No electrical power
legotech7
legotech7 is offline
PostPosted: Tue May 28, 2024 12:11 pm    Post subject: No electrical power Reply with quote
Trying to start my buggy today, I turned the key and nothing happened. I have a universal ignition switch on it , and when when I turn to the acc. the gauges would move and the lights would come. But this time nothing happened . Completely dead. I thought it might have been the ignition switch that went bad, but I switched it for a new one. Same thing dead. No juice anywhere. I checked all the fuses, all good. The battery is brand new, so I don't think its that! It has a hard start relay that's been on there for awhile and it was working fine. I also checked the ground from the battery to the starter and ground to the frame and on to the tranny side.
So I'm at a loss. Where can I go from here. Every time I fix something on this thing, something else goes hay wire. Any help would be greatly appreciated.
slayer61
slayer61 is offline
PostPosted: Tue May 28, 2024 12:43 pm    Post subject: Re: No electrical power Reply with quote
It's just an adult version of "connect-the-dots".
Do you have voltage at the battery?
Does that voltage make it all the way up to the "input", or "Batt" terminal at the ignition switch?
When you turn the ignition switch on, does the voltage appear at the "on" terminal?
When you turn the ignition switch to the "start" position, does the voltage make it to the "start" terminal?
Just connect all the dots! Very Happy
Cusser wrote:
... Most folks are idiots when it deals with electrical !!!
67rustavenger wrote:
3/4 race cam? What's missing, one of the lobes? Shocked
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo (pending)
Tim's stage II turbo heads (pending)
MSD Box and distributor
Car Craft turbo header
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
legotech7
PostPosted: Tue May 28, 2024 2:39 pm    Post subject: Re: No electrical power Reply with quote
slayer61.....Yes there is voltage at the battery. Second question, no voltage to to the input or battery terminal of the ignition switch. Third question, When I turn on the ignition switch, no voltage appears on the "on" terminal. Forth question. When I turn the ignition switch to the "start". position, the voltage does not make it to the "start" terminal......There is no power anywhere. I should mention, I put an epower steering unit in this buggy . Prior to the loss of electrical issue , everything was working fine. The only thing that has power is the ecu of the unit with out tuning the key to the acc. position I used a test light to check this, Nothing else is working thus far......????? Thanks for your response....
slayer61
slayer61 is offline
PostPosted: Wed May 29, 2024 6:48 am    Post subject: Re: No electrical power Reply with quote
There is the problem. You haven't "connected the dots" from the battery to the ignition switch! If you put in a temporary jumper as a test... I bet everything else will fall into place. Idea Very Happy
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
legotech7
PostPosted: Wed May 29, 2024 7:39 am    Post subject: Re: No electrical power Reply with quote
slayer61....Ok temporary jumper. Please excuse my ignorance, but as I mentioned before, electronics is not my forte.. How do I go about making and using the jumper. This is driving me nut!... And thanks...
