Painting for a idiot
Nodnol
Nodnol is offline
PostPosted: Tue May 07, 2024 7:44 pm    Post subject: Painting for a idiot Reply with quote
Hi I'm trying to learn how to repaint my 72 super beetle, it's got a good bit of rust and is going to need some body work, but I have no idea how to do anything. I really don't want to mess this up, can anyone tell me about the process and what products I need?
Evil_Fiz
Evil_Fiz is offline
PostPosted: Wed May 08, 2024 11:38 am    Post subject: Re: Painting for a idiot Reply with quote
Many factors will influence your course of action. Some examples are:
- How deep do you want to get into the project?
--- Full strip to bare metal or scuff and spray?
--- Show quality or "Good enough"?
--- Spray at home or rent a booth?
- What equipment and tools do you have?
- What equipment and tools are you willing to buy?
- How long are you willing to take to finish your project?
- What is your budget?
To do all the work at home, at a minimum you will need:
- An air compressor
- Paint gun and painting supplies
- Primer, filler. and paint
- Welder if replacement metal is needed
- Body working tools (hammers, dollies, sanding blocks Etc.)
- Lots of time to spend learning and practicing.
This is an oversimplified reply. More specific questions from you will get better answers from us.
Emil
“…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted
Nodnol
Nodnol is offline
PostPosted: Thu May 09, 2024 3:07 am    Post subject: Re: Painting for a idiot Reply with quote
Ok thank you, I know that I want to use something like vp2050 primer and some of Eastwood's products like ther gide coat and rust killer, but I don't know what kind of body filler or top coat I need, I want to do panel to panel blocking, hopefully that helps keep me from messing it up.
I know I need a da sander to get the paint off, but I don't know how many coats I need to apply and what grit of sand paper I should use.
esde
esde is offline
PostPosted: Thu May 09, 2024 4:54 am    Post subject: Re: Painting for a idiot Reply with quote
Full stop.
Watch a ton of videos, and talk to as many people that do this for a living/ hobby as you can.
What you are proposing is a huge undertaking. Which is fine, lots of us do it. Laughing
BUT, there are tons of projects out there that were started by people with big aspirations like yours, and they sit unfinished. It is doable, but it is a TON of work. And there are so many products, and processes.
It's too easy to get in over your head with bodywork, especially if you've never done it before.
Fix the front fenders, and see what's involved before tearing farther in. If it doesn't scare you then go farther.
modok wrote:
Nodnol
Nodnol is offline
PostPosted: Thu May 09, 2024 10:50 am    Post subject: Re: Painting for a idiot Reply with quote
Alright, but the issue I'm having is that I need to replace the window scrapers because at the moment ever time it rains there's about of inch of standing water in the doors, and I don't want to have to take it apart twice. There's a good bit of rust damage I need to fix like a spot really close to the foam on the back left and some cracking on the right side.
https://youtu.be/G6JpZP3xsd0?si=ErMSU7g2rGhr0MPB
bomberbob
bomberbob is offline
PostPosted: Thu May 09, 2024 4:31 pm    Post subject: Re: Painting for a idiot Reply with quote
There should be drains in the doors, possibly they are blocked. You should not have standing water in the doors. I guess having standing water means they are not full of rust holes (yet).
I believe I see signs of death foam back in the rear quarter. This is repairable, but its a lot of work. There are posts in this forum, and other forums on the samba showing how people have repaired rust damage like this. Your photos do not show some of the other common rust areas, heater channels, floor pans, and that area under the seat where the battery sits.
Window scrapers, there are probably posts with photos on how to replace these as well. This is the place to be if you want to repair your bug yourself, but its going to be a lot of work.
1968 Beetle torn apart again
1990 Jetta GLI megasquirted, burning E85 (currently in storage)
2004 Jetta turbo GLI
Marion, Iowa
Nodnol
Nodnol is offline
PostPosted: Sat May 11, 2024 9:15 pm    Post subject: Re: Painting for a idiot Reply with quote
I checked the door drains and they where clogged, I'm not sure if it's possible but I would like to keep most of the paint as the Rust is limited to small spots and on some parts like the hood and fenders there's only 1 or 2 spots of rust, I want to go ahead and fix the body damage caused by rust but I don't know what kind of body filler and rust neutralizer to use.
Also if it is possible to keep the old paint then how would I bring back the shine without it being obvious that it's been repainted in spots?
67ctbug
67ctbug is offline
PostPosted: Sun May 12, 2024 11:18 am    Post subject: Re: Painting for a idiot Reply with quote
What kind of equipment do you have? What you're proposing, for someone with no tools and experience, will take years and probably $10,000. to prep the car and spray it you'll need at least two spray guns, a minimum 60 gallon compressor, DA sander, die grinders, cut-off tools, maybe a belt grinder. Then you need the body hammers, dollies, a welder with gas, tons of vice grips, sanding blocks, sand paper for DA and blocking, etc.
Forget about VP2050, Eastwood products, and panel to panel blocking right now. You'll get so focused on wanting the product the people on TV and Facebook use vs. a product that will get the job done as well if not better. You should be worried about what metal you need to buy. Personally I prefer BASF products (glasurit, RM, Limco), PPG 2050 has great reviews but is not a true epoxy, I prefer a real epoxy and a real high build primer. Admittedly, I've never used the VP2050.
Watching your video, that car has some messed up and spots and YOU WILL end up doing things twice if you've never done this before. You aren't going to like how things turn out and you'll want to redo them. You're going to find tons of different fillers and thigns, avoid Bondo brand. I've used Evercoat, 3M, Upol, Fast Line, and a few others. It's all about the same to me. I like 3M Platinum Plus. I normally use a fiberglass filler over my weld areas to help prevent any pinholes I missed. Body and paint is a big undertaking and there are a ton of products out there to get it done.
'67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote:
...or the PO envied the terrorists' bus in "Back to the Future". Laughing
mukluk wrote:
He's fine, just waiting for the dragon in winklepickers to move out of his lane.
Nodnol
Nodnol is offline
PostPosted: Sun May 12, 2024 12:56 pm    Post subject: Re: Painting for a idiot Reply with quote
Right now all I want to do is patch up the rust holes, after that I'll look into painting. But for now all I want is info, would it be possible to "revive" the Old paint l, while still sanding and repainting the spots with surface rust? And would the repainted spots match the original paint?
Busstom
Busstom is offline
PostPosted: Sun May 12, 2024 3:51 pm    Post subject: Re: Painting for a idiot Reply with quote
I like this place https://www.autobody101.com/forums/
cory464 wrote:
Evil_Fiz
Evil_Fiz is offline
PostPosted: Mon May 13, 2024 1:55 pm    Post subject: Re: Painting for a idiot Reply with quote
I was in your shoes a few years ago and will try to summarize my experience for you. My intention is to encourage and show you that what you want is possible, but It is also daunting at times, often frustrating, sometimes depressing, but ultimately rewarding.
Timeline
- purchased the car in 2015-09
- finally had it fully stripped to bare metal in 2018
- finally had my rotisserie designed and built in 2020
- had most of the metalwork done by 2022
- spent 2 years researching the PRIMMER and FILLERprocess at the SPI forum
- FINALLY got the car in epoxy primer in 2024-05
- So far I:
- spent about $4000 on tools, equipment, and supplies
- spent ~40 hrs metalworking one of my doors to remove dents and a crease
- Spent ~30 hrs designing and building my rotisserie
- spent 2 days building a makeshift paint booth in my garage
- bought most of my tools at Harbor Freight with good results
- taught myself to weld sheet metal and did repairs
All the advice provided in the ptrvious posts is spot on and worth adopting. You CAN do this. You CAN learn what you don't know. You CAN finish your project. Make a high-level plan, break it up into smaller, attainable projects, tackle only ONE sub-project at a time, and Stick with it until you are content with the results you achieve.
The best resource I found for painting and body-working advice is the Southern Polyurethane Inc forum(http://www.spiuserforum.com/index.php). SPI also makes outstanding products at very reasonable prices. Everything I know about paint and bodywork was learned over two years on that forum. I used SPI epoxy as primer, and will use more of their products as my project progresses. The best advice I can provide is to ask questions, do your research, and look for three different sources that agree with the process you want to employ for any given task. Don't listen to anything I say unless you find at least two other people/sources to corroborate it.
It will take more time than you think, will cost more than you budgeted, and will be more rewarding than you ever imagined.
Emil
kiwighia68
Nodnol
Nodnol is offline
PostPosted: Tue May 14, 2024 5:28 am    Post subject: Re: Painting for a idiot Reply with quote
I plan on sanding and grinding out the rust spots and putting some primer on it to hold off the rust till I get around to painting it. That should be fine right?
Evil_Fiz
Evil_Fiz is offline
PostPosted: Tue May 14, 2024 6:44 pm    Post subject: Re: Painting for a idiot Reply with quote
The advice you got on the other forum was sound, harsh, but sound. If it were me, I would "Keep it dry and enjoy it" until you have the time and money to do it right.
If you forge ahead with temporary rust mitigation, use MasterSeries Silver (MS) to prime the metal. Remove all the rust you can, using all the methods you need, get the metal as rust-free as possible, treat it with phosphoric acid (scrub with Scotch-Brite pads as you apply the acid), neutralize the acid, then apply 2 coats of NasterSeries followed by your top-coat of choice. (Sister Mary Francis, that was a long sentence.)
NOTE: Don't mention MasterSeries on the other forum, they are not fans.
I used 1 coat of MS Silver over bare metal treated with phosphoric acid and top-coated it with 3 coats of SPI epoxy. I would have used only epoxy but it does not play well with acid and I had already treated the car with acid by the time I learned that. If you can get enough of the rust off and treated, the MS should buy you some time. Contact the MS vendor at nomorerust.com or give them a call. They are very helpful and can guide you in your efforts.
Emil
kiwighia68
bomberbob
PostPosted: Wed May 15, 2024 5:37 pm    Post subject: Re: Painting for a idiot Reply with quote
I have used several quarts of master series, I love it. On my beetle, and then on my Jetta. Coverage, sandability, all that is top notch, the only thing I don't like about it is once you open the can and expose ambient air to the contents of the can, it starts to cure.
I actually have a brand new quart in my garage, when I open it and pour some out, I am going to use one of those food sealers with the plastic bag to seal the remains in the can, and pull a vacuum on the bag, and seal. I hope this will keep whats left in the can from curing and going to waste.
Marion, Iowa
Evil_Fiz
Evil_Fiz is offline
PostPosted: Fri May 17, 2024 4:57 pm    Post subject: Re: Painting for a idiot Reply with quote
bomberbob wrote:
...I actually have a brand new quart in my garage, when I open it and pour some out, I am going to use one of those food sealers with the plastic bag to seal the remains in the can, and pull a vacuum on the bag, and seal. I hope this will keep whats left in the can from curing and going to waste.
Another option is a mixing lid. You can get them for under $20 from a local paint jobber. You open the can, pop the mixing lid on, and use a drill to mix the paint at a slow speed. When you pour it out, you only open the pouring spout a little, so the exposure to the elements is limited.
Once done painting, you put the can, with the lid still installed, into a plastic bag or zip-loc and seal it up. BE FOREWARNED, the MS Silver will try to glue the slider on the spout so it is a good practice to give it a quick slide every hour or so until the paint on the edge dries. If it cures on the spout slide, you may not get I open again.
I love my mixing lids, they are cheap and reusable. Buy them from a paint jobber rather than Amazon, they are much cheaper that way. I paid $38 on Amazon for a Gallon lid (2024) but only $17 at Single Source. The quart lid was $12
Emil
kiwighia68
tehillah1
tehillah1 is offline
PostPosted: Tue May 28, 2024 2:53 pm    Post subject: Re: Painting for a idiot Reply with quote
Evil_Fiz wrote:
treat it with phosphoric acid (scrub with Scotch-Brite pads as you apply the acid), neutralize the acid, then apply....Emil
I've stepped into the paint classroom...this thread has a lot of useful info for us noobs...Emil, how do you do about neutralizing the acid prep?
What are the problems with applying epoxy primer after the neutralized acid prep? Is there a way to mitigate these problem and go with epoxy primer w/out applying ms?
viiking
viiking is offline
PostPosted: Tue May 28, 2024 5:11 pm    Post subject: Re: Painting for a idiot Reply with quote
The simplest way after reapplying the Ospho/phosphoric acid is to just wash with water COPIOUSLY with a bit of a scrub with scotchbrite pad. Not just a rinse, a good wash. Use a hose , pressure washer or whatever running water you have.
Once you’ve gone over the car then dry it off completely but wear gloves to prevent oils from your hands contaminating the surface. Use a garden blower to get the water out of the seams then follow up with a heat gun, hair dryer and make sure the surface is DRY.
Because the surface is completely clean it is now reactive and it WILL flash rust. How quickly it does so depends on the temperature and humidity in your area so you need to paint within a couple of hours or so of doing this step. If you cant achieve this then consider doing smaller parts of the car and just repeat the acid wash, water wash and complete dry then paint immediately.
Now you could go to the extent of washing the car with an alkali such as bicarbonate of soda to more quickly neutralise the acid but you still have then to wash off the residual neutralised sodium salts. So IMO it’s just easy to wash with lots of water not to mention it’s cheaper,
Most epoxy paint suppliers will say it is not recommended to paint with epoxy over an Ospho/phosphoric acid treated surface. But they need to say that because MANY MANY people just don’t read the instructions and the manufacturers have to deal with the bad press that comes with failed paint surfaces, so out of a degree of caution they say “don’t”.
There’s an interesting experiment on the SPI forum of someone who divided a hood into four and painted over un-neutralised, neutralised, smooth and rough sanded metal to see the difference. From memory he found no effect. I’ll try and find the link separately.
viiking
viiking is offline
PostPosted: Tue May 28, 2024 5:36 pm    Post subject: Re: Painting for a idiot Reply with quote
I can't find the article I was talking about, but this one is worth reading.
http://www.spiuserforum.com/index.php?threads/how-to-neutralize-ospho.3973/
tehillah1
PostPosted: Wed May 29, 2024 6:46 am    Post subject: Re: Painting for a idiot Reply with quote
This is exactly the information I've been looking for. The SPI forums are a deep resource...Thanks all for pointing me in the correct direction.
Evil_Fiz
Evil_Fiz is offline
PostPosted: Fri May 31, 2024 3:29 pm    Post subject: Re: Painting for a idiot Reply with quote
I was out of town so sorry for the delay in responding. The post above does an excellent job of answering your questions. I will add to it in-line.
One trick I learned on the SPI forum is to use ZEP Purple Degreaser, mixed at its strongest (lowest) dilution as the initial acid rinse. Apply it with a sprayer and let it wash over the treated area, scrub it while it is still wet, then completely rinse it off. Repeating this step is not mandatory but recommended. And don't forget to RINSE,RINsE,RINSE. The advice above is spot on.
ONLY USE ELECTRIC drying tools. DO NOT USE any gas-powered ones. A long bake in the mid-day sun will also help get the water out.
I don't know about all epoxies, but SPI epoxy has some rust inhibition and will apply well over MINIMAL flash rust. In the ideal world we could all apply epoxy over virgin, un-rusted metal; for the rest of us, good enough is usually more than enough.
Zeo Purple Degreaser is alkaline and will wash off, with enough water and agitation, without any of the ugly plaque buildup you get from soda.
I did not know about the experiment on the SPI forum so I did my own and posted it on TS earlier this year. I did the exact setup but added MS Silver into the mix. As stated, the epoxy stuck and was a bitch to remove. Here is a link to my adhesion test post: MasterSeries Silver, SPI Epoxy, and a head to head adhesion test https://www.thesamba.com/vw/forum/viewtopic.php?t=789397&highlight=adhesion+test.
I will add one last bit of advice. You can never have metal that is TOO CLEAN for paint. After treating the metal with acid and properly rinsing it, you must sand it with 80# sandpaper (Mandatory for SPI epoxy and probably others). The sanding will provide an adhesion-promoting profile on the metal and, as a byproduct, will remove the surface rust. After sanding, wipe the metal down with solvent-based wax and grease remover followed by water-based wax and grease remover. This article in the SPI forum explains the correct way to do it. The proper way to wipe down a vehicle prior to paint http://www.spiuserforum.com/index.php?threads/the-...aint.6622/
Treating, neutralizing, sanding, cleaning, and painting can be done in small sections; just ensure you get all the water out every time.
Emil
kiwighia68
