CAD models, drawings and dimensions
sgellis
sgellis is offline
PostPosted: Fri Nov 15, 2024 12:01 pm    Post subject: CAD models, drawings and dimensions Reply with quote
I decided to make a CAD model of my 54 while restoring. Found I was making drawings of the models to help with restoring/building parts. Having 1:1 prints of panels can be quite useful.
Putting all the time into creating models and drawings just for myself seemed like a bit of a waste so I started uploading them to GrabCAD after restoring the parts. Have had almost 500 downloads so thought a thread here for suggestions, comments, questions and experiences with the drawings would be helpful for insuring they are as useful and accurate as possible.
CAD models and drawings
Drawings are in PDF format (insure printing at 100% if using patterns). Any flat patterns have DXF files. Solid models are in Step format. The PNG files are just for previews on GrabCAD.
YouTube videos of my restoration progress
Please let me know here if you see any errors or have any details that I missed. Occasionally dimensions have a ? indicating it is not confirmed and could be accurate or just a guess. Also if anyone has VIN range, part numbers or year data I will add it to the title blocks. That was something I was going to research but never have the time.
These drawing are updated when errors or more info is found. The file name and revision number will change and notes are added to the details. Insure you have the latest revision before using these.
These models and drawings are off my Apr 54 standard. Many changes were made through production so drawings may not match other BD. Also there is a good amount of inaccuracies in the original parts and assemblies. This sometimes made it difficult to come up with the intended dimension.
And thanks for all the help I have received to get this far!
My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings)
Huetti_1989
Huetti_1989 is offline
PostPosted: Sun Nov 17, 2024 1:27 pm    Post subject: Re: CAD models, drawings and dimensions Reply with quote
-printet and in my Barndoor shell for reference measurements Surprised Applause
-Christian
My 1957 SC
http://www.thesamba.com/vw/forum/viewtopic.php?t=605363&postdays=0&postorder=asc&start=0
MY 1967 Sparsamba:
https://www.thesamba.com/vw/forum/viewtopic.php?t=757182
My 1952 Panel:
https://www.thesamba.com/vw/forum/viewtopic.php?t=797388
My 1954 Deutsche Bundespost:
http://www.thesamba.com/vw/forum/viewtopic.php?t=621802
My 1961 SO34:
https://www.thesamba.com/vw/forum/viewtopic.php?t=716285
My 1991 Westfalia California:
http://www.thesamba.com/vw/forum/viewtopic.php?t=650751
Peter_N
Peter_N is offline
PostPosted: Tue Nov 19, 2024 7:19 am    Post subject: Re: CAD models, drawings and dimensions Reply with quote
Thank you for sharing your knowledge and drawings Sgellis.
I don't know if you're a professional CAD drawer, but even then it must have been an insane amount of work to measure and draw.
If I remember correctly, did you also made designs of the ambulance tow hook bracket?
I can't find them anymore on the samba.
My 1958 PGSG project topic
sgellis
sgellis is offline
PostPosted: Tue Nov 19, 2024 9:51 am    Post subject: Re: CAD models, drawings and dimensions Reply with quote
I have it on my other Grabcad account. Mostly stuff from my 64
https://grabcad.com/library/front-tow-hook-vw-bus-1955-to-67-1
sgellis
sgellis is offline
PostPosted: Tue Dec 03, 2024 10:19 am    Post subject: Re: CAD models, drawings and dimensions Reply with quote
Looking for some details for 54 front floor panels. Anything circled in red. These are the bits completely lost on my 54.
Hoping someone can fill in some of these. I think they are close but want them as exact as possible before I share the drawings... and build my floor.
sgellis
sgellis is offline
PostPosted: Tue Oct 28, 2025 11:12 am    Post subject: Re: CAD models, drawings and dimensions Reply with quote
Looking for a few hole details on the transmission hump panel. Hoping someone has some original steel they can measure.
Also is the drain tube hole round on a 54?
ezcamper
ezcamper is offline
PostPosted: Wed Oct 29, 2025 7:25 pm    Post subject: Re: CAD models, drawings and dimensions Reply with quote
super impressive cad skills!
I make HWE style roof racks, Jim-Dandy racks, SO-33 metal parts, Dormobile racks, HWE style ladders, engine crank start handles, Westy rack tags, Binz tags, Sundial badges, State of California tags, steering lock electrical covers and single / double cab gate latch friction blocks.
instagram is http://instagram.com/bullidriversteelworks
FritzCP
FritzCP is offline
PostPosted: Fri Oct 31, 2025 9:45 am    Post subject: Re: CAD models, drawings and dimensions Reply with quote
Well done. I really enjoy the thread updates and following along. thanks for sharing!
Fritz Custom Products
