65 European Standard (My Patina Pal)
Page: 1, 2, 3 ... 13, 14, 15  Next
WrennMetallWerks
WrennMetallWerks is offline
PostPosted: Wed Sep 25, 2024 9:21 pm    Post subject: 65 European Standard (My Patina Pal) Reply with quote
It’s been a very long time since I did a thread on a car I’m building for myself, I thought this Standard would be a fun opportunity
From what I see it still wears its original equipment,…
⚒ Believe In The Power Of Positive Thinking ⚒
Purpose Over Pleasure 🕊
“Hard Werk ⚒ God First “
sportin-wood
sportin-wood is offline
PostPosted: Wed Sep 25, 2024 9:24 pm    Post subject: Re: 65 European Standard (My Patina Pal) Reply with quote
Never seen jack stands on dollies! What could go wrong?? Looks like a cool project.
Dave
1966 Bug project
1973 Thing project
OldSchoolVW's Premium Member
OldSchoolVW's is offline
PostPosted: Wed Sep 25, 2024 9:39 pm    Post subject: Re: 65 European Standard (My Patina Pal) Reply with quote
That is some serious patina! Planning to preserve it or restore or ??? Looking forward to hearing/seeing what you do with it. Popcorn
Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
ppilotmike Premium Member
ppilotmike is offline
PostPosted: Thu Sep 26, 2024 5:03 am    Post subject: Re: 65 European Standard (My Patina Pal) Reply with quote
I love the “standards” they are so utilitarian. Looking forward to your build. Very Happy
PostPosted: Thu Sep 26, 2024 5:05 am    Post subject: Re: 65 European Standard (My Patina Pal) Reply with quote
I love the “standards” thy are so utilitarian. Looking forward to your build. Very Happy
WrennMetallWerks
PostPosted: Thu Sep 26, 2024 9:24 pm    Post subject: Re: 65 European Standard (My Patina Pal) Reply with quote
Hey Folks thanks for checking it out.
I plan to just do what it takes to get it going. I do not plan to restore it at this time. It has some pretty good rust here and there so I’m going to just have some fun leaving it the way you see it.
I will take out the drive train and replace it with what will get it layed out on the ground.
WrennMetallWerks
PostPosted: Thu Sep 26, 2024 9:35 pm    Post subject: Re: 65 European Standard (My Patina Pal) Reply with quote
PostPosted: Fri Sep 27, 2024 7:36 am    Post subject: Re: 65 European Standard (My Patina Pal) Reply with quote
Sounds like a good plan to me.
WrennMetallWerks
PostPosted: Fri Sep 27, 2024 8:20 am    Post subject: Re: 65 European Standard (My Patina Pal) Reply with quote
YeSir
I have a zero miles hopped up 40 hp just sitting around in my garage that I plan to stab in there.
The steering lock/ignition key was frozen but lucky I was able to work the key until it came free
I have these old redline tires to put on the original to the car rims
The beam and trans is nothing to fancy but it’s stuff I already had so I’m going rock it for now.
WrennMetallWerks
PostPosted: Fri Sep 27, 2024 8:39 am    Post subject: Re: 65 European Standard (My Patina Pal) Reply with quote
Here is some more jackstand/dolly madness
They are welded so it is definitely a calculated risk
Apostle_
Apostle_ is offline
PostPosted: Fri Sep 27, 2024 9:49 am    Post subject: Re: 65 European Standard (My Patina Pal) Reply with quote
Awesome! Looking forward to this!
The Pilch
The Pilch is offline
PostPosted: Fri Sep 27, 2024 5:41 pm    Post subject: Re: 65 European Standard (My Patina Pal) Reply with quote
Yeah this is great stuff!
'85 Vanagon GL, weekender package, 1.9 wbx named Freddie/ '61 Beetle named Ringo/ '78 Dodge Monaco which is nothing like the Bluesmobile so please don't cast that oily rag upon it.
WrennMetallWerks
PostPosted: Fri Sep 27, 2024 10:06 pm    Post subject: Re: 65 European Standard (My Patina Pal) Reply with quote
Wanted to share some shots when I got the Beetle. There is something so satisfying about washing a VW that has sat forever…
WrennMetallWerks
PostPosted: Fri Sep 27, 2024 10:18 pm    Post subject: Re: 65 European Standard (My Patina Pal) Reply with quote
KLM speedo and the hood with an early prop but the hood still has the hinges that except the springs. Lots of little oddities about this car that I will share along the way.
The mileage is supposedly accurate and has not turned over. I was told the motor runs. I got this car from a friend that purchased it from the Original owner and he told me he is sending me records that indicate this is in fact the original miles on the car. The US born gentleman bought it brand new in Germany when he was stationed there. When he returned to the US he brought the Kar with him.
WrennMetallWerks
PostPosted: Sat Oct 05, 2024 9:44 am    Post subject: Re: 65 European Standard (My Patina Pal) Reply with quote
Finally have some free time to play with the Standard
I’m going to pull this wacky 36 hp set up out and try to make sense of all the unusual tin it took to mix a 36 with 40 tin and heater boxes.
Krazy Kar
House
Minutia Militia
House is offline
PostPosted: Sat Oct 05, 2024 3:56 pm    Post subject: Re: 65 European Standard (My Patina Pal) Reply with quote
The fresh air 36 horse is cool. Cool
WrennMetallWerks
PostPosted: Sat Oct 05, 2024 5:29 pm    Post subject: Re: 65 European Standard (My Patina Pal) Reply with quote
Yep…. It’s pretty neat.
I found it to be kinda tricky to get out.
I tried to pull the breast tin to make it easy but the downdraft tube runs through it and looked everywhere for my tool to remove the filler neck with no luck.
I did notice some interesting tin at the heat riser tube to the muffler.
This pulley tin looked odd to me as well.
I can honestly say I know very little about this application, it’s definitely interesting.
WrennMetallWerks
PostPosted: Sat Oct 05, 2024 5:41 pm    Post subject: Re: 65 European Standard (My Patina Pal) Reply with quote
I typically consider taking a motor out to be easy but I really did struggle with this one. I was by myself and both top motor mount nuts wanted to spin so I had to get creative to stop that from happening. I also struggled with the heater tube coupler on the driver side ,it was stopping me from coming all the way out to be able to drop the motor. The breast tin was still attached by the downdraft tube so it was giving me grief as well. The heads at the muffler have this very unusual adapter/riser to the muffler, I feel like it’s safe to say that had something to do with the muffler hitting the apron so soon. It took some blood sweat and tears but eventually I got it out with causing any new* noticeable damage, to the car that is. lol
67rustavenger
67rustavenger is offline
PostPosted: Sat Oct 05, 2024 6:19 pm    Post subject: Re: 65 European Standard (My Patina Pal) Reply with quote
That's the first time I have seen a VW engine give the mechanic the finger!
That "air bag lift" is brilliant. Compact and portable. Thumbs Up
The scratches on your arm are the price you pay for working on a VW.
I paid a high price once installing the dashboard defrost tube.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
WrennMetallWerks
PostPosted: Sat Oct 05, 2024 7:40 pm    Post subject: Re: 65 European Standard (My Patina Pal) Reply with quote
O snap man
You got it good. I had a picture of my other arm scrapped up too but seeing that I’m glad I saved it and didn’t look weak. Haha.
The motor sure did give me the finger
Page 1 of 15
