dave1 Samba Member
Joined: September 12, 2003 Posts: 532 Location: United Kingdom, London
Posted: Tue Nov 05, 2024 3:14 pm Post subject: 52 crotch cooler deluxe split fusebox |
Hi all,
Can someone please forward a picture of the fusebox area under the spare wheel area. Are there two fuseboxes in this area, next to each other?
Thanks for you help Dave
splitjunkie Samba Member
Posted: Tue Nov 05, 2024 7:30 pm Post subject: Re: 52 crotch cooler deluxe split fusebox |
There is only one fuse box up front. It's a 6 location fuse box.
_________________ Chris
dave1 Samba Member
Posted: Wed Nov 06, 2024 3:16 am Post subject: Re: 52 crotch cooler deluxe split fusebox |
Hi Splitjunkie ,
Thank you for the pictures. I'm still a bit confused as a 52 wiring diagram shows another 3 fusebox next to the six fusebox. Where should this be located? Car manufacture is Feb 1952 if this helps.
diagram as shown
I appreciate the help Dave |
wagen19 Samba Member
Joined: November 16, 2007 Posts: 752 Location: germany
Posted: Wed Nov 06, 2024 4:49 am Post subject: Re: 52 crotch cooler deluxe split fusebox |
dave1 wrote: |
Hi Splitjunkie ,
diagram as shown
Hello Dave,
the part "M4" you are probably referring is no fuse box, it´s the connector for three wires, two red-black ones for the brake light and the yellow-black for the horn. Have a look on the pics. Compare the symbols for the 3 fuse box in engine compartment "L 3"and the 3-connector beside the front fuse box "M 4". They are different. |
finster Samba Member
Joined: May 26, 2012 Posts: 10191 Location: not far from the madding crowd
Posted: Wed Nov 06, 2024 8:10 am Post subject: Re: 52 crotch cooler deluxe split fusebox |
the key/legend for each wiring diagramme is in the next column to the right
https://www.thesamba.com/vw/archives/info/wiring/4_52bug_key.jpg
google translate can help decipher the german _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
Posted: Wed Nov 06, 2024 8:49 am Post subject: Re: 52 crotch cooler deluxe split fusebox |
As others have said, M6 is the three position screw terminal block that you can partially see under part of the wiring harness in the pictures I posted. _________________ Chris
virtanen Samba Member
Joined: January 08, 2006 Posts: 1497 Location: Finland
dave1 Samba Member
Posted: Wed Nov 06, 2024 5:06 pm Post subject: Re: 52 crotch cooler deluxe split fusebox |
Hi all,
Nice one. Thank you for the feedback & information great help
Dave |
Posted: Wed Nov 06, 2024 7:47 pm Post subject: Re: 52 crotch cooler deluxe split fusebox |
virtanen wrote: |
I'm also putting wiring for my split right now and wonder why there is connector "M2", in-line from ignition switch to coil? Why not connect the wire direct to the switch? |
I think it is there to give a spot for adding a radio or other accessory that needs to have switched 6 volts. Safer than having people messing around with screw terminals on the back of the ignition switch. Just a guess, but makes sense to me. _________________ Chris
dave1 Samba Member
Posted: Fri Nov 08, 2024 1:40 pm Post subject: Re: 52 crotch cooler deluxe split fusebox |
Hi Splitjunkie,
Would it be possible to see what the M4 connector looks like so that I can purchase one through the forum
Thanks Dave |
Posted: Sat Nov 09, 2024 12:26 pm Post subject: Re: 52 crotch cooler deluxe split fusebox |
that's it near the bottom of this photo, they usually come in a strip and you cut off how many you want. _________________ "we're here on Earth to fart around" kurt vonnegut
dave1 Samba Member
Posted: Sat Nov 09, 2024 1:10 pm Post subject: Re: 52 crotch cooler deluxe split fusebox |
Thanks Finster, thought it might be like that but wanted to make sure. Mine at present has a 3 way fusebox which I will change out
Thank you all
Dave |
Posted: Sat Nov 09, 2024 7:39 pm Post subject: Re: 52 crotch cooler deluxe split fusebox |
This is a modern version. Certainly not exact, but gives you a pretty good idea how they look.
dave1 Samba Member
Posted: Sun Nov 10, 2024 10:52 am Post subject: Re: 52 crotch cooler deluxe split fusebox |
Thanks Splitjunkie |
