NJ John Samba Member
Joined: September 21, 2007 Posts: 2937 Location: HdG, MD & NJ
Posted: Fri Jun 28, 2024 1:18 pm Post subject: Anyone regret having a car blasted? |
I just got this 1970 chopped bug. It has a 1996 inspection sticker, so I assume it’s been sitting outside for about that long. It’s solid in all 4 wheel wells. Driver’s heater channel is the worse of the two. I know ill be doing at least pans. It was red, now it’s white. I talked to a blast company, he uses glass and it’s $160 an hour. I’m just scared of bringing home Swiss cheese. It’s probably just going to be a flat or satin black lowered cruiser, not a show car.
_________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
viiking Samba Member
Joined: May 10, 2013 Posts: 3242 Location: Sydney Australia
Posted: Fri Jun 28, 2024 4:10 pm Post subject: Re: Anyone regret having a car blasted? |
In reference to the Swiss cheese comment, are you worried about damage caused by the glass beads or what you will find underneath?
You don't show pictures of the outer body. These areas are the ones most sensitive to warping etc. As far as underneath and in non visible areas, you want some aggressive media blast to get rid of undercoating or really rusty areas. These areas are far less likely to be affected by aggressive media blasting. Glass beads are far less aggressive than say aluminium oxide or garnet.
It depends on your time frame. If you have the time I would remove paint on the outer body in sections and immediately epoxy just that section. Your removal process could be to sand back to bare metal or to use paint stripper followed by correct neutralisation then epoxy. As I have found rust spots under filler that has been applied to the bare metal previously, all filler needs to be removed to ensure you have no problems down the track.
If you don't have the time, then you have to use a media blaster. Given the issue about possible warping you should get a recommendation from a couple of people who use a specific media blaster. It's easy to do media blasting. I have done it. But if you get a cowboy to do it, you might end up regretting that decision and taking far longer to repair than if you took your time to do it yourself and remover the paint manually. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Fri Jun 28, 2024 4:18 pm Post subject: Re: Anyone regret having a car blasted? |
My concern isn’t warping. This guy is a one man shop and claims to not warp metal. Just pin holes or bigger. As I mentioned the roof is chopped, but the bondo cracked and water did get under it. I may end up refilling the center with another roof. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
Posted: Fri Jun 28, 2024 6:08 pm Post subject: Re: Anyone regret having a car blasted? |
Whether you want to or not you have to address the underlying problems otherwise they will become evident after you spend a lot of money painting the car. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Puppy67 Samba Member
Joined: October 04, 2022 Posts: 288 Location: Bristol, UK
Posted: Sat Jun 29, 2024 12:25 am Post subject: Re: Anyone regret having a car blasted? |
I had my floorpan and shell soda blasted before I started work on the restoration. It uncovered lots I was unaware of that needed to be repaired/redone, but I don't regret it. Yes, more work before paint, but I now know I have a solid car. I would have regretted it far more if I hadn't found the problems and had them show up a year or 2 after paint and re-assembly. |
esde Samba Member
Joined: October 20, 2007 Posts: 6359 Location: central rust belt
Posted: Sat Jun 29, 2024 6:23 am Post subject: Re: Anyone regret having a car blasted? |
The problems are there, whether you see them now or not. I have blasted a half dozen cars, and do not regret any. You need to get some ospho into the seams after you clean all the grit out of every nook and crevice, as there is no way to address rust between the layers.
I stay away from the door skins, and blast the hood at a low angle to minimize heat and raising the metal too much.
Starting with virgin completely clean metal makes the welding go so much better, you won't believe t till you do it. _________________ modok wrote:
Posted: Sat Jun 29, 2024 9:22 am Post subject: Re: Anyone regret having a car blasted? |
All points noted. Thanks.
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2780 Location: Plattsburgh, New York
Posted: Thu Jul 04, 2024 7:12 am Post subject: Re: Anyone regret having a car blasted? |
I have done a lot of sandblasting at home. There is nothing better for getting metal rust free. If I had a better set up, I would do more of it. The only downside is getting all the sand out of the car.
Unless the sandblaster exclusively works on cranes or bridges, he should know how to run a blaster to avoid warping. Of course some of the car might disappear as it pinholes through punky metal, but that’s what you want to have gone. |
Posted: Wed Jul 10, 2024 11:32 am Post subject: Re: Anyone regret having a car blasted? |
I’m going to look into mobile dustless blasting. There’s a local guy around. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
lqqkatjon Samba Member
Joined: July 02, 2013 Posts: 64 Location: St. Cloud, MN
Posted: Mon Jul 15, 2024 7:17 am Post subject: Re: Anyone regret having a car blasted? |
I am doing a resurrections over the past 8+ years.
I home sandblasted... I am still cleaning up grit. that stuff gets everywhere! shop vac at arms length, been pressure washed a few times, had to take dash all apart and vacuum and clean grit out of there.
last week I had it hoisted up on a crane and flipped car on side so I could do some work on the bottom, and more grit fell out of the master cylinder hole in the napoleon hat that I had take my shop vac and hose and shoved it down there many times!
so I would be doing some sort of different blasting then just dry blasting. do a better job then I did taping up areas you don't want grit in. |
bruceo98 Samba Member
Posted: Mon Jul 15, 2024 8:15 am Post subject: Re: Anyone regret having a car blasted? |
as for as swiss cheese . if it came out blasting it , it needed to be done. if you don't remove all the rust it will come back to haunt you later down the road. rust never gets better over time, only worst. if you're going to do it right you need to start with a clean slate. after you're done with all the body work and paint , drown it with some body cavity wax.rust needs 2 things to continue growing, air and moisture . so make sure it's covered in some type of coating. _________________ I may not be the best, but when the top 10 get together, they all talk about me. |
swharris Samba Member
Joined: September 10, 2010 Posts: 641 Location: N. Orange County
Posted: Mon Sep 09, 2024 12:09 pm Post subject: Re: Anyone regret having a car blasted? |
NJ John wrote: |
My concern isn’t warping. This guy is a one man shop and claims to not warp metal. Just pin holes or bigger. As I mentioned the roof is chopped, but the bondo cracked and water did get under it. I may end up refilling the center with another roof. |
"claims" LOL. Lets get this straight right here. ALL blasting "peens" the metal the instant the media hits it. You are pushing the metal around weather you acknowledge it or not. Any blasting of sheet metal "warps" it, period. Now, it depends on how particular you are about your final finish and how much "fixing" of that moved metal you plan to do. Check out Sylvester's customs thoughts on blasting. It opened my eyes about when and where to blast and what other ways can be used instead.
https://www.youtube.com/watch?v=uLJvlQ8t-RU |
Posted: Mon Sep 09, 2024 3:56 pm Post subject: Re: Anyone regret having a car blasted? |
Thanks. I actually may be making an appointment to have it blasted in the near future. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
Dusty1 Samba Member
Posted: Sun Sep 15, 2024 4:51 pm Post subject: Re: Anyone regret having a car blasted? |
I wouldn't blast that. Somewhere under the several layers of paint is the original German primer. You can't beat that stuff.
I would wire wheel the rough spots on the roof. Nuthin' chews through Bondo like a twisted stainless steel brush on an angle grinder.
Bet you a dollar there are things under that paint you don't want to see.
Bet you another dollar that it's a bigger project than you hoped it would be in bare metal.
Posted: Mon Sep 23, 2024 8:59 pm Post subject: Re: Anyone regret having a car blasted? |
I know. I was just in the trailer looking at it today. I haven’t had it out since I got it. Just don’t have the space or time. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
oprn Samba Member
Joined: November 13, 2016 Posts: 14905 Location: Western Canada
Posted: Wed Oct 02, 2024 1:47 am Post subject: Re: Anyone regret having a car blasted? |
There is a strongly believed myth that a proper restoration means the body has to be taken back to bare metal. That is the worst thing you could ever do. The original primer and paint durability is very hard to duplicate and makes the best base for a new finish.
The only time it is right to "take it back to bare metal" is to remove rust or fix collision damage. Blasting the whole body to remove all the paint will create untold hours of unnecessary hard work to get the panels straight again, imperfections filled and ready for paint. Or it's the right thing to do if the original finish has suffered a catastrophic failure but that is extremely rare.
Properly done blasting of a rusted area will not create swiss cheese, it will expose the swiss cheese that already exists. And that is a good thing. _________________ Our cars get old, we get old but driving an old VW never gets old! |
Posted: Thu Oct 03, 2024 11:01 am Post subject: Re: Anyone regret having a car blasted? |
Sometimes, hidden Swiss cheese is bliss. Lol _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
esde Samba Member
Posted: Fri Oct 04, 2024 6:23 pm Post subject: Re: Anyone regret having a car blasted? |
oprn wrote: |
Properly done blasting of a rusted area will not create swiss cheese, it will expose the swiss cheese that already exists. And that is a good thing. |
I mostly disagree.
Most of these cars have 2-3-4 or more coats of paint with filler and rust. Your current work is only as good as what's under it, so get all that stuff off and start fresh. The rust is there whether you know it or not. Warped metal is a poor operator. If the car has decent original paint to begin with you probably aren't considering blasting it, of course leaving it would be preferable.
I blasted my zwitter and it probably saved a hundred hours of sanding and who knows how much money in sandpaper, and warped or damaged nothing. I'd do it again without question.
Key factors are media selection/ nozzle size/ air pressure/ work speed. These NEED to be correct and chosen by an experienced operator. Wrong media or pressure will make the work take too long and lingering to get the paint off a spot lets heat build up and works the metal too much. That's how warping happens. I use garnet at around 100 psi and it takes the paint off fast so the nozzle is always moving. Big flat areas get gone over lightly and at a low angle to minimize direct impact. Works great _________________ modok wrote:
oprn Samba Member
Posted: Sun Oct 13, 2024 7:57 pm Post subject: Re: Anyone regret having a car blasted? |
There are 2 kinds of rust,
1) surface rust. You can see that and yes stripping to bare metal is the only way to deal with it properly.
2) rust from inside the panel. If it has not yet broken through to the paint no amount of stripping or sand blasting will find it... ever! Do whatever you want but it will show up when it is ready to show up. It might not be for years and it just might pop through a week after you painted it. Sand blasting to bare metal will accomplish nothing to prevent it.
If there is multiple layers of old paint, just grab some coarse sand paper, elbow grease and have at it. If your method is correct it doesn't take that long. Just go progressively finer as you reach the original finish. Save that as a base. If it takes hundreds of hours you are doing it wrong. _________________ Our cars get old, we get old but driving an old VW never gets old! |
