50Splitman Samba Member
Posted: Sun May 19, 2024 3:18 pm Post subject: Recommended tool to remove oil pressure spring plug |
I've tried some larger screwdrivers, but I can't budge the oil pressure spring plug on my 25hp engine. Is there a recommended tool I can use to fit into the slotted plug to remove it? I'm thinking a drag link socket like this, but not sure if anyone has any better ideas or experience:
https://www.amazon.com/Stanley-Proto-J5444A-2-Inch...amp;sr=8-2 |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52881 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun May 19, 2024 4:05 pm Post subject: Re: Recommended tool to remove oil pressure spring plug |
The drag link socket will be better than a screwdriver, but for really stuck ones I use a great big cold chisel that I custom ground the tip for an exact fit in the plug's slot, you can turn it with a crescent wrench or vise grips, and pound on it at the same time. I sized it so it was a slight interference fit in the slot.
Any cheapo one will do, mine came from the bargain bin at a discount tool store, it waas too soft to use as a chisel, but perfect for relief plugs. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
mg50 Samba Member
Joined: August 30, 2022 Posts: 750 Location: Southeast
Posted: Sun May 19, 2024 5:51 pm Post subject: Re: Recommended tool to remove oil pressure spring plug |
50Splitman wrote: |
You might try whacking at an angle the outer parts of the slot with a hammer and screwdriver, alternating sides. When I got mine out I replace it with an allen head plug. And the suggestion of making a tool from a chisel sounds good, as the shank is square so you can grab it with a vise grip. _________________ 1971 Super Beetle & 1971 Karmann Ghia
engine rebuild: https://www.thesamba.com/vw/forum/viewtopic.php?t=775424&highlight= |
Posted: Sun May 19, 2024 7:36 pm Post subject: Re: Recommended tool to remove oil pressure spring plug |
Custom grinding a cold chisel is a creative solution for sure - I'll look into that. I can't try and approach hitting the slot from the side as I can't get an angle, so I'll look at either the socket or modified cold chisel unless someone else has a different idea. Thanks! |
wagen19 Samba Member
Joined: November 16, 2007 Posts: 719 Location: germany
Posted: Mon May 20, 2024 12:39 am Post subject: Re: Recommended tool to remove oil pressure spring plug |
50Splitman wrote: |
Try a long head stud with thread M 10 or a bit bigger. Schrew in and pull. |
Zwitterkafer Samba Member
Joined: November 17, 2007 Posts: 1004 Location: Lanark County, Ontario, Canada
Posted: Tue May 21, 2024 10:51 am Post subject: Re: Recommended tool to remove oil pressure spring plug |
If the plug is to be reused and not marred, I use a small piece of rectangular steel, thickness = plug slot width, and length = point-to-point fit in an appropriate sized socket. _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
sweden Samba Member
Posted: Fri May 24, 2024 1:23 am Post subject: Re: Recommended tool to remove oil pressure spring plug |
I made this for many years and it´s allway work.
_________________ Me and my sons cars Typ1 -49 -50 -51 -52 -52 -53 -53 -54 -55 -55 -56 -56 -57 -58 cab -64 cab
T3 TriStar airride with Audi 1,8T engine and Porsche 996 gearbox. |
Posted: Fri May 24, 2024 2:33 pm Post subject: Re: Recommended tool to remove oil pressure spring plug |
Cool idea. I ordered the drag link socket from Amazon and I’ll see if that works. If it doesn’t, then I’ll make a custom tool similar to the ideas you have all shared. Thanks for all the feedback |
Posted: Mon May 27, 2024 4:36 pm Post subject: Re: Recommended tool to remove oil pressure spring plug |
Good news!, thanks for following up.  _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Robert Chambers Samba Member
Posted: Tue May 28, 2024 7:05 am Post subject: Re: Recommended tool to remove oil pressure spring plug |
I just use a blade socket if needed to turn it loose and pull it out with a strong magnet! It works 99% of the time. _________________ '63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117 |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79685 Location: Sneaking up behind you
Posted: Tue May 28, 2024 7:10 am Post subject: Re: Recommended tool to remove oil pressure spring plug |
The $0.10 solution
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
