Starbucket Samba Member
Posted: Thu Nov 14, 2024 1:42 pm Post subject: Re: Odd 2 piece motor? |
[email protected] wrote: |
Starbucket wrote: |
I think that is a Porsche two cyl. air compressor note only the one carb. |
??????? Two cylinder lol
Two cyl.s driving two cyl.s compressing. |
IN2VWS Samba Member
Joined: January 29, 2006 Posts: 2549 Location: Australia
Posted: Thu Nov 14, 2024 2:05 pm Post subject: Re: Odd 2 piece motor? |
Starbucket wrote: |
Starbucket wrote: |
No....It is not a compressor.  _________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹ ¹⁹⁵⁸
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³ |
wagen19 Samba Member
Joined: November 16, 2007 Posts: 664 Location: germany
Posted: Fri Nov 15, 2024 12:01 am Post subject: Re: Odd 2 piece motor? |
IN2VWS wrote: |
Starbucket wrote: |
Starbucket wrote: |
No....It is not a compressor.  |
Please, lift some sheets and let us see the details and give us more information.
Of course no compressor, cause 4 wires to plugs here.
Is it known how many miles or km the engine has already run, or is it still "new"? |
IN2VWS Samba Member
Posted: Fri Nov 15, 2024 2:22 am Post subject: Re: Odd 2 piece motor? |
wagen19 wrote: |
What I know....
The engine builder passed away 15+ years ago.
The engine was running in a Pre-A for a short while. I do not know how many Km's the motor has done. It was removed from the car when the matching numbers engine was found and installed in the car.
It has not been run since. I do not want to pull the engine apart just to see what is inside it.
My plans are to change the seals, check the carburetors, put an exhaust on it, then install it in my '56 Karmann Ghia. _________________ ( ⫏ ⫐ )
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³ |
Posted: Fri Nov 15, 2024 4:08 am Post subject: Re: Odd 2 piece motor? |
IN2VWS wrote: |
wagen19 wrote: |
What I know....
My plans are to change the seals, check the carburetors, put an exhaust on it, then install it in my '56 Karmann Ghia. |
Thank you for your answer. I think, we are on a very good way.
Suggest, it wouldn´t be a fault to replace the oil cooler (radiator) seals...
Then some pics... P L E A S E...
Thank you in advance, (wagen 19)
(I also have low light, a 58 coupe, 1 930 xxx, thinking Porsche too) |
IN2VWS Samba Member
Posted: Fri Nov 15, 2024 1:49 pm Post subject: Re: Odd 2 piece motor? |
wagen19 wrote: |
IN2VWS wrote: |
wagen19 wrote: |
What I know....
I will take some pics when I re-seal the motor. I think I will upgrade the brakes to B brakes when the motor goes in...
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³ |
Joined: June 24, 2015 Posts: 855 Location: Rialto. CA
Posted: Fri Nov 15, 2024 2:22 pm Post subject: Re: Odd 2 piece motor? |
Can I have those front disc brakes ..lol |
Two Glove Boxes Samba Member
Posted: Thu Dec 05, 2024 11:56 am Post subject: Re: Odd 2 piece motor? |
IN2VWS wrote: |
wagen19 wrote: |
What I know....
I think this is a cool ass early Pre-A looking engine, and that isn't easy machine work to make that happen. Also, not for nothing, it does have Porsche carbs, intake, and heads, and with a couple of other changes, it could look even better. Plus, it's going in a low-light Ghia, so it's a perfect complement to an already cool car. _________________ 1950 Deluxe Sedan Build
Two Glove Boxes IG |
