. _________________ november 1952 ragtop
ddutch Samba Member
Posted: Wed Apr 17, 2024 4:15 pm Post subject: Re: Jims 1952 |
Thanks. It seems very appropriate. |
Jimone Samba Member
Posted: Fri Apr 19, 2024 6:04 pm Post subject: Re: Jims 1952 |
Made more progress.
i pulled out the heater boxes and started working on them.
the top set are the ones for the bug.
there arent many things ive cleaned up that were dirtier. the little tabs on the J tubes are one of the small unique features of the early parts. the 3 holes across the front are another.
this goo is like the size of a plum. i think i ended up with maybe a cantaloupe or so
they came out pretty nice. they are a bit beat up so they still need some fine tuning but not to shabby.
picture WITH return springs... the one i posted earlier didnt have them
took a fun picture of some engine bits getting sorted out
oh...and cranberry sauce. like a lot of cranberry sauce.
Jimone Samba Member
Posted: Thu Apr 25, 2024 5:47 am Post subject: Re: Jims 1952 |
cleaned up my seat frames this week
here they are back in 2021.
i blasted them up and detail cleaned them last year. claned them a bunch and hit them with some paint
kept the maker tag
pulled the steering coulmn while i had the steering box out. cleaned up the horn contacts
painted it gave it new rubber
updated cabin pic
also we got added to the Hoffman Registry. Smiley is car #34.
fun fact about hoffman splits - there were just over 2000 split bugs imported to the us by hoffman. there are estimates of as many as 2200 split bugs in the us today. the split bug is more numerous in america today than it was at the end of production in 1953.
the turn signal housing wants you to have a nice weekend!
Posted: Fri Apr 26, 2024 11:15 pm Post subject: Re: Jims 1952 |
Looks great! And I am having a great weekend! _________________ Jimbo
TDCTDI wrote: |
tehillah1 Samba Member
Joined: August 23, 2009 Posts: 281 Location: Colorado
Posted: Sat Apr 27, 2024 9:44 am Post subject: Re: Jims 1952 |
Jimone wrote: |
i like the way the bug looks, so for at least a while its going to keep its current appearance. its got a lot of personality. today i dont think i will ever paint it but who knows what tomorrow will bring.
one thing is for sure. nobody else has a bug like mine. |
I'm of a similar mind in regards to keeping the current appearance, whatever that may be...I'm not trying to build a show winner,my goal is to drive my bug again.
I really appreciate your diligence in putting this car back on the road and documenting it for the rest of us. I just read through the whole thread again just because its such a great story. |
Jimone Samba Member
Posted: Tue Apr 30, 2024 5:02 am Post subject: Re: Jims 1952 |
thank you Jim and also Jim!. i love both of your threads as well. i reference them often.
i fixed up some headlight buckets this week. i havent been able to find an answer to what headlight a hoffman nov 1952 would have been sporting when it left the dealership.
i have a number of headlight buckets but these were the ones that i had that seemed to embody the spirit of this car. they are euro headlights that have been modified into sealed beams. they didnt have lenses so i added the best set of glass i had on hand which was a decent looking (but shameful) set of sb 19 20 21s.
today i woke up to an email from Joe Ruiz that should have come with an explicit content warning. ill make a full post about that later but i thought you guys might like a teaser
