Field find 1954 Canadian custom
Page: Previous  1, 2, 3 ... 35, 36, 37, 38  Next
Dan22
Dan22 is offline
PostPosted: Sun Jul 07, 2024 2:47 pm    Post subject: Re: Field find 1954 Canadian custom Reply with quote
Don, is it the same motor?
1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074
sunroof
sunroof is offline
PostPosted: Mon Jul 08, 2024 10:13 am    Post subject: Re: Field find 1954 Canadian custom Reply with quote
Yes, it is the same motor. She put up a hell of a fight but she is sweet as anything now. The latest is that I had to replace the intake due to a big hole in the heat riser. The good news is that it idles and runs noticeably smoother now.
The bad news is that the diaphragm clutch has got to go. Really hating on it now.
Don
Better and better mistakes!
sunroof
sunroof is offline
PostPosted: Sun Aug 04, 2024 1:10 pm    Post subject: Re: Field find 1954 Canadian custom Reply with quote
Looking at the VIN of my car and the tables here in the Technical section and doing a little math and guesswork I have determined that today is the 70th birthday of my little car whom I call Betsy.
Happy birthday old girl!
Don
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Mon Aug 05, 2024 9:18 pm    Post subject: Re: Field find 1954 Canadian custom Reply with quote
Happy Birthday!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
sunroof
sunroof is offline
PostPosted: Sat Oct 26, 2024 3:32 pm    Post subject: Re: Field find 1954 Canadian custom Reply with quote
The '54 report:
Betsy got some new parts!
Confession time. When I repaired the A pillars I did not brace them up and the whole front of the car dropped about a half centimeter causing the door bottoms to rub on the heater channels. Not much, just enough to take off the paint. Lesson learned. Anyways the door bottoms needed to be replaced due to hinge problems and rust so I bought Virtanen's ribbed door bottoms intending to do the job myself
https://www.thesamba.com/vw/classifieds/detail.php?id=1453062
https://www.thesamba.com/vw/classifieds/detail.php?id=1895664
But I could not figure out how to approach the problem so things sat on the shelf for over a year. In August I had a brainwave and took the car to a buddy of mine who has a body shop in his back yard and he agreed to tackle the door bottoms for me. This is a guy who only takes on projects that interest him so I was pretty stoked that he said yes. Well I got the car back today and am pleased beyond measure.
You can see the line where the new panel starts
Wow. That was worth every penny
Don
heimlich Premium Member
VWNOS.com
heimlich is offline
PostPosted: Sat Oct 26, 2024 3:53 pm    Post subject: Re: Field find 1954 Canadian custom Reply with quote
A diamond in the ruff!
Busstom
Busstom is offline
PostPosted: Sat Oct 26, 2024 6:31 pm    Post subject: Re: Field find 1954 Canadian custom Reply with quote
Bodyline creases look really good, lined up nicely.
VW_Jimbo is offline
PostPosted: Sat Oct 26, 2024 10:32 pm    Post subject: Re: Field find 1954 Canadian custom Reply with quote
That came out great!
Did he cover it with aluminum tape?
Jimbo
sunroof
sunroof is offline
PostPosted: Sun Oct 27, 2024 2:59 pm    Post subject: Re: Field find 1954 Canadian custom Reply with quote
Not sure what you mean
Don
Busstom
Busstom is offline
PostPosted: Sun Oct 27, 2024 11:10 pm    Post subject: Re: Field find 1954 Canadian custom Reply with quote
Maybe a reference to the foil-backed panel damping material inside the door Think
cory464 wrote:
sunroof
sunroof is offline
PostPosted: Tue Oct 29, 2024 8:51 am    Post subject: Re: Field find 1954 Canadian custom Reply with quote
Anyways, further to the '54 report
I debated with myself for a while about replacing the door cards. They were pretty stained and worn out but sort of matched the body. However with the purchase of the type 3
I have decided to sell the beetle. To that end it was necessary to spend the money to get the door bottoms done and make new door cards.
Before:
Here we see the badly damaged hinge mount and my futile attempts to get things to line up. Replacement really was the only possibiliyt
After:
In order to repair the mistake I made with the lower hinges Peter had to drop the hinge about 1/4" to get the doors to fit. Also the hinge mounts in the doors were badly distorted from years of people (me) opening and closing the doors with seized hinges. Also also the door bottoms were rusted through so Peter took care of several problems at once and did a beautiful job. However! This raised the door bottoms by 1/4" so I was pretty worried the new door cards would not fit. OY!
So I was pretty happy with this:
I think that went well.
Don
sunroof
sunroof is offline
PostPosted: Tue Oct 29, 2024 10:06 am    Post subject: Re: Field find 1954 Canadian custom Reply with quote
Also also also in the '54 report:
I was so disgusted with the LED flashing bulbs from CIP I splurged and bought a set from
https://www.classiccarleds.co.uk
https://www.classiccarleds.co.uk/products/6v-self-...amp;_v=1.0
They are worth every penny and the company is one of the best I have ever dealt with online. A completely great experience.
https://www.youtube.com/shorts/P9xz6MuuNSE
Don
VW_Jimbo is offline
PostPosted: Tue Oct 29, 2024 9:59 pm    Post subject: Re: Field find 1954 Canadian custom Reply with quote
Exactly!
Selling? What? Good for you! I will miss your updates. Good luck and I hope it sells quickly and for a higher price than what you set it at!
Jimbo
AlteWagen
Troll
AlteWagen is offline
PostPosted: Tue Dec 17, 2024 9:34 pm    Post subject: Re: Field find 1954 Canadian custom Reply with quote
sunroof wrote:
Of course the window rubber is aftermarket and not correct but it is all that is available so we have to make do. [/img]
Don
wondering what brand of rubber you used. Thanks
Official Dual Carb Thread
sunroof
sunroof is offline
PostPosted: Sat Apr 12, 2025 7:18 pm    Post subject: Re: Field find 1954 Canadian custom Reply with quote
So my buddy Scott is restoring a '54 deluxe
https://www.thesamba.com/vw/forum/viewtopic.php?t=797788
But it came with a set of standard wiper blades. As soon as I saw them I said I want those. So we made a swap and now I have these:
They will go perfect with my car
Super stoked
Don
AlteWagen
Troll
PostPosted: Sun Apr 13, 2025 10:48 am    Post subject: Re: Field find 1954 Canadian custom Reply with quote
I may be mistaken but are those 59 up symmetrical wipers?
This ad looks like it has 3 driver side arms so you would have to bend one arm to make the correct angle for the passenger side.
https://www.thesamba.com/vw/classifieds/detail.php?id=2737433
sunroof
sunroof is offline
PostPosted: Fri May 02, 2025 8:32 am    Post subject: Re: Field find 1954 Canadian custom Reply with quote
I think you are right. I could only use one arm, the other was the same and pointed in the wrong direction. Good spot.
Anyways I was cleaning my windshield and broke the third and last WW reproduction wiper base, those things really are shit. I took the opportunity to install my "new" wiper bases
I think I will have to paint the blades black to match.
Anyways, these NOS SWF wiper bases now go to Scott's '54.
A good swap, happy to get the black ones.
Don
sunroof
sunroof is offline
PostPosted: Tue May 20, 2025 9:28 pm    Post subject: Re: Field find 1954 Canadian custom Reply with quote
Well rats, the generator pulley destroyed itself.
I ordered a new one from Kaefer-nostalgie. I just hope he didn't put it in the mail.
Don
sunroof
sunroof is offline
PostPosted: Fri May 23, 2025 7:38 am    Post subject: Re: Field find 1954 Canadian custom Reply with quote
I bet I could model one of these shims in solidworks and send it to someone with a laser and cut a couple out in the same thickness as the pulley. Then find someone with a lathe to cut the center out of the pulley then find someone with a TIG to weld the new centers in. Hmm, I will have to look into that. The lathe and the solidworks are easy but the laser and the TIG might be a little more difficult.
Also my buddy Jay has a '57 that he has had since he was 15, I remember meeting him then and how proud he was of the car. Fast forward to today and he is now 53 which means he has had the car for, hmm, lets see, where's my calculator... 38, yes, 38 years. Anyways he is not good around a wrench so he has asked me to rebuild his carburetor
Happy to help. I quite enjoy rebuilding 28PCI. Anyways he called me in a panic the other night because his car wouldn't start, turns out it was a stuck needle valve (float valve) so time to rebuild.
Don
67rustavenger
67rustavenger is offline
PostPosted: Fri May 23, 2025 10:54 am    Post subject: Re: Field find 1954 Canadian custom Reply with quote
There's always Send Cut send to laser cut your design.
I know how you folks up north feel about the US currently. Maybe there is a company there that can preform the same type service for you, without the tariff bullshit.
https://sendcutsend.com/?srsltid=AfmBOoqVLFpcu3wkerXzP5BKzaZK2IjBaVtzEF6qUwpcWaOrW7C1YwLE
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Page 36 of 38
