Andrew oval Samba Member
Joined: February 06, 2008 Posts: 82 Location: Oxford, UK
Posted: Fri Aug 09, 2024 12:39 am Post subject: Gearbox ring gear and pinion shaft part numbers |
I need to source a ring gear and pinion shaft for my late 1958 split case gearbox. The gearbox is 113-301-101B
There are plenty of these for sale in the classified section but I need to ascertain which part numbers I need.
Can anyone here help me work out what I need, please?
_________________ 1954 Deluxe oval 'Gertie' - barn stored for 20yrs, work in progress. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25988 Location: Olympia Wash Rinse & Repeat
Posted: Fri Aug 09, 2024 9:59 am Post subject: Re: Gearbox ring gear and pinion shaft part numbers |
The Obsolete Air-Cooled Documentation Project (link below) has a bunch of hard and important original VW factory to dealership literature that are a must to go thru often. Amongst those is the type 2 parts manuals.
http://www.oacdp.org/
You will want to get used to the ten part organized sections in the parts manuals.
Enjoy!! _________________ In Stereo, Where Available! |
Clara  Samba Member
Posted: Fri Aug 09, 2024 3:25 pm Post subject: Re: Gearbox ring gear and pinion shaft part numbers |
IIRC, the pinion shaft has eight teeth for tunnel case, and there are various ring gears
split case pinion shaft has seven teeth,
check the parts list for part numbers  _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Mon Aug 12, 2024 7:58 am Post subject: Re: Gearbox ring gear and pinion shaft part numbers |
Eric&Barb wrote: |
Enjoy!! |
Thanks very much. I found exactly what I needed on there. _________________ 1954 Deluxe oval 'Gertie' - barn stored for 20yrs, work in progress. |
Posted: Mon Aug 12, 2024 8:01 am Post subject: Re: Gearbox ring gear and pinion shaft part numbers |
Clara wrote: |
check the parts list for part numbers  |
Thanks, interesting point about the number of teeth. Mine is a split case but my gearbox rebuilder has it so I don't know how many it has, waiting for him to get back to me.
Seeing your forum name has reminded me that I need to get in touch with you about interior panels, I'll do that via PM.
Thanks. _________________ 1954 Deluxe oval 'Gertie' - barn stored for 20yrs, work in progress. |
