Hatterasker Samba Member
Joined: October 31, 2011 Posts: 250 Location: Pacific Northwest
Posted: Thu Jul 04, 2024 8:35 am Post subject: Ground clearance, engine removal |
I need to remove my engine. Trying to figure out of I have the vertical space to do the work in my carport. I’ll probably be using a jack on casters that is about 8” tall. The answer depends on how much I take off the top of course.
What kind of ground clearance would I need to roll the 2.1l motor out from underneath my 1991 Vanagon?
As always, thank you Samba. _________________ 1990 Vanagon Westfalia |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2946 Location: San Luis Obispo, CA
Posted: Thu Jul 04, 2024 9:16 am Post subject: Re: Ground clearance, engine removal |
A 2t floor jack and a couple of jack stands are what I use. Your 8" tall dolly is a little excessive. If height is an issue, use a cherry picker or other hoist device to lower the engine down onto a piece of plywood. Then lift the van up with floor jack until you can slide the motor out on the plywood. I doubt the motor is more than 18" tall...
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
GoEverywhere Samba Member
Joined: December 13, 2020 Posts: 941 Location: Portland, OR
Posted: Thu Jul 04, 2024 12:23 pm Post subject: Re: Ground clearance, engine removal |
I swapped engines in mine a few weeks back. I put the back end up on harbor freight ramps, and removed the engine with a motorcycle jack. Rolled out under the rear with JUST a hair's room under the rear sheet metal. |
Posted: Fri Jul 05, 2024 6:47 pm Post subject: Re: Ground clearance, engine removal |
Hey! Thanks! _________________ 1990 Vanagon Westfalia |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1555 Location: san diego
Posted: Fri Jul 05, 2024 10:05 pm Post subject: Re: Ground clearance, engine removal |
if you strip the top of the long block before you drop the engine, likely you will be doing it anyway, you can get it out without lifting the van at all, l've done it that way a couple of times working in peoples garages. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
