Official "What oil / additives should I use" topic
Page: Previous  1, 2, 3 ... , 235, 236, 237  Next
Gamba1973
Gamba1973 is offline
PostPosted: Fri Jul 12, 2024 3:49 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
Hiya guys, well after over an hour of reading...... I am.no closer to making my mind up for an engine oil for my 1300 60s engine.
I live in western Australia and have been recommended this, what are your thoughts?
https://www.supercheapauto.com.au/p/penrite-penrit...lsrc=aw.ds
Thanks.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Jul 12, 2024 4:18 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
Thanks.
I would only use a 20W-60 on a engine that has a rod knock. Even in desert heat, its way too thick and and will make your engine run hotter since it has to work harder to push that muck through the oil galleys.
If your engine is high mileage i'd use a 10W-40. If relatively new, i'd use a 5W-30.
Clean oil is better than any dirty fancy oil.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Wildthings
Wildthings is offline
PostPosted: Fri Jul 12, 2024 5:09 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
Both straight weight oils and synthetic oils will handle heat better than dino multigrade oils. Run the thinnest oil that will give you adequate oil pressure which is around 0.7 Bar per 1000 rpm for a hot engine.
This is the lubricant chart for a 66 Type 1 engine, note that VW was not recommending a particularly thick oil.
Also note that modern oils are a vast improvement over the oils of the 1960's.
KingAir42
KingAir42 is offline
PostPosted: Fri Jul 12, 2024 8:00 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
It’s been 114F everyday for the past few weeks. My 1200 40hp uses 30 weight oil. The hottest oil temp I have ever seen while driving around in this heatwave is 218F
A stitch in time saves nine
oprn
oprn is offline
PostPosted: Fri Jul 12, 2024 8:43 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
I normally run 10W30 in my Buggy. The oil pump is not new due to availability of proper oil pumps (type 4) but was just inside wear limits. Normally in the summer it runs 35 psi and 220*F at cruise. Last week I did an unintentional oil change on the side of the highway and the closest available oil I could find at the time was 15W40. It takes nearly twice as long now for the oil pressure to come down off the pin on cold start up, runs 45 psi and 240*F at cruise.
The only other gasoline engine I have run 15W40 in was a used Chevy 350 pickup the bearings were worn so bad in that it didn't have enough oil pressure to keep the lifters from collapsing once warmed up. The heavier oil did the trick for light duty service for quite a while.
oprn
oprn is offline
PostPosted: Fri Jul 12, 2024 8:47 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
^^^This right here is gold!^^^
Bruce
Bruce is offline
PostPosted: Fri Jul 26, 2024 3:44 am    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
Glenn wrote:
... its way too thick and and will make your engine run hotter since it has to work harder to push that muck through the oil galleys.
More than that, running a -60 weight tar will cause super high oil pressures. This will bypass the stock cooler, making the oil temp go way up.
Your engine was designed to used straight 30. Today we have multigrades, so use a 10W-30 or better yet, 5W-30.
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Fri Jul 26, 2024 6:18 am    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
Both my bugs engines have less than 10k miles on them since rebuild. I tried 10W-40 a few years ago. I then went down 10W-30 and saw 10° lower oil temperatures. Here in god awful hot Arizona, I rarely exceed 220°.
The Samba member since 2004.
bnam
bnam is offline
PostPosted: Fri Jan 31, 2025 9:32 am    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
I’m newly reading this thread so forgive me if this question has been asked and answered before,
In an engine with a well regulated cooling system, the engine temperature remains the same (+/- 10F) whether it is 70F outside or 90F or 110F. So, why is there a need for hotter grade (say xW50) oil? Engine temp is anyway much greater than ambient. I’ve read that engines are typically designed to need about 10 centistokes at operating temp (100c/212F). xW30 and xW40 would seem to more than meet that need.
Thx,
Byas
Click to view image
1952 Citroen TA 11BL
Wildthings
PostPosted: Fri Jan 31, 2025 2:36 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
Thx,
Byas
There is a reason why for decades 10w30 was the best selling oil around the world and if an engine called for a single weight oil it was typically 30wt.
VW recommended against multigrades and recommended fairly thin straight weight oils like 20wt for moderate temperatures and 30wt for hotter temperatures for a long time, and then for a couple of year did recommend multigrades for cooler temps only, but dropped that recommendation again and went back to only recommending straight weight oils, I think they started recommending 40wt at the highest tropical temperatures at that time. After another four'ish years they put multigrades back on the chart. Personally I am glad I had already learned a lesson on running needlessly thick oil on another rig and on the first VW I did regular maintenance on (a 1966 Beetle) ran the recommended 30wt in the summer. Not running super thick oils has served me very well over the years, as more oil passes through the cooler and less gets dumped right back to the sump without being able to help cool anything. Unless one's engine is just built loose or badly worn, I don't think one is apt to get any real advantage from running an overly thick oil.
hobthebob
hobthebob is offline
PostPosted: Thu Feb 06, 2025 4:47 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
Sorry! I posted this in another thread, but I wanted to know what you guys think of this guy and his video on oil?
vamram Premium Member
vamram is offline
PostPosted: Thu Feb 06, 2025 6:12 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
Hmm...can't wait to see the comments. I'm no expert. I use QS full synthetic 5w/30 Dextros 1 on my year-round daily driver '73 1600dp in all temps, nothing fancy. I've *never* had pressure or oil temp problems on this car.
[Edit: Pet-peave: why do so many youtubers always fly their hands around the screen so it becomes the main focus of the video??? Rolling Eyes ]
'75 Super Le Grande...we hardly knew ye. Sold 2025 for peanuts.
Click to view image
Save the Supers!!
Bruce
Bruce is offline
PostPosted: Sat Feb 08, 2025 9:34 am    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
the video wrote:
" if your engine turns 10,000 rpm, you need 100psi oil pressure.
Wildthings
PostPosted: Sat Feb 08, 2025 10:29 am    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
If one runs a 50wt oil the engine will require more oil pressure to get the same volume of oil through the galleys and to the bearings than if you run a thinner oil, while if you have a stock oil pressure relief set up you will ALSO be bypassing the cooler and potentially dumping more oil back to the sump if you make too much pressure, so the actually oil volume to the bearings can be reduced significantly with a thicker oil. Measuring oil pressure just doesn't tell the entire story, VW gives a spec for oil pressure for 30wt oil, so if you were wanting to run a 50wt you would have to have a higher pressure to get it the same amount of oil to the bearing, which might well mean the VW oil pressure relief/cooling system is going to let the oil bypass the cooler and get hotter.
I remember decades ago plugging in the numbers for all the variables of the lubrication system on a then new engine using an accepted engineering equation and coming up with 30wt as the oil that would give the best all around results as far as journal bearing life. I doubt if much has changed since.
I you have loose bearing clearances then you may need a thicker oil to make up for the slop.
vamram is offline
PostPosted: Tue Apr 22, 2025 1:26 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
Synthetic or dino...?
Click to view image
Save the Supers!!
oprn
oprn is offline
PostPosted: Fri May 23, 2025 12:39 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
I don't know if it has been covered here yet or not but for all you heavier is better folks I am seeing ads now for 60wt "racing" oil.
Not my cup of tea but some may want to try it. It's gotta' make your car faster... no?
modok
modok is offline
PostPosted: Sat Jun 07, 2025 2:33 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
Finest crash course on the subject I've ever seen.
Welcome to the future, it's not so bad Wink
And mobil one classic looks pretty legit
https://www.youtube.com/watch?v=a3uXSI9wQv8
Bruce
Bruce is offline
PostPosted: Tue Jun 10, 2025 3:05 am    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
In Mexico, it's pretty easy to find 25W-60 engine oil. The numbers are bigger, so it's gotta be better, right?
jim martin
jim martin is offline
PostPosted: Fri Jun 20, 2025 2:54 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
just chucking it out there, just a different way to look at it and save time with the guessing game.
doesn't anyone measure clearances anymore ?
its kinda the first step in picking a oil weight .
then run it and monitor pressure .
for example my last motor ran main clearance of 0.005" .that motor ran 20w-50
on yearly inspection all bearings looked as new .pressure was ok .
new motor mains are 0.0027" ,will due the same fire it up on 30w and check oil pressure when oil is 200 deg .and in theory will drop down to 10w-40 and again run it an check , simple .
if you don't know your clearances , fire it cold get your idle and driving pressures cold . watch pressures during warm up then when its real hot .
recheck those idle. and say 3500-4000 rpm pressure .you will know if you need to go up or down on your oil weight choice.
knowledge is power .
and you want to save fuel run a 0w-20 . Wink Wink
bearing Oil Clearance Chart for reference
https://cdn.shopify.com/s/files/1/0827/6783/9538/f...1697433294
B.C's fastest street legal vw , June 2006 Hot VW's feature car 9.81 sec at 145.26mph.
Sponsored by :
LUCAS OIL PRODUCTS http://www.lucasoil.com
KROC head porting services
Dialedinperformance.com
Airspeedparts.com topic http://airspeedparts.com/forums/index.php?topic=914.0
modok
modok is offline
PostPosted: Fri Jun 20, 2025 7:54 pm    Post subject: Re: Official "What oil / additives should I use" topic Reply with quote
IT'S TRUE
I mentioned it on page 181
And, here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=467803
Page 236 of 237
