Vanagon Electric Brake Booster Install
Page: 1, 2, 3  Next
BernieTime
BernieTime is offline
PostPosted: Thu May 30, 2024 10:27 am    Post subject: Vanagon Electric Brake Booster Install Reply with quote
Installed an electric brake booster--called a Bosch ibooster--last night on my Doka.
Has anyone else done this?
I don't have any pics at the moment... I will update this thread next week when I am back with my Doka.
It was fairly straight forward. I retained the stock brake pedal. I had to completely remove the dash and steering column. I used an ibooster from a model 3 tesla and changed the brake fluid reservoir to fit under the dash. There are a couple of other cars out there that use the ibooster too so you can avoid the price mark-up that comes with the "Tesla" name.
Why? 12v electric brake booster gives better performance compared to 40 year old vaccum assist (skeptical? Google it...). You also get to used your brakes more than once if your engine dies.... Cool
Finally, its really easy to wire if you already are running an electric power steering kit (like I am).
Again, I'll update this with some pics and a quick how-to guide next week.
shagginwagon83
shagginwagon83 is offline
PostPosted: Thu May 30, 2024 10:34 am    Post subject: Re: Vanagon Electric Brake Booster Install Reply with quote
This sounds rad, and a beautiful solution for the various flavors of big brake kits out there.
With the iBooster, the pedal characteristics can be adjusted from sporty to comfortable.
Last edited by shagginwagon83 on Thu May 30, 2024 10:38 am; edited 1 time in total
ALIKA T3
ALIKA T3 is offline
PostPosted: Thu May 30, 2024 10:35 am    Post subject: Re: Vanagon Electric Brake Booster Install Reply with quote
That's super interesting, I'd love to see the pictures!
Not that I will ever do it (the less electric stuff the happier I am) but I appreciate creativity applied to our beloved Vanagons!
Jake59
Jake59 is offline
PostPosted: Thu May 30, 2024 11:01 am    Post subject: Re: Vanagon Electric Brake Booster Install Reply with quote
Yes, More information please. like what # item number and lots of photos if any mods to the item or van were necessary.
A Google search for "Bosch ibooster" only sent me to a bunch of Tesla links.
Embarassed
Curent ride: 87 2WD Westy, 2012 Jetta Sportwagon 2.5S
Past Rides: 62 (23 window) Bus, 64 Ghai convertable, 68 single cab, 72 Super Bettle, 78 Bay window Bus, 84 GTI.
dublife13
dublife13 is offline
PostPosted: Thu May 30, 2024 7:49 pm    Post subject: Re: Vanagon Electric Brake Booster Install Reply with quote
I am very interested in this conversion both for the performance and the space in the dash, excited to see some pictures.
RoryGirl
RoryGirl is offline
PostPosted: Thu May 30, 2024 9:51 pm    Post subject: Re: Vanagon Electric Brake Booster Install Reply with quote
Give SuperfastMatt a sub...
1991 Twin Slider VR6
1985 Audi 4k
11BC2
11BC2 is offline
PostPosted: Sat Jun 01, 2024 9:04 am    Post subject: Re: Vanagon Electric Brake Booster Install Reply with quote
I've been testing the electric vacuum pump that late model Subaru WRX use due to low engine vacuum at certain RPMs.
1985 Westy Joker EJ253 and Subaru 5spd
1990 ex Bundewehr Doka 1.9 AAZ
JohnL99
JohnL99 is offline
PostPosted: Sat Jun 01, 2024 3:51 pm    Post subject: Re: Vanagon Electric Brake Booster Install Reply with quote
This is cool. With all the trouble finding replacement boosters this might be well timed. I have Toyota Yaris electric power steering on mine so you know I am interested.
AndyBees
AndyBees is offline
PostPosted: Sat Jun 01, 2024 3:56 pm    Post subject: Re: Vanagon Electric Brake Booster Install Reply with quote
Subscribed for updates and pics.
'84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful.
SnowDaySyncro
SnowDaySyncro is offline
PostPosted: Mon Jun 03, 2024 9:26 am    Post subject: Re: Vanagon Electric Brake Booster Install Reply with quote
I've been eyeing this as well, as part of my dream of eventually converting my TDI Syncro to 4xE.
Running in FWD EV mode will require the brake booster and power steering to be electric. In the meantime, it should theoretically decrease engine load and increase efficiency if I eliminate the need for a vacuum pump.
dieseltdi
dieseltdi is offline
PostPosted: Tue Jun 04, 2024 7:41 am    Post subject: Re: Vanagon Electric Brake Booster Install Reply with quote
Was wondering what master cylinder you used? The one that is mounted on the power unit? I am about to have to completely disassemble my dash to install my Behr ac unit so……
When a clown moves into a palace he doesn’t become a king, the palace instead becomes a circus. — Turkish proverb
Those who will willingly sacrifice freedom for security, deserve neither.
Currently:
1982 Vanagon Westy TDI conversion with Coast Mt. Hightop - SKYE
2025 Hyundai Ioniq 6 EV
2015 Golf Sportwagen S TDI
Way too many previously owned to list!
dieseltdi
PostPosted: Thu Jun 06, 2024 7:29 am    Post subject: Re: Vanagon Electric Brake Booster Install Reply with quote
Hey OP! Are you going to give us a follow up with pics?
Currently:
midwestOutreach
midwestOutreach is offline
PostPosted: Thu Jun 06, 2024 9:42 am    Post subject: Re: Vanagon Electric Brake Booster Install Reply with quote
Yes, please more details!
In the garage:
  • 90 Vanagon Carat
  • 80 Vanagon Westy
  • 03 Discovery
BernieTime
PostPosted: Thu Jun 06, 2024 12:28 pm    Post subject: Re: Vanagon Electric Brake Booster Install Reply with quote
Yes! My Doka has been in storage and I've only been able to access it once a week. I am towing it down to my shop this weekend and I'll take some better pics. I have a full step by step write up in the works so this thread can be used as a reference in the future! Sorry for the wait.
dieseltdi
PostPosted: Thu Jun 06, 2024 12:49 pm    Post subject: Re: Vanagon Electric Brake Booster Install Reply with quote
Great!
Currently:
BernieTime
PostPosted: Mon Jun 10, 2024 10:56 am    Post subject: Re: Vanagon Electric Brake Booster Install Reply with quote
Here's a sneak peak! I am putting all my pics and advice into a comprehensive how-to.
Biggest take away: Most of the stock brake fluid reservoirs that come with any version of the iBooster won't fit our vans.
HOWEVER, there is a master cylinder from a different car that is a direct bolt-on to the iBooster which fits perfectly in the Vanagon and works with the stock brake lines.
More on that later after I 100% confirm the compatibility.
dieseltdi
PostPosted: Tue Jun 11, 2024 7:45 am    Post subject: Re: Vanagon Electric Brake Booster Install Reply with quote
Waiting with keen anticipation. I am about to have to remove my dash for AC work so this may be the time and place for a change to a more modern system.
Currently:
shagginwagon83
PostPosted: Tue Jun 11, 2024 8:12 am    Post subject: Re: Vanagon Electric Brake Booster Install Reply with quote
As someone with electric power steering, I am very interested also. That unit has worked perfectly since it was installed.
It is beautiful to see wrecked electric cars bringing vintage cars back to life.
I too am overdue for a dash-out servicing. I have a BMW reman booster on the shelf - which now I am likely to sell given this project. Love the ability to adjust with this unit!
Run8Stud
Run8Stud is offline
PostPosted: Tue Jun 11, 2024 8:28 am    Post subject: Re: Vanagon Electric Brake Booster Install Reply with quote
Would this type of conversion work for stick-shift vans? Or would another reservoir be needed for the clutch? I ask out of ignorance as I haven't dug into the brake-booster or clutch yet, but I think they share the one reservoir.
John G. - 1987 Westy GW 2.2 5-Speed
panzer
panzer is offline
PostPosted: Tue Jun 11, 2024 6:56 pm    Post subject: Re: Vanagon Electric Brake Booster Install Reply with quote
I was thinkin' about this also. Most sport type motorcycles have a remote reservoir that attaches to the handle bars for the brakes or clutch. One could be mounted right above the clutch master or farther away to make a longer route to hold more fluid since they're not too large.
Page: 1, 2, 3  Next
