oil temp sensor install
MTT3107
MTT3107 is offline
PostPosted: Sun Jun 30, 2024 7:54 am    Post subject: oil temp sensor install Reply with quote
Hi, I want to install this oil temp sensor on my engine, on the blank plate at the bottom of the case.
Can anybody here tell me what kind of tap I need to cut those threads ?
Outside diameter of the threads is just over 10mm.
Dale M.
Dale M. is offline
PostPosted: Sun Jun 30, 2024 8:31 am    Post subject: Re: oil temp sensor install Reply with quote
Are the threads SAE or Metric.....
What is exact thread count and what is exact diameter of threads?
They make gauges to tell you all this!
Dan_Lockwood
Dan_Lockwood is offline
PostPosted: Sun Jun 30, 2024 9:35 am    Post subject: Re: oil temp sensor install Reply with quote
Not to hijack this thread, but is the 2-bolt plate a "good" place to mount the oil temp sender?
Regardless of the work required to do so, is there a "better" place to install the oil temp sender?
Thanks, Dan
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Jun 30, 2024 9:47 am    Post subject: Re: oil temp sensor install Reply with quote
It's a good place
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Dan_Lockwood
PostPosted: Sun Jun 30, 2024 10:25 am    Post subject: Re: oil temp sensor install Reply with quote
Glenn wrote:
It's a good place
Thanks Glenn!
Dan_Lockwood
PostPosted: Sun Jun 30, 2024 10:31 am    Post subject: Re: oil temp sensor install Reply with quote
Glenn, got to thinking about my build and with the sump on the bottom, would it be better to drill/tap the side casting and insert my sensor there? I'll have a skid plate protecting that area when finished.
MTT3107
MTT3107 is offline
PostPosted: Sun Jun 30, 2024 11:06 am    Post subject: Re: oil temp sensor install Reply with quote
Don't know the thread count....
I have a M10x1.25 tap, drilled and tapped a hole in a piece of angle iron with it, but than didn't work...
I think it would have to be a M10x1.0, but am not sure.
And yes, I know there a gauges for this, but it would be easier for me to just be able to buy the right tap, instead of buying the gauges ( which in all likelihood will never need again), and then buy the right tap.
67rustavenger
67rustavenger is online now
PostPosted: Sun Jun 30, 2024 11:13 am    Post subject: Re: oil temp sensor install Reply with quote
It appears to me, that the sensor has tapered threads. Like 1/8" NPT.
Who is the sensor manufacturer?
Dan, You can tap the sump. But you'll likely get different temp readings than from the T3 sump plate.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Don Jones
Don Jones is offline
PostPosted: Sun Jun 30, 2024 11:31 am    Post subject: Re: oil temp sensor install Reply with quote
I've tried mounting the sensor in the oil filter bracket, oil relief plug and finally in the steel plate talked about here. Plate mounting is the strongest as it's steel and the easier to get to if you have to remove / install. Oil temp readings are the same at all locations.
Here's the size, at least that is what mine is:
VDO-323-057 - 323057 - 300F DEGREE OIL TEMPERATURE SENDER / SENDING UNIT 1/8-27 NPT
MTT3107
MTT3107 is offline
PostPosted: Sun Jun 30, 2024 12:55 pm    Post subject: Re: oil temp sensor install Reply with quote
@ Don Jones :
Thanks !
Just ordered the corresponding tap.
@rustavenger :
Manufacturer is VDO.
fl59bug
fl59bug is offline
PostPosted: Sun Jun 30, 2024 2:05 pm    Post subject: Re: oil temp sensor install Reply with quote
I can't remember where I bought mine from, but I'm running this exact oil temp sender and location. I purchased it already drilled and tapped.
Here is one from Appletree Automotive:
https://www.appletreeauto.com/type-3-dipstick-bloc...h0QAvD_BwE
Ted
MTT3107
MTT3107 is offline
PostPosted: Sun Jun 30, 2024 2:30 pm    Post subject: Re: oil temp sensor install Reply with quote
Thanks for that tip !
But I just ordered the tap from amazon.
$ 6.56, so I saved some money ! Very Happy Very Happy
Don Jones
PostPosted: Sun Jun 30, 2024 10:10 pm    Post subject: Re: oil temp sensor install Reply with quote
May as well grab the correct drill for the 1/8" NPT from amazon also.
Clamp the plate to a board, eg. 2x4 when drilling to prevent mishap when drill bit bites going thru the plate. Find your enter and center punch it.
I did my drilling in 3-steps w/ cutting fluid. Didn't want to screw up and have to purchase another plate.
Murt
Murt is offline
PostPosted: Sun Jun 30, 2024 10:16 pm    Post subject: Re: oil temp sensor install Reply with quote
How are these senders connected electrically to the gauge?
1966 VW Beetle ‘Jules’
1967 Kombi Splitscreen ‘Barney’
2018 VW Caddy Maxi R Line
2017 Golf GTD saloon
2008 VW EOS 2.0 TFSi
Mr. 010
Glenn is offline
PostPosted: Mon Jul 01, 2024 5:40 am    Post subject: Re: oil temp sensor install Reply with quote
With a wire Wink
You use the left terminal.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
RWK
RWK is offline
PostPosted: Mon Jul 01, 2024 6:15 am    Post subject: Re: oil temp sensor install Reply with quote
Don't tap too deep, pipe taps are tapered, if you go too deep it will not seal, try 4-5 turns then check with sender, you want a few threads left above the plate on the sender. 3-4 turns on pipe threads is the min.
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
Cusser
Cusser is offline
PostPosted: Mon Jul 01, 2024 7:06 am    Post subject: Re: oil temp sensor install Reply with quote
Does anyone use a copper crush washer with these?
Mr. 010
Glenn is offline
PostPosted: Mon Jul 01, 2024 7:15 am    Post subject: Re: oil temp sensor install Reply with quote
Not needed if its a taper thread.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Don Jones
PostPosted: Mon Jul 01, 2024 12:07 pm    Post subject: Re: oil temp sensor install Reply with quote
This is how i ran the oil temp wire. I had it previously going to my oil filter adapter so i just continued it along the full-flow lines (insulated for lines) under engine to sender.
If you look closely you'll see that i use a small "L" shape bracket attachment to engine block.
My sender uses the spade connector.
oprn
oprn is offline
PostPosted: Mon Jul 01, 2024 12:19 pm    Post subject: Re: oil temp sensor install Reply with quote
Very neat and tidy!
