patricke1971 Samba Member
Posted: Thu May 23, 2024 3:22 pm Post subject: Low rpm woes |
I have an ongoing problem..I have a 2332and previous was a 2234 and have the same problem..under or around 2000rpm it seems to miss a bit, idles perfect at 850 rpm.
I have changed distributors played around with timing changed idle jets ...after 2000 it takes off like a rocket..
The only thing I didn't change is the carburetor..it's an Spanish idf center mount..
I currently have 65 idle jets..
And currently running a 010 distributor with petronix.. |
modok Samba Member
Joined: October 30, 2009 Posts: 27750 Location: Colorado Springs
Posted: Thu May 23, 2024 3:55 pm Post subject: Re: Low rpm woes |
| patricke1971 wrote: |
So what does the center mount..mount to?
PVC pipe from homeless depo?
CB intake? Bugpack intake? isolated? plenum? steel? fat? skinny?
Does it have a CAMshaft?
How about an exhaust? |
Posted: Thu May 23, 2024 4:09 pm Post subject: Re: Low rpm woes |
Lol I have a redline intake stock dual port end casting
Fk42 camshaft
1 5/8 header
Ported heads |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3676 Location: Paradise, Ca
Posted: Thu May 23, 2024 5:56 pm Post subject: Re: Low rpm woes |
OMG your running a center mount on that 2 liter!!!!! Your killing it _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
modok Samba Member
Posted: Thu May 23, 2024 6:28 pm Post subject: Re: Low rpm woes |
| replace with CB low profile intake |
Posted: Thu May 23, 2024 6:34 pm Post subject: Re: Low rpm woes |
I have no choice..dual carbs simply won't fit..it's on a beach buggy ..after 2000 rpm the thing is a rocket...
Red light to red light I have raced quite a few different cars and won.
I have 295 50 15s on the back and it will spin the Machine sideways..
Lol it's just under 2000 rpm Is where it's a tad sluggish |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3423 Location: Hamble, Hampshire, UK
Posted: Thu May 23, 2024 11:05 pm Post subject: Re: Low rpm woes |
Maybe switch to a 123Tune distributor so you can use whatever vaccum you have in the manifold to dial in some extra advance just off idle, or ramp the centrifugal curve a bit faster off idle.
That must suck as even driving with a stock cam 1641 the engine only works above 2000 rpm .. _________________ Ancient vehicles and vessels
Slow 1200 Samba Member
Posted: Fri May 24, 2024 1:02 am Post subject: Re: Low rpm woes |
| let me guess, no heat risers? |
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1574 Location: Westfield, MA.
Posted: Fri May 24, 2024 3:32 am Post subject: Re: Low rpm woes |
| Slow 1200 wrote: |
Was thinking the same thing, or possible small vacuum leak |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7941 Location: Videbaek Denmark
Posted: Fri May 24, 2024 3:57 am Post subject: Re: Low rpm woes |
Agree on the distrributor. If it has to be an all mechanical, go with a 019 or a Magnaspark or Shockwave.
Header is too large for the power window, so there will be a good deal of overscavenging.
If you run the stock 36 mm venturis they are likely too large. Go 2 mm down and rejet. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
oprn Samba Member
Joined: November 13, 2016 Posts: 15181 Location: Western Canada
Posted: Fri May 24, 2024 4:37 am Post subject: Re: Low rpm woes |
| I have no choice.. dual carbs simply won't fit.. it's on a beach buggy |
Lots of us Beach Buggy owners are running dual carbs. Yes, a tight fit but not impossible...
I curse mine every time I need to work on them but absolutely will not go back when I get behind the steering wheel! Dual carbs on a Beetle looks even tighter to me and it's done all the time. _________________ Our cars get old, we get old but driving an old VW never gets old! |
Posted: Fri May 24, 2024 5:43 am Post subject: Re: Low rpm woes |
| Right now I have an idf 48 with 40mm vents..I have a pair of 36mm would they work better? |
modok Samba Member
Posted: Fri May 24, 2024 9:03 am Post subject: Re: Low rpm woes |
40mm vents.....That's waaay too big for what the intake manifold can flow.
a pair of 36....... whats? |
jinx758 Samba Member
Joined: October 04, 2014 Posts: 1046 Location: half a bubble from plumb
Posted: Fri May 24, 2024 9:25 am Post subject: Re: Low rpm woes |
Accelerator pump squirt off?
Double check dwell. Nubs, putting, & gap off can cause that symptom.
Hope it's something simple.
Sounds like a fun ride ... stay safe
jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference ...
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
modok Samba Member
Posted: Fri May 24, 2024 1:17 pm Post subject: Re: Low rpm woes |
| modok wrote: |
Ah! 36mm venturis I bet. Sorry.
Yeah that would be a bit better |
