Mounting a Hirschmann uto Antenna?
russelltatedotcom
russelltatedotcom is offline
PostPosted: Sat Jul 06, 2024 6:08 pm    Post subject: Mounting a Hirschmann uto Antenna? Reply with quote
Hi guys, anybody have any experience in mounting a
Hirschmann automatic Antenna behind the splash guards of a Ghia?
The support brackets for the splash guards seem to stop the Antenna from going in.
I don't know how this guy did it (looks like he has no splash guard brackets)
I think partially disassembling the antenna will not work as I will have to reassemble while reaching into the tight space with very little hand room?
One Idea might be to cut the bracket, but it needs to go back to keep the splash guard in place.
If you've down one before show us how ya did it!
Cheers
Russell
Braukuche
Braukuche is offline
PostPosted: Sat Jul 06, 2024 7:33 pm    Post subject: Re: Mounting a Hirschmann uto Antenna? Reply with quote
Is that a power antenna? I have several original manual antennas and never had a problem.
Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia
russelltatedotcom
PostPosted: Sun Jul 07, 2024 7:31 pm    Post subject: Re: Mounting a Hirschmann uto Antenna? Reply with quote
Yes power antenna, auto antenna. Manual is not a problem but the motor unit and the mast together will not squeeze past the 2 splash guard brackets
