Brake fluid res. Question
carsdlt
carsdlt is offline
PostPosted: Fri Jul 19, 2024 2:16 pm    Post subject: Brake fluid res. Question Reply with quote
Looking at the reservoir from inside the cabin, I've got low fluid on the right chamber and full on the left. Which one is for front or rear? Not able to raise the thing right now but used a flashlight to verify no leaks at the MC .
Thanx, DLT
'73 181 stock 1600 - "Dr. Bombay"
"If it works, don't fix it....let it break on its own."
carsdlt
carsdlt is offline
PostPosted: Tue Jul 23, 2024 2:36 pm    Post subject: Re: Brake fluid res. Question Reply with quote
Nobody knows? Well, I guess I'll find out when I bleed the brakes.
Thanx, DLT
74 Thing
74 Thing is offline
PostPosted: Tue Jul 23, 2024 3:06 pm    Post subject: Re: Brake fluid res. Question Reply with quote
Look at the hoses that connect from the res to the master cylinder-one feeds the front the other the rear
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1000255
carsdlt
carsdlt is offline
PostPosted: Tue Jul 23, 2024 9:07 pm    Post subject: Re: Brake fluid res. Question Reply with quote
Makes sense, thanks.
Thanx, DLT
mondshine
mondshine is offline
PostPosted: Wed Jul 24, 2024 8:15 am    Post subject: Re: Brake fluid res. Question Reply with quote
On a 50 year old car, it is unlikely that the master cylinder, or its supply hoses are original.
Since there is no right or wrong way to route the supply hoses, it's a 50-50 choice.
However, you could peer through the driver's side wheel arch, and probably see
How the hoses are routed.
At the master cylinder, the single steel line at the rear runs to the rear brakes.
The front brakes have individual steel lines connected at the front of the MC.
carsdlt
carsdlt is offline
PostPosted: Thu Aug 15, 2024 4:53 pm    Post subject: Re: Brake fluid res. Question Reply with quote
Thanks,Mondshine. I'll check that out.
Thanx, DLT
volkybus
volkybus is offline
PostPosted: Sat Sep 07, 2024 6:35 am    Post subject: Re: Brake fluid res. Question Reply with quote
Jack up one side of thing or whatever car have somebody hit the rakes. Spin both front and rear wheels. if one spins freely that's the end of the car with the empty side and the problem end of the car. Thing,bus,bug ,gia,Chevy,whatever..good luck..Bill VT & PR
emersonbiggins
emersonbiggins is offline
PostPosted: Sun Nov 10, 2024 9:58 am    Post subject: Re: Brake fluid res. Question Reply with quote
My right side goes to the front.
