Hebmuller door build.
Page: Previous  1, 2, 3  Next
finster
finster is offline
PostPosted: Wed Sep 11, 2024 5:43 am    Post subject: Re: Hebmuller door build. Reply with quote
not quite sure what difference there is on those doors?
Hebster52
Hebster52 is offline
PostPosted: Wed Sep 11, 2024 12:47 pm    Post subject: Re: Hebmuller door build. Reply with quote
The pictures in my previous post are the same door different angle. Very Happy
Here's a later door where the u-channel for door rubber bends over the top.
~Kris~
"The Hebster52" my Hebmuller replica build
The 912ST
The KidVRod project
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen, SOLD
Hebster52
PostPosted: Wed Sep 11, 2024 11:18 pm    Post subject: Re: Hebmuller door build. Reply with quote
Kind of like this on that very early car...
Which is different from atleast the 5th and later production Hebs
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Thu Sep 12, 2024 8:54 pm    Post subject: Re: Hebmuller door build. Reply with quote
Yesterday I welded the holders for the adjustable nuts into the doorwindow rail mounts.
After this I tested to fit the rails with mounts into the doors. I weld the mounts to the doors later though when i mount the doors to the body to ensure the right angle to the cab frame and windscreen pillars.
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Mon Sep 16, 2024 1:41 am    Post subject: Re: Hebmuller door build. Reply with quote
Not much happened during the weekend due to other other stuff but got some details finally fitting perfect.
Got to fix a few things inside while there is easier access before welding though.
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Sat Sep 21, 2024 1:27 pm    Post subject: Re: Hebmuller door build. Reply with quote
Some small progress.
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Sun Oct 13, 2024 9:48 pm    Post subject: Re: Hebmuller door build. Reply with quote
Have not had much time for these the past weeks and just done some minor progress..
But atleast some. Getting the front parts also ready for welding on the first door.
Also started working on the second door now.
The past weekend I also finished the rear corner parts and they are now ready to be welded to the doors!
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Sun Oct 20, 2024 4:17 am    Post subject: Re: Hebmuller door build. Reply with quote
Spent several week with a lot of other work prepairing the house and garden for winter.
Today I got some major job done on the first door!
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Sun Oct 20, 2024 10:06 am    Post subject: Re: Hebmuller door build. Reply with quote
Had to spray a thin layer of some random paint to see the overall look..!
~Kris~
The 912ST
The KidVRod project
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Sun Oct 20, 2024 10:19 pm    Post subject: Re: Hebmuller door build. Reply with quote
That is looking really good! Nice work!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
Hebster52
PostPosted: Wed Oct 23, 2024 9:46 am    Post subject: Re: Hebmuller door build. Reply with quote
Thanks!
Got started on the second door today! Inner structures welded and got the outer patch tackwelded!
The shape even is a mirror image of the first door.
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Fri Dec 06, 2024 9:05 am    Post subject: Re: Hebmuller door build. Reply with quote
Not much progress on the doors at the moment but got the rear corners done in early november.
Brought the body home from storage in the end of October so my main focus is now to work on that. It's been in storage in 15 years so there's some that needs attention too.. And also some work that a younger me with less experience have done that needs to be improved...
You can see the full project in The Hebster52 link in my signature below.
Here a photo of the body outside my garage last weekend.
~Kris~
The 912ST
The KidVRod project
Two Glove Boxes
Two Glove Boxes is offline
PostPosted: Sat Dec 07, 2024 2:28 pm    Post subject: Re: Hebmuller door build. Reply with quote
Awesome getting it done!
1950 Deluxe Sedan Build
Two Glove Boxes IG
johnshenry
johnshenry is offline
PostPosted: Sun Dec 08, 2024 11:10 am    Post subject: Re: Hebmuller door build. Reply with quote
Late to this thread, but WOW, amazing work. Metal fab like that is fun, and really not that hard *if* you take your time and are very patient. Making templates, hammer dollies/bucks is all do able without many special tools. Grinding and flattening (flat filing) welds also takes time but with patience you can make a perfect looking all metal repair/mod. Nice work Habster52, and your welds are very nice and neat! Messy, cold and lumpy welds take SO much more time to grind, flatten and sometimes re-fill. When you get your MIG dialed in for the sheet metal thickness you are using , it is very gratifying.
Keep the pics coming!
John Henry
'57 Deluxe
'56 Single Cab
Hebster52
PostPosted: Mon Dec 09, 2024 9:46 pm    Post subject: Re: Hebmuller door build. Reply with quote
Thanks. Yes, the door work is mostly just time-consuming. Lot of work on small details and most annoying part was to first restore them before even starting the modification work... Laughing
Bodywork would also been easier to do all from the start again as my skills have improved a lot compared to what I could do when I started the bodywork on this over 20 years ago... Embarassed
~Kris~
The 912ST
The KidVRod project
phillmore
phillmore is offline
PostPosted: Sat Dec 21, 2024 12:43 pm    Post subject: Re: Hebmuller door build. Reply with quote
Like John Henry, I’m late to the thread but enjoyed reading and viewing the way you converted the ribbed doors to replicate the conversion carried out on Hebmullers. Your skill and patience will ensure a fantastic car will be made. I’m half way through restoring the body shell on my 54 and know how long each detail takes to get right. Well done and thanks for sharing the knowledge.
peter schepens
peter schepens is offline
PostPosted: Tue Dec 24, 2024 8:48 am    Post subject: Re: Hebmuller door build. Reply with quote
Kristian is doing a great job in recreating the proto type. For all other Heb builders around that are working on the doors... this is a prototype style door with a slight difference in the end part near the B pillar. THe goal for Kristian is to build as accurate as possible. And believe me, it is not as simple as you think.
Zelensis, glassfibre body made in Belgium , disigned and built on a VW platform About 25 body's built.
Hebmuller info wanted for http://www.hebmueller-registry.com/home.html
VW_Jimbo is offline
PostPosted: Tue Dec 24, 2024 9:30 am    Post subject: Re: Hebmuller door build. Reply with quote
Love your work! It inspires me to continue on with my own! Keep up the thread and the panel beating! It looks great!
Jimbo
Hebster52
PostPosted: Tue Dec 24, 2024 1:48 pm    Post subject: Re: Hebmuller door build. Reply with quote
Thanks Peter for your nice words and support through the years of research and for keeping on pushing me forward on this project!
Without you and several other supporters this project would not be what it is now becoming! Pray
More progress to come very soon in the complete project thread. Link below in my signature. Wink
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Tue Apr 29, 2025 1:22 am    Post subject: Re: Hebmuller door build. Reply with quote
Not worked on the doors much the past months since I got the body back to the garage last year.
Mostly focused on finishing up and constucting the rear end as close to what the prototypes would have been done by Hebmuller factory too.
Full project thread link in my profile below.
~Kris~
The 912ST
The KidVRod project
Page 2 of 3
