Loose red wire in engine bay black box
syncroid
syncroid is offline
PostPosted: Tue Jul 30, 2024 10:41 am    Post subject: Loose red wire in engine bay black box Reply with quote
Is it supposed to attach to the open terminal on this little fuse block?
What is it for?
4Gears4Tires
4Gears4Tires is offline
PostPosted: Tue Jul 30, 2024 11:50 am    Post subject: Re: Loose red wire in engine bay black box Reply with quote
Looks like something in your hand is missing it's female spade connector, just pointing that out.
What doesn't work on your van?
Corwyn Premium Member
Corwyn is offline
PostPosted: Tue Jul 30, 2024 12:11 pm    Post subject: Re: Loose red wire in engine bay black box Reply with quote
Plug it in - lets find out. What doesn't work in your van?
'90 White Westy ("White Lightning")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~
syncroid
syncroid is offline
PostPosted: Tue Jul 30, 2024 12:31 pm    Post subject: Re: Loose red wire in engine bay black box Reply with quote
I'm thinking it's the reverse lights that suddenly stopped working - everything else in that circuit checks out ok. Engine also consistently dies at idle after rehabbing my idle control unit. Used to only die when cold right after startup. I'm just worried about doing some damage by just plugging it in.
Was hoping that someone else would have the same fuse block to confirm.
