Odd 2 piece motor?
Page: Previous  1, 2
Starbucket
Starbucket is offline
PostPosted: Thu Nov 14, 2024 1:42 pm    Post subject: Re: Odd 2 piece motor? Reply with quote
[email protected] wrote:
Starbucket wrote:
I think that is a Porsche two cyl. air compressor note only the one carb.
??????? Two cylinder lol
Two cyl.s driving two cyl.s compressing.
IN2VWS
IN2VWS is offline
PostPosted: Thu Nov 14, 2024 2:05 pm    Post subject: Re: Odd 2 piece motor? Reply with quote
No....It is not a compressor. Rolling Eyes
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹ ¹⁹⁵⁸
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
wagen19
wagen19 is offline
PostPosted: Fri Nov 15, 2024 12:01 am    Post subject: Re: Odd 2 piece motor? Reply with quote
Please, lift some sheets and let us see the details and give us more information.
Of course no compressor, cause 4 wires to plugs here.
Is it known how many miles or km the engine has already run, or is it still "new"?
IN2VWS
IN2VWS is offline
PostPosted: Fri Nov 15, 2024 2:22 am    Post subject: Re: Odd 2 piece motor? Reply with quote
What I know....
The engine builder passed away 15+ years ago.
The engine was running in a Pre-A for a short while. I do not know how many Km's the motor has done. It was removed from the car when the matching numbers engine was found and installed in the car.
It has not been run since. I do not want to pull the engine apart just to see what is inside it.
My plans are to change the seals, check the carburetors, put an exhaust on it, then install it in my '56 Karmann Ghia.
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
wagen19
wagen19 is offline
PostPosted: Fri Nov 15, 2024 4:08 am    Post subject: Re: Odd 2 piece motor? Reply with quote
What I know....
Thank you for your answer. I think, we are on a very good way.
Suggest, it wouldn´t be a fault to replace the oil cooler (radiator) seals...
Then some pics... P L E A S E...
Thank you in advance, (wagen 19)
(I also have low light, a 58 coupe, 1 930 xxx, thinking Porsche too)
IN2VWS
IN2VWS is offline
PostPosted: Fri Nov 15, 2024 1:49 pm    Post subject: Re: Odd 2 piece motor? Reply with quote
What I know....
I will take some pics when I re-seal the motor. I think I will upgrade the brakes to B brakes when the motor goes in...
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
[email protected]
JERRY63VW@YAHOO.COM is offline
PostPosted: Fri Nov 15, 2024 2:22 pm    Post subject: Re: Odd 2 piece motor? Reply with quote
Can I have those front disc brakes ..lol
Two Glove Boxes
Two Glove Boxes is offline
PostPosted: Thu Dec 05, 2024 11:56 am    Post subject: Re: Odd 2 piece motor? Reply with quote
What I know....
I think this is a cool ass early Pre-A looking engine, and that isn't easy machine work to make that happen. Also, not for nothing, it does have Porsche carbs, intake, and heads, and with a couple of other changes, it could look even better. Plus, it's going in a low-light Ghia, so it's a perfect complement to an already cool car.  Applause  Applause  Applause
1950 Deluxe Sedan Build
Two Glove Boxes IG
Page: Previous  1, 2
Page 2 of 2
