iconic_schlieper Samba Member
Posted: Wed Feb 14, 2024 8:26 am Post subject: Re: German "Hazard Streaker" Baja |
Engine Time...
sorry we forgot to make more pictures of mounting the new engine.
Parts we used:
- 78mm crankshaft
- 90.5 Mahle cylinders and pistons
- build heads with 40mm intakevalves and 36mm outtake valves
- 274 degrees camshaft
- 40mm Webers
- CSP products airfilters & velocity stacks
- CSP products engine breather box
- CSP products valve covers
- CSP products crank pulley
- CSP products Pacemaker distributor
- cagero oil cooling system
- Empi baja Exhaust
Later we saw that the pushrof tubes are fuckin bad quality and we changed them to CSP products pushrod tubes |
Posted: Sat Feb 17, 2024 4:45 am Post subject: Re: German "Hazard Streaker" Baja |
ok, guys, I installed the engine now. As you see the pushtube rods are the cheap ones. They doesn´t looked good and i decided against them and changed it to CSP. You can see them on the next pictures. The really cool thing is you can change them without dismantle the whole cylinderhead.
the longer intake funnels from Csp give the engine more torque.
Air filters are from K&N and Empi exhaust fits perfecty.
We make the oil system ready. We put a cagero underfloor cooler on the rear axle. Its very flat and we used them on many cars. It cooled the oil very good when you had bigger engines and more heat.
Rear bumper tube is installed, oil system ready, engine wireing finished. |
nightbasser Samba Member
Joined: December 25, 2023 Posts: 41 Location: Kentucky
Posted: Mon Feb 19, 2024 3:08 pm Post subject: Re: German "Hazard Streaker" Baja |
incredible build!!! Thanks for sharing!!! |
Posted: Tue Feb 20, 2024 11:43 pm Post subject: Re: German "Hazard Streaker" Baja |
Ok the new selfmade front bumper is on the car, together with two Hella frontlights. We put the cables inside the tube. That was very difficult to realize.
the new high torque starter is mounted on the gearbox.
CSP Pacemaker disturbator in black edition.
Empi Exhaust complete...
Fuelpump and filter are now on the car.
Posted: Fri Mar 08, 2024 7:57 am Post subject: Re: German "Hazard Streaker" Baja |
CSP Shifter installed, rollover cage installed and now first test with the tires and how the tire fit when we have big rocks...
QRP Samba Member
Joined: April 27, 2008 Posts: 1887 Location: NORTH HOLLYWOOD,CA
Posted: Fri Mar 08, 2024 9:27 am Post subject: Re: German "Hazard Streaker" Baja |
Looks awesome, nice work! |
kpf Samba Member
Joined: March 01, 2017 Posts: 1061 Location: California, US
Posted: Fri Mar 08, 2024 10:53 am Post subject: Re: German "Hazard Streaker" Baja |
Beautiful!
sky = headliner _________________ 1971 Super Beetle |
Safety Ed Samba Member
Joined: July 10, 2023 Posts: 9 Location: San Pedro CA
Posted: Fri Mar 08, 2024 1:50 pm Post subject: Re: German "Hazard Streaker" Baja |
beautiful build, i would move that oil cooler off the bottom of the pan tho. that will get torn off real quick. |
Posted: Sat Mar 09, 2024 2:35 am Post subject: Re: German "Hazard Streaker" Baja |
kpf wrote: |
Beautiful!
sky = headliner |
thx for the correction...helps me a lot |
Posted: Sat Mar 09, 2024 2:38 am Post subject: Re: German "Hazard Streaker" Baja |
Testdrive on a local construction area...
and we put sticker on it...
the roofrack is build from a standard one with wooden boards. I changed them against aluminium |
2type2 Samba Member
Joined: June 02, 2002 Posts: 1179 Location: SW Colorado
Posted: Sun Mar 10, 2024 8:18 am Post subject: Re: German "Hazard Streaker" Baja |
Absolutely beautiful toy! What about protection for pushrod tubes- industrial tin set? _________________ "A life of peace and happiness depends on your own gratefulness" |
Posted: Mon Mar 11, 2024 4:27 am Post subject: Re: German "Hazard Streaker" Baja |
Do you have an example how to protect it? Something build from sheetmetal? |
Posted: Mon Mar 11, 2024 4:46 am Post subject: Re: German "Hazard Streaker" Baja |
What about some cool pictures for CSP Magazine? Georg Otto and Günter Poley came to us for fotoshooting. The Streaker will be featured in CSP Magazine which came with every order. AWESOME!!
YEAH thats me
DREAMTEAM Georg, Christian (Me) and Björn |
2type2 Samba Member
Posted: Mon Mar 11, 2024 7:20 am Post subject: Re: German "Hazard Streaker" Baja |
Check out the gallery, look for " industrial tins"... You can fabricate your own or buy them. But don't go without the protection! _________________ "A life of peace and happiness depends on your own gratefulness" |
mikec4193 Samba Member
Joined: July 15, 2014 Posts: 295 Location: Mechanicville NY (Upstate)
Posted: Sat Mar 23, 2024 2:37 pm Post subject: Re: German "Hazard Streaker" Baja |
That is an amazing build right there...
I would have had a hard time getting it dirty and beating on it at the same time...a crap ton of work right there...and tons of money I am sure...
Hope it was a fun build for you too...
Keep us in the loop as you go along...
MikeC _________________ Dad bought his first Beetle on Dec 17, 1953. |
agramer1966 Samba Member
Joined: October 17, 2010 Posts: 179 Location: Northern Poland
Posted: Sat Mar 30, 2024 9:31 am Post subject: Re: German "Hazard Streaker" Baja |
That's an amazing build. Congrats. _________________ 1966 VW1300
1973 VW1302
1979 924
1984 924
Bunch of old Jap motorbikes
Instagram & YT: #agrameroldoctane |
backagain73 Samba Member
Joined: December 23, 2014 Posts: 62 Location: United States
Posted: Fri May 03, 2024 5:40 am Post subject: Re: German "Hazard Streaker" Baja |
Very impressive work. You put your mind to the job and you can achieve anything. Enjoy it now. |
Posted: Tue Jun 18, 2024 6:50 am Post subject: Re: German "Hazard Streaker" Baja |
hey guys...after two years driving the customer wants to sell this crazy build.
as i told...german street legal!
you find it on thesamba later. |
Posted: Tue Jun 18, 2024 8:46 am Post subject: Re: German "Hazard Streaker" Baja |
