how do the mice get in?
RatCamper
RatCamper is offline
PostPosted: Tue Dec 13, 2011 2:12 pm    Post subject: Reply with quote
What's the point of normal traps if you have a mouse problem? you'll never sleep! I got sick of empting and resetting them every 5-10 minutes plus the hunt whenever the trap failed to do the job and the mouse dragged it off somewhere.
At least there are the bonus times when a trap gets a 2 or 3x multiplier bonus, or two traps catch the one mouse. it's a real fist pumping victory moment.
Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002.
ewdb92
ewdb92 is offline
PostPosted: Tue Dec 13, 2011 7:02 pm    Post subject: Reply with quote
kevin77westy wrote:
I've heard of some people having good luck with those little sonic noise makers that are suppose to keep them away. Anybody here tried those?
I've been following this thread with interest because I just got rid of an infestation in my attic. I have sonic noise makers plugged into the crawl space under the house and in the attic and their effectiveness may depend on brand (I think mine are decker, but do not hold me to that). Last winter, while working on the plumbing, I saw a mouse run right under one and this past week found the most effective place to put a trap was under the noise maker in the attic Rolling Eyes So I'm not a believer at the moment. The only thing that finally got rid of all the mice was poison. I hate to go that route but had run out of options.
Erik
71 Camper
http://zerotosixtyeventually.wordpress.com/
curtis4085
curtis4085 is offline
PostPosted: Tue Dec 13, 2011 7:29 pm    Post subject: Reply with quote
How about putting the bus up on jack stands and coating the jack stands with a grease so the mice just slide down when attempting to get inside.
On different note. Best to make sure grass is short as possible in the area your parking the bus use moth balls, dryer sheet, sonic plugs, and atom bombs and you should be fine. plug all holes
Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com
Hoody
Hoody is offline
PostPosted: Tue Dec 13, 2011 11:08 pm    Post subject: Reply with quote
Hastingsreserve.org mice in cars. Simple, inexpensive, problem solved.
SGKent Premium Member
SGKent is offline
PostPosted: Tue Dec 13, 2011 11:31 pm    Post subject: Reply with quote
Spilled my glass of wine after reading that I laughed so hard. The image of a mouse trying to climb up a greased jack is something out of an Inspector Clouseau skit or Coyote vs Road Runner scene. especially a pair of mice - one big fat one and one thin short one pushing on the fat one to lift him up while he keeps slipping and falling down on the thin mouse. One more push Frank - we almost got it that time ....
brookmp
brookmp is offline
PostPosted: Wed Dec 14, 2011 12:29 am    Post subject: Reply with quote
Razz Razz Razz
1968 Westfalia Campmobile
1971 Double Cab Pick-up
1974 Standard Beetle
RatCamper
PostPosted: Wed Dec 14, 2011 1:52 am    Post subject: Reply with quote
Shame the little buggers can jump like superman and walk on the ceiling.
I saw a good project on hackaday I think it was ages ago with an automated sentry gun (paintball). That'd do it, although a sentry like from the Alien movies would be far more satisfying, if not a little bit of overkill.
Blaubus
Blaubus is offline
PostPosted: Wed Dec 14, 2011 2:51 pm    Post subject: Reply with quote
finally read the Hastingsreserve.org advice and it seems sensible:
to put up a perimeter of 24" aluminum flashing around the vehicle. the mice cant climbe the slippery metal. but they dont answer the question i have: how does that defeat their habit of burrowing under that perimeter?
Blaubus
Blaubus is offline
PostPosted: Wed Dec 14, 2011 2:55 pm    Post subject: Reply with quote
brookmp wrote:
Razz Razz Razz
dont laugh too hard, it might actually work.
SGKent is offline
PostPosted: Wed Dec 14, 2011 4:42 pm    Post subject: Reply with quote
RatCamper
PostPosted: Wed Dec 14, 2011 5:06 pm    Post subject: Reply with quote
SGKent wrote:
More like:
But the obvious answer is:
curtis4085
PostPosted: Wed Dec 14, 2011 5:13 pm    Post subject: Reply with quote
was hoping it would bring someone a laugh Very Happy
Special Thanks to:
kevin77westy
kevin77westy is offline
PostPosted: Wed Dec 14, 2011 5:15 pm    Post subject: Reply with quote
I agree that is probably useless unless its on a slab. Kinda seems like a PITA too but I'd be game if I knew it worked. Guess its time to get under the dubs and find/seal the holes. Weird thing is that I have never found evidence of them in my shop but they love the VWs. Tighter spots I guess.
Blaubus
Blaubus is offline
PostPosted: Thu Dec 15, 2011 10:48 am    Post subject: Reply with quote
well, there may be a way to make it work.
instead of building a perimeter around the whole car, build a flashing perimeter around each wheel- nailing flashing to a treated 2 X 12 that sits atop a 4 X 8 X 16 cinder block. i would have to make sure the rear shocks are fully within the perimeter, since they hang low.
Blaubus
Blaubus is offline
PostPosted: Thu Dec 15, 2011 10:51 am    Post subject: Reply with quote
jeffsbugs
jeffsbugs is offline
PostPosted: Thu Dec 15, 2011 11:16 am    Post subject: Reply with quote
I heard that dryer sheets help keep them out. Never tried this but apparently they don't like the smell.
I also found this interesting trap. Very Happy
http://www.frugal-living-freedom.com/mouse-traps.html
Jeff
'73 Westfalia, rebuilt 1700, dual OG solex - 3500 miles and counting
'62 Baja
Blaubus
Blaubus is offline
PostPosted: Thu Dec 15, 2011 11:50 am    Post subject: Reply with quote
Jeff
just as with humanz, some mice are more hearty than others and dont mind the smelly stuff. and there will always be creatures that arent interested in walking into a trap. research done by hastings reserve showed that to be the case.
SHBPrincipal
SHBPrincipal is offline
PostPosted: Sun May 12, 2024 1:55 pm    Post subject: Re: how do the mice get in? Reply with quote
I have been chasing my tail with this one too. That smell!!
I have traps set in the garage but have only caught one mouse and no food is kept in the van over winter. So I think I am chasing the smell of one rogue dead rodent.
I took out the interoir this winter in search of a dead mouse body and no luck.
Years ago I removed the main heater channel and it was full of mouse nest, dead mice, mice poop, you name it. Gross. Because of that it was rusted beyond.
At that time I replaced the heater tube with a galvanized piece of duct, cleaned and painted all the metal heater tube pieces. Put it back toegther.
One place is the floor vent between the two front seats, facing backwards. I put a metal screen over that.
I am wondering if they are getting in through the heater dump ports. I may clamp another piece of screen over that. But they also may be getting in through the cooling fan fins. Not much you can do about that aside from keeping a loaded trap in the engine bay.
Ill take that main tube off again and see if something made its way in there.
RWK
RWK is offline
PostPosted: Sun May 12, 2024 7:06 pm    Post subject: Re: how do the mice get in? Reply with quote
The mice here eat Irish spring soap, so they don't mine the smell, hopefully soap will kill them by ingestion.
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
SGKent is offline
PostPosted: Mon May 13, 2024 11:55 pm    Post subject: Re: how do the mice get in? Reply with quote
they have a special door they use. It is right under the battery door. Laughing
Page 3 of 4
