Joined: August 31, 2013 Posts: 13268 Location: North Carolina
Posted: Wed Oct 16, 2024 9:01 am Post subject: Re: SKULLDUGGERY |
After drilling out the rest of the holes, I slid the seat track into a seat to ensure correct alignment of the tracks.
I then set the assembly onto the pan & positioned it back up to the lines.
And tacked it in place.
Once secured, I removed the seat, flipped the pan over & began filling in the holes.
_________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu Oct 17, 2024 7:57 am Post subject: Re: SKULLDUGGERY |
This morning I plugged up the rest of the holes.
And started knocking down the high spots.
And then buffed them off with a Scotch Brite surface pad.
Posted: Sat Oct 19, 2024 9:28 am Post subject: Re: SKULLDUGGERY |
Today’s endeavors consisted of knocking down the rest of the welds with a cutoff wheel.
Grind them flush with a sanding disc.
And finish them off with a scotchbrite pad.
madster Samba Member
Joined: November 01, 2006 Posts: 213 Location: Rio Grande Valley Texas
Posted: Thu Nov 07, 2024 9:50 am Post subject: Re: SKULLDUGGERY |
 _________________ 1966 BEETLE @ 1973 THING |
