Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Mon Jul 09, 2018 12:13 am Post subject: Re: Lower Ball Joint Wear - Limit for T3/T25 Syncro?? |
RichardF wrote: |
After my experience, if the boots are good and there is no play, leave them alone.
You can't expect them to be as tight as brand new ones.
If you are sure you can add grease without damage it can't really do any harm. |
Thanks Richard, good advice. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
RichardF Samba Member
Joined: December 23, 2012 Posts: 12 Location: Southern France
Posted: Mon Jul 09, 2018 8:04 am Post subject: |
Looking at Zeitgeist 13's images (copied below), I just realised that the fact that the lower balljoint on the Syncro is fitted upside down compared with the way it is fitted on the normal T25 may be the reason for premature "failure" of the joint. (If a very small vertical play can be deemed a failure)
The joints with the design "4" should perform better on a Syncro, where the joint is in compression, as the material between the ball and the cap is less likely to be compressed.
However, design "3" might perform better on non-Synro vans, as there seems to be more material between the ball and the stem, to support weight of the vehicle when the joint is in tension.
It seems to me to be a major design fault to use the same balljoint on two different suspension designs, where it is subjected to exactly opposite loadings.
Or maybe they were originally different, but replacing parts with others of similar dimensions but different construction has led to this situation.
_________________ 1987 Syncro Transporter Camper Van. |
Posted: Sun Aug 04, 2024 6:22 am Post subject: Re: Lower Ball Joint Wear - Limit for T3/T25 Syncro?? |
6 years later, and the van is still parked over the pit in the garage with the new engine standing next to it.
I decided to drop the fuel tank to replace all the breather and other hoses, so the new ones are sitting next to the engine, together with all the new parts needed to do the job - HP fuel lines gaskets for injectors, etc., exhaust pipes, clutch, etc. etc.
Bad health followed by Covid put a stop to any work, then we lost our son, who was to help with the work and buy the van, and I really lost interest.
I now have worse problems with my legs, I can drive the automatic Audi, but using a clutch would probably be dangerous if even possible.
If anyone is interested in a LHD 2.1L Digijet Syncro camper van, and could help rebuild and reinstall the engine and fuel tank, or could take the van away by flatbed or trailer, please contact me with any ideas or offers.
We are in small town north east of Carcassonne, and could possibly offer accommodation for a short period. _________________ 1987 Syncro Transporter Camper Van. |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 4525 Location: ABQ NM USA.... Except when not
Posted: Sun Aug 04, 2024 9:00 am Post subject: Re: Lower Ball Joint Wear - Limit for T3/T25 Syncro?? |
RichardF wrote: |
We are in small town north east of Carcassonne, and could possibly offer accommodation for a short period. |
Sorry to hear about your son. What a blow.
Considering you are in France and dealing with a Syncro user Alika cubes to mind to help you or maybe just find a direction to go. He's in here often and I'll PM him for you directing to this thread.
It's looks like a great van and project. I bet you'll get much interest and if for what ever reason it's not going good you want, get in touch. Would love a reason to go to France for my first time. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Sun Aug 04, 2024 9:18 am Post subject: Re: Lower Ball Joint Wear - Limit for T3/T25 Syncro?? |
Thanks vanis13. Pity NM is so far away!
We have had the van since we bought it in Spain in 1999, just before we moved to France, and have had many holidays in it, so want it to go to someone who appreciates it and all the work put into it. _________________ 1987 Syncro Transporter Camper Van. |
Posted: Sun Aug 04, 2024 9:35 am Post subject: Re: Lower Ball Joint Wear - Limit for T3/T25 Syncro?? |
RichardF wrote: |
We have had the van since we bought it in Spain in 1999, just before we moved to France, and have had many holidays in it, so want it to go to someone who appreciates it and all the work put into it. |
You are welcome.
NM is less than half way around the world, no problem! Only a couple days  _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
onwardtothestars Samba Member
Joined: April 04, 2007 Posts: 385 Location: Hazenville Pass Wyoming
Posted: Mon Aug 05, 2024 2:51 am Post subject: Re: Lower Ball Joint Wear - Limit for T3/T25 Syncro?? |
RichardF, just reading through this thread for the first time. I do not post often on the samba.
I'm really sorry about the loss of your son. _________________ Beetle, Ghia, Vanagon Syncro, and more |
Posted: Mon Aug 05, 2024 5:57 am Post subject: Re: Lower Ball Joint Wear - Limit for T3/T25 Syncro?? |
onwardtothestars wrote: |
I'm really sorry about the loss of your son. |
Thank you for your kind thoughts. _________________ 1987 Syncro Transporter Camper Van. |
Posted: Mon Aug 05, 2024 7:05 am Post subject: Re: Lower Ball Joint Wear - Limit for T3/T25 Syncro?? |
vanis13 wrote: |
RichardF wrote: |
You are welcome.
NM is less than half way around the world, no problem! Only a couple days  |
Richard,
While I still think Alika may be a great (possibly the best) person to help you with this, another idea occurred to me overnight....
From where you mentioned in your posts that you could have room at your house for someone while they put the van back together, I could arrange to visit and put this together for/with you and then you could sell it or keep traveling in it for a bit longer and then sell it or do what ever with it ( I could also buy it but the 2wd's were always enough for me so maybe seeking it to a Syncro fan might make more sense....if you like the idea, we can talk about how to put it together.
My motivation would be to help you get this done (*), I like tackling protects, to have a reason to visit the south of France would be awesome (do you know any sailors? I have a sailboat in Florida USA and have sailed in Greece).....Maybe I'd even make a trip to my home town Prague,CZ from which my mom escaped with me and my brother in 1980 when I was 7.
This could be a fun project and a grand adventure!
Timing could be as soon as October and maybe in June could be nicer. What's the weather like by you at those times?
Andy
[email protected]
+1-505-304-5306
(*) A couple summers ago I helped a friend in Hood River, OR, USA get her 91 weekender 2.1 going after she took it to the shop a number of times and they didn't fix it right so she was worried about driving it on trips. I can connect you with her if you want to ask how that experience was for her. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Posted: Mon Aug 05, 2024 1:24 pm Post subject: Re: Lower Ball Joint Wear - Limit for T3/T25 Syncro?? |
vanis13 wrote: |
Considering you are in France and dealing with a Syncro user Alika cubes to mind to help you or maybe just find a direction to go. He's in here often and I'll PM him for you directing to this thread. |
I re-PMd to ALIKA T3. Turns out I messaged user ALIKA and they just let me know it was the wrong one...don't know there were 2 _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7278 Location: Honolulu,Hawaii and France
Posted: Wed Aug 07, 2024 12:32 am Post subject: Re: Lower Ball Joint Wear - Limit for T3/T25 Syncro?? |
Hi Vanis! Salut Richard!
Thank you for bringing this to my attention!
Richard, mes condoléances pour le décés de ton fils, c'est une nouvelle terrible qu'aucun parent ne devrait avoir à vivre
I could help putting this back together but honestly working at someone's house is always full of surprises and challenges, missing parts, wrong tools and so on.
I do this for a living, so I know it's never straight forward, but impossible is not french we say
I'll come back to France next summer, I could take on the challenge depending on my family's schedule or I could also buy it as is and getting it back to my storage in Alpes de Haute Provence (04) to work on it later.
I was actually considering building myself a second Syncro to have back home to camp with my daughter and wife in remote places, so that'll make the project much easier
Aloha!
Alika _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Wed Aug 07, 2024 5:15 am Post subject: Re: Lower Ball Joint Wear - Limit for T3/T25 Syncro?? |
Hi Alika,
Thanks for your interest, but I really want to put the van back on the road here, and possibly make another couple of trips in it, but if I still haven't sorted it by next summer I could possibly arrange something with you.
I bought the automatic Audi Avant, thinking to replace the van, and we have been staying in hotels on our trips since then, but we're fed up with dragging luggage around, fitting in with hotel timetables, restaurant meals which are too big for us nowadays, and being tied down to a schedule. My wife doesn’t like driving it, she finds the visibility is poor with the high window sills of modern cars, and prefers the van.
The van is in our remise in a village 5 km away, and I can assure you that I have all the tools possibly needed for working on it, including an engine stand, engine hoist, chain hoist, press if necessary, wheel dollies to raise the rear end to roll it back over the rebuilt engine/g'box, and all the pullers and special tools required.
I’m an ex oilfield engineer, and have worked on vehicles all my life, so have a fair idea what I’m doing. I’m just not as mobile as I once was.
The van is over my pit, so it’s easy to work underneath.
All the new parts needed have been bought, listed, and checked.
I still have the complete old engine, as I exchanged a spare 2.1 short engine I already had for the rebuilt one.
I also have photos of the engine bay from several angles before removal. _________________ 1987 Syncro Transporter Camper Van. |
Posted: Wed Aug 07, 2024 7:22 am Post subject: Re: Lower Ball Joint Wear - Limit for T3/T25 Syncro?? |
Glad you two connected.
Richard,
I can't think of anyone better than Alika for your project. And I understand you wanting to camp in the van a few more times. There is nothing like a Vanagon!
Alika,
You may not yet know Ricard's age and experience, just let me say that he just may have more time on this earth than you and I combined so another year may be a large percentage of his active time still available.
To both - I'm willing to help as needed to make this happen. Can arrange my schedule to go over sooner or whatever may be needed to give this van life and a chance for Richard to enjoy it.
...it'll be interesting how this goes! _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
